Throttle Position/response
17 replies to this topic
#1 MCBodge
MCBodge
  • 745 posts
Posted 05 April 2009 - 05:16 pm
I've noticed that the TDM throttle opening/twist-grip rotation is very non-linear at wider openings.
There appears to be a noticeable 'step/surge' of torque (in a good way) that starts when the throttle is only a couple of degrees before Wide Open.
Is this normal on the TDM850 or do the carbs need tweaking to smooth this out?
The one thing I didn't check having replaced the emulsion tubes last weekend was the float levels due to a lack of time.
The throttle response is sharp off idle, there are no obvious hiccups or flat-spots and the engine pulls to high rpm.
When I'm not on the bike, I drive turbo diesel car, so am accustomed to a very different, fairly blunt, throttle response.
Edited by MCBodge, 09 April 2009 - 09:03 am.
#2 MCBodge
MCBodge
  • 745 posts
Posted 06 April 2009 - 09:26 pm
TPS appears to be working correctly, so maybe it is normal.
#3 TDMTAM
Posted 07 April 2009 - 08:14 am
QUOTE(MCBodge @ Mon 6th Apr 2009, 10:26 PM) <{POST_SNAPBACK}>
Could be a jetting issue but if its not bothering you I'd not bother chasing it, it would need dyno time.
#4 MCBodge
MCBodge
  • 745 posts
Posted 07 April 2009 - 11:12 am
QUOTE(TDMTAM @ Tue 7th Apr 2009, 09:14 AM) <{POST_SNAPBACK}>
I realise that a dyno session would be required for an optimal set-up, I was just wondering what was a likely cause of such a marked difference in urge over a small range of movement at a wide throttle opening and whether float level might contribute.
If I did decide to go down the dyno route, I'd like to get the bike working fairly well with a bit of DIY before taking it to a dyno for final tweaking.
#5 Guest_GuyGraham_*
Guest_GuyGraham_*
Posted 07 April 2009 - 11:41 am
there is a distinct lag compared to modern FI bikes when opening the throttle, although the higher the rev's the less noticable it is
#6 MCBodge
MCBodge
  • 745 posts
Posted 07 April 2009 - 11:52 am
QUOTE(GuyGraham @ Tue 7th Apr 2009, 12:41 PM) <{POST_SNAPBACK}>
Probably the best way to describe it is
open throttle to 95% open and get 75% of maximum pull
open throttle to 100% open and get 100% of maximum pull
It may just happen to coincide with the alleged dip at mid rpm and hitting the "powerband", but I've noticed a few times.
The power delivery/torque curve feels fairly constant, but it does keep going with urge to the red line.
#7 TDMTAM
Posted 07 April 2009 - 12:05 pm
Try http://www.factorypro.com/
look ing tech support there are some good guidlines there.
#8 MCBodge
MCBodge
  • 745 posts
Posted 07 April 2009 - 04:13 pm
QUOTE(TDMTAM @ Tue 7th Apr 2009, 01:05 PM) <{POST_SNAPBACK}>
Thanks. Some useful info on there.
As a matter of interest, does anybody have a torque plot from a factory standard Mk2 TDM850?
I'm just interested in seeing what the standard is as a reference point.
Edited by MCBodge, 07 April 2009 - 04:22 pm.
#9 wicklamulla
Posted 07 April 2009 - 04:38 pm
QUOTE(MCBodge @ Tue 7th Apr 2009, 05:13 PM) <{POST_SNAPBACK}>
ya i have one in my photobucket link below, but my boike runs a K&N filter (wow) and carbon cans. search the pics and you will find the dynochart.
#10 MCBodge
MCBodge
  • 745 posts
Posted 07 April 2009 - 08:13 pm
QUOTE(wicklamulla @ Tue 7th Apr 2009, 05:38 PM) <{POST_SNAPBACK}>
Cheers wicklamulla!
That's a significant dip at 4-4.5K. It's consistent with the shape of the other plot too.
Is that 'dip' engineered-in by the factory to get around some regulations??
