Battery
12 replies to this topic
#1 MarkO
MarkO
  • 2 posts
Posted 15 February 2007 - 12:54 pm
Hi all just after abit of help. just got the tdm its an 850 and has a flat battery im told the battery is under the tank and not sure how to get tank off ive undone obvious bolt in bottom of tank just wondering if i need to remove all the fairing to get top undone or if its just clipped in somehow?
Cheers for any help
#2 GIBBO
GIBBO
  • 463 posts
Posted 15 February 2007 - 01:42 pm
I've just doen mine and what I did was...
Remove the back wheel
Remove the suspension strut
Remove the battery.
Some suggest you can remove the battery with the strut in place.
My body is a temple, that's why my shoes are on the outside.....
#3 stu
stu
  • 2,060 posts
Posted 15 February 2007 - 03:05 pm
For a Mk2 (mine is a 1999):
Remove rear master cyl bolts so m/cyl can be moved out of the way.
Remove rear brake hose guide from swingarm
Remove battery box retaining bolts (hex key)
Detach battery leads from solenoid.
Lift twist wiggle swear and remove box incl battery from right rear side of bike.
Replacement is as above, in reverse, except swearing occurs when trying to get battery box retaining bolts back in place..
#4 wicklamulla
Posted 15 February 2007 - 07:00 pm
QUOTE(MarkO @ Thu 15th Feb 2007, 12:39 PM) <{POST_SNAPBACK}>
Cheers for any help
Go to Halfords and buy a Haynes manual or down load some it from here i tink ?? http://jbx9.free.fr/TDM/index.php
#5 tdm850rider
Posted 15 February 2007 - 11:47 pm
QUOTE(MarkO @ Thu 15th Feb 2007, 07:39 AM) <{POST_SNAPBACK}>
Cheers for any help
First.... Welcome to Carpe.
I have a Mk1 (1991-1995) and this is how I get to the battery... and yes it is a pain.
  1. Remove the fairing (top and both sides). Not all the bolts are the same length so its a good idea to keep track.
  2. Unbolt the tank, the rear bolt (and washer) then the left and right side bolts. (keep track).
  3. You can now lift the tank up at the back to remove the battery.
  4. NOTE: Unless you like doing all this every time you need to charge the battery install 'remote' wiring from a quality charger on the terminals.
Check your air filter at the same time, lift the entire tank a few centimeters and turn clockwise approx 90 degrees. Three phillips head screws need to be removed to take off the air filter cover.
You can do this alone but a buddy to hand you tools is always nice.
This is actually easier than removing the rear wheel and its a good time to inspect under there.
You may want to install a K&N air filter, high quality and won't need to be serviced for ages.
Like I said.... welcome to Carpe.
#6 MarkO
MarkO
  • 2 posts
Posted 16 February 2007 - 11:13 am
Thanks for that will get it sorted at weekend. bike is for bad weather mostly as ive got a zx7r for summer but was amazed how deceptive it is. Feels like your doing 30 mph you look at clock and its showing 80. Good fun and alot more comfy. lol
#7 Kpnuts
Kpnuts
  • 157 posts
Posted 26 March 2007 - 09:23 pm
QUOTE(tdm850rider @ Fri 16th Feb 2007, 12:32 AM) <{POST_SNAPBACK}>
I dug deep for this one... a forum with all the answers, my god.
I came out to the bike on saturday and to my total dismay found the bike dead.. the culprit was the heated grips..
Not going into detail here, I realized the massive problem of getting to the battery..
Ok i have my answer here, of which i`m grateful, and i do have a new battery to fit but on the above you mentioned "remote" wiring.. are you saying that I can fit an earth and live lead connector away from the battery. and therefore enabling me to charge the battery from there.
Soz if i haven`t understood you and this is not the case.
If thats true is that safe?.. I`m only thinking that the wiring loom is still part of the circuit.
P.S ... I was put off from trying a third time to bump start her.. I was put off by a lad who seemed to "know" .. if you know what I mean. Thought it best myself to take the advice.. I wasn`t sure enough.
Was I ok having a go??
Edited by Kpnuts, 26 March 2007 - 09:32 pm.
Well, everyone knows that the speed of light is 299,792,456 meters per second. and thats all very fine and dandy, and it explaines a lot in our universe ......or is maybe it opens up more questions than answers, and the most important of those is....what is the speed of dark?
#8 wicklamulla
Posted 26 March 2007 - 09:36 pm
previously i had this attached to the + and - terminals beneath the saddle but heres what i did with the Optimate charger extension lead (the one with the eyelets, not the crocodile clips) to keep it out of harms way.
#9 Landy
Landy
  • 1,387 posts
Posted 27 March 2007 - 07:54 am
If you look at this thread you can see the charging tail that I made up for my wife's CBF. It just attaches directly to the +'ve and -'ve terminals. I have some spare connectors so I could make one up for you if you like?
#10 Drew48
Drew48
  • 1,150 posts
Posted 27 March 2007 - 11:08 am
QUOTE(GIBBO @ Thu 15th Feb 2007, 02:27 PM) <{POST_SNAPBACK}>
Remove the battery.
taking the swingarm out was the way I did my MK2 only did it once and lost my temper many times with it trying to "thread" it past the shock before deciding to just unbolt the swinger- has to be THE most stupid place to site the battery but hey they're consistent look at where the main fuses and starter relay are blink.gif
CB125 SUPERDREAM, DR125, MZ125ETZ, CD200BENLY, CB250SUPERDREAM x 2, VT250F, XT350,SRX400,CX500EC,XT600,GPX600C1,TDM850MK2,GS850,TDM850MK1,XJ900F,SV1000S, SV1000N, TDM850MK1 (nr2), TDM850 MK1 (nr3),TDM850 MK1 (quatre)
#11 Kpnuts
Kpnuts
  • 157 posts
Posted 27 March 2007 - 04:59 pm
QUOTE(Landy @ Tue 27th Mar 2007, 08:39 AM) <{POST_SNAPBACK}>
cheers... sons on way home and i`ll see if he`s got that or similar connector in his cases. good idea though.
just come out of garage really annoyed , i cant believe this is what it takes to sort battery. if i`d known prior to spring i would have sorted whilst stored.
[attachment=331:tdm_charging.jpg]
Well... I studied and studied and then wondered if I could take off the `live` wire coming out from the battery cover from the block (notice I don`t get technical here ...) on the right side and connect the positive from the charger. Confident by now it would work just as the `remote` wiring idea. I fastened the earth to the body earthing point. I turned on the charger and felt the wire for heat and searched around hoping I hadn`t made a grave error. I left it half an hour then tried it... it was just short of starting it.
I`ve put my LED light unit on whilst waiting around and hope to start her up after a bit of supper.
I haven`t got my new battery on but I`m going to drop the bike off on friday morn to the local bike man... he can do it.. I`m too stressed... need beer.
Edited by Kpnuts, 28 March 2007 - 07:48 pm.
#12 Hartside Man
Posted 28 March 2007 - 10:18 pm
QUOTE(wicklamulla @ Mon 26th Mar 2007, 09:21 PM) <{POST_SNAPBACK}>
Edited by Hartside Man, 28 March 2007 - 10:19 pm.
#13 wicklamulla
Posted 29 March 2007 - 07:05 am
Amarko ya get ya !
