Hid Bixenon Projectors With Halo Angel Eye Fitted
#21
Posted 13 November 2010 - 11:17 pm
#22
Posted 13 November 2010 - 11:26 pm
#23
Posted 14 November 2010 - 08:27 am
Like the other mods as well, the fairing and screen in particular, is this your own custom one nice one - more info appreciated ?
#25
Posted 15 November 2010 - 10:21 am
#26
Posted 15 November 2010 - 11:05 am
#27
Posted 18 November 2010 - 06:52 am
Please tell us exact make/model of the HID kit and would it be possible to fit it on TDM 850 '91 - '94 (3VD)
Thanks in advance,
Mladen
Edited by longman555, 18 November 2010 - 06:52 am.
The Road Starts here. It never Ends.
#28
Posted 19 November 2010 - 05:39 pm
#29
Posted 26 November 2010 - 06:44 pm
How did you adjust the two lights? I mean, the two lightbeams must be at the same level, but this is hard to see when the lightunit is not fitted on the bike right?
Or can you adjust them seperately after closing the unit?
#30
Posted 29 November 2010 - 03:37 pm
Adjusting the light is exactly the same way as the OEM lights. the 2 projectors fit on the reflectors.
#31
Posted 29 November 2010 - 08:31 pm
Wow, I already opened the unit the way you did, by heating it in the oven. This was much easier than I expected.
Still waiting for the HID kit I ordered.
Thank you so far!
#32
Posted 29 November 2010 - 08:42 pm
Thank you so far!
you're welcome...
remove the caps from the reflectors to be ready for the installation
also remove any old glue-sealant left on the headlight
#33
Posted 30 November 2010 - 07:56 pm
i hate to hijack this thread but i have a question..
ive been thinking on buying HID conversion kits for my 4tx, Thrakiotis seems to think that maybe the hid H7 bulbs wont fit...
is this true?
does anyone have a solution
#34
Posted 30 November 2010 - 08:05 pm
not true...
I just said that H7 projectors won't fit due to the small area between the reflector and the lens...
Simple H7 HID kit would work fine
#35
Posted 30 November 2010 - 08:10 pm
apologies, i must have read it wrong
#36
Posted 03 December 2010 - 10:07 pm
One hour later they answered me that the kit I ordered is not available at the moment, so they canceled the transaction, but they are still advertising on E bay?
Did I do something wrong or what?
#38
Posted 12 December 2010 - 10:52 am
Only 2 more questions; what sealant did you use to seal the headlight? There is no sealant/ glue in the kit.
And second, is the slim ballast really necesary, or can I use the big original ones too? And if not, where did you get the slim ballast from?
#39
Posted 12 December 2010 - 11:12 am
there should be 2 sealant packs in the box...
check the items descrition..and ask the seller to send you
using slim ballast you lose less space, and you can fit them behind the clocks...
if you use the standard ballast you must fit them in the right hand side panel (away from the abs unit-in case you own abs model)
#40
Posted 12 December 2010 - 01:07 pm
I've sent a mail to the seller, no problem I hope
But it doesn't seem too difficult so far, only thing not obvious to me is the power-on test, how did you do this??