Are they before and after plots or different bikes?
It looks as if it's best to keep above the 'black hole' at 4k and there's nothing to be gained from going above 7.5K
-although my bike seems happy enough going to the red line and gets there fairly quickly.
Edited by MCBodge, 07 April 2009 - 08:20 pm.
#11 robelst
robelst
  • 1,844 posts
Posted 07 April 2009 - 08:40 pm
My Guzzi and Buell have those leaned down dips as standard in the "lower-midrange", just to get around the noise and emission regulations (result of lovely but ancient engine designs laugh.gif ). TDM engines are a lot more modern but maybe they have this effect as well? Unlike my Buell (when it was still standard rolleyes.gif ) I never really noticed it on my TDM. Then again, I have a '01 model which have differences in the carbs compared to models up to '99 or '00 (so I am told). Apart from the odd carb-icing I have to say the throttle response is always spot on (unlike some FI bikes I have owned as well). I bet a modern diesel will always be more lineair though, and so will triples and fours be, but a properly engaging bike shouldn't be too lineair. laugh.gif
That was not a banana, Dougal
#12 MCBodge
MCBodge
  • 745 posts
Posted 07 April 2009 - 09:12 pm
QUOTE(robelst @ Tue 7th Apr 2009, 09:40 PM) <{POST_SNAPBACK}>
As I suspected.
From looking at the Factory Pro site, raising the needle appears to be the method for richening the mixture at thse sort of rpm.
#13 wicklamulla
Posted 07 April 2009 - 09:42 pm
MCBodge, the top pic is of my dyno run (i'm still out of breath) and the borrom one is of Emmett's 1998 MKII but it has TDM 900 barrells and pistons fitted hence the extra bhp, the midrange on his bike felt quite impressive to me when i rode it.
#14 MCBodge
MCBodge
  • 745 posts
Posted 08 April 2009 - 09:51 am
QUOTE(wicklamulla @ Tue 7th Apr 2009, 10:42 PM) <{POST_SNAPBACK}>
Ah, interesting stuff.
Was the dyno plot scan rate done different for that bike? The line is much smoother.
#15 wicklamulla
Posted 08 April 2009 - 10:12 am
QUOTE(MCBodge @ Wed 8th Apr 2009, 10:51 AM) <{POST_SNAPBACK}>
don't u dare speak to me loike that ya fecker rotflmmfao.gif excl.gif sorry man i dunno what ya mean wub.gif but
both bikes were done within minutes of each udder on the same day obviously.
#16 MCBodge
MCBodge
  • 745 posts
Posted 08 April 2009 - 04:05 pm
QUOTE(wicklamulla @ Wed 8th Apr 2009, 11:12 AM) <{POST_SNAPBACK}>
no offence intended, old bean, what, what.
#17 dandywarhol
Posted 08 April 2009 - 05:09 pm
Even with a Power Commander fitted there's still a dip around max noise test area. The revs for taking the reading is based on the engine stroke.
#18 MCBodge
MCBodge
  • 745 posts
Posted 09 April 2009 - 08:02 am
Having experimented this morning, my bike does pull disproportionately harder at "Wide Open Throttle" than it does at "almost-Wide-Open" -Maybe that's just a function of the CV vacuum slide opening for given 'vacuum'/throttle position and isn't really a problem.
There's a slight snatchiness between coasting and power-on. It revs smoothly and the revs return to idle without under-shoot, albeit maybe slightly slowly.. The pilots are set to the standard 2 turns out and I suspect this could be improved on.
-I'm going to try reaching the screws without having to dismantle the bike.
QUOTE(dandywarhol @ Wed 8th Apr 2009, 06:09 PM) <{POST_SNAPBACK}>
So, it's possibly just a feature of the engine's mechanical dimensions. Harmonics, waves etc.
There are two DynoJet places in Stockport. Does anybody have any experience of either of them or any other decent places in the N Cheshire/Manchester/South Lancs area?
Edited by MCBodge, 09 April 2009 - 08:10 am.
