Gear Changing 850.
Posted 03 May 2012 - 08:35 am
Posted 03 May 2012 - 09:45 am
Might be worth having a good look at the front drive sprocket for starters, take the nut & sprocket off and check the splines.
I'm assuming the sprockets' teeth and drivechain are in good condition ?
Might be worth investigating the clutch area, hard to say what's causing yer problems really though.
Have you tried reducing the clutch cable freeplay ?
Could also check the cushdrive rubbers and the sprocket carrier bearing, I had a bearing loose on my mk1 and it wore out the carrier.
Also had a snagging clutch cable that only showed up when I was at high speed and trying to go even faster.
Posted 03 May 2012 - 09:54 am
Posted 03 May 2012 - 12:29 pm
the chain is starting to stretch a little more regular so could do with a change just been putting it off till i have to get the rear tyre change so i can do it all in one go. back sprocket looks ok but best to do it all the same time. not looked at the front yet. the clutch seems ok when i had a look a couple of months ago, no ridges on the basket.
Posted 03 May 2012 - 12:52 pm
When chain is too tight (as you said 20-25mm on your bike), then it stretches out wery quickly. 3VD chain free play should be about 40mm
Posted 03 May 2012 - 02:09 pm
the manual gives free play of between 40 and 50 mm for the 850
Posted 03 May 2012 - 04:39 pm
Posted 06 May 2012 - 04:54 pm
Posted 26 May 2012 - 02:57 pm
Posted 26 May 2012 - 04:47 pm
I wonder if the clutch is dragging when its warm (hot). Only way to tell is to get to the gear clunking stage and stop the bike in 1st or second gear (on a level road). With the clutch pulled in try to push the bike along the road. If the clutch is dragging you'll find it hard to push. If the clutch is dragging you'll need to investigate things like spring length, plate warping etc.
Good luck
Steve K
Posted 26 May 2012 - 05:19 pm
Posted 26 May 2012 - 08:31 pm
Posted 28 May 2012 - 05:17 pm
Yes.
Your description of the symptoms (gear grinding between first and second and nowhere else) points to wear in the components that select the gears sequentially, that is, any or all of the following.
- Selector barrel/ worn channel
- Selector fork/ worn fork faces, bent arms, worn selector dog
- Channels that the selector forks run in on each gear wheel (less likely)
If the previous owner was an accomplished wheelie merchant,or a di*k(not related I hope!), then he would've been banging the bike into second without using the clutch and getting it wrong.
The wear and or bending will be minute, but it's exactly where you and I want to change briskly into second under load in normal use.
Cold engine oil will help.
Given how touchy the TDM is with oil, I don't think using anything else apart from the usual will help in this instance.
I would experiment with drive chain slack to see if this improves matters, as it did with my EXUP, esp if you are large or carry loadsa luggage.
Otherwise the good/bad news is that you'll have to go inside to locate the issue and it may not be obvious. Sorry.
I would adopt a riding technique that skirts around the problem at 1st and 2nd, be gentle and deliberate about changing up for now whilst congratulating yourself for the money saved and time spent riding this Summer. A winter project perhaps
Posted 28 May 2012 - 07:50 pm
#16
Posted 29 May 2012 - 07:51 pm
Thank you openroad. All my EXUPs needed gearboxes seeing to as well because of the way they had been treated. Make the most of the Summer then and keep an eye out for a donor motor. Plenty turn up that are already half split with damaged cranks and heads. You could snap one up fer littles and start on it before dismantling your own bike.
That is what I'd be doing.
