900 timing chain tensioner - Take 3 -SORTED!
11 replies to this topic
#1 dandywarhol
Posted 10 April 2007 - 10:23 pm
Secondly - I've got the 900 one to work. There's a HUGE difference in the spring tension of the plunger between the 850 and 900 - the 850 is a ratchet type with a strong spring and the 900 a worm and nut type with a very weak spring (well mine was)
I don't have a diagram of pic so it's best to PM me and I'll give you my phone number to talk through it but the 900 has a "Slinky" type of coil spring, if that makes sense, the kind of action you'd get in a clockwork toy. I basically dismantled the tensioner assembly and rebuilt it with a couple of more turns of tension, much like winding a clockwork toy up just that bit more (I realise some of the yoof on here won't have a fuckin' clue what I'm on about talking about clockwork wacko.gif )
This gives the plunger some more pressure on the chain tensioner blade and so far (fingers crossed) and 50 miles later there isn't a noise from it yahoo.gif Seems to me that this is a Yamaha production assembly fault even though Yamaha UK have only replace two TDM900 tensioners under warranty ranting.gif
To determine TDC firing on the left cylinder - and without having to take the camcover off (again unsure.gif ) you can remove the cylinder identification sensor out on the top left of the cam cover (this picks up a signal to tell the ECU the left cylinder is firing) and put your little finger down onto the camshaft. Turning the crankshaft in the anticlock (forward) direction you will feel a raised part on the exhaust cam as TDC is approaching - then turn the crank 1 FULL TURN from there and that's the left cylinder firing. I also removed the right spark plug to feel compression to back up this theory/practice but the cam sensor method works rolleyes.gif
#2 Hartside Man
Posted 10 April 2007 - 10:29 pm
QUOTE(dandywarhol @ Tue 10th Apr 2007, 10:08 PM) <{POST_SNAPBACK}>
well done mate good.gif if i get a minute tomorrow Alan i will give you a ring for the Techy details. (p.s. i must be old i know what clockwork is huh.gif )
cheers
#3 dapleb
  • 18,344 posts
Posted 11 April 2007 - 12:55 am
It was only a matter of time until the words "900" and "clockwork toy" were mentioned in the same sentence!
#4 dandywarhol
Posted 11 April 2007 - 08:55 am
QUOTE(dapleb @ Wed 11th Apr 2007, 01:40 AM) <{POST_SNAPBACK}>
As I've said to you before - in life, there's those who can.........and those who can't
#5 Guest_Emmett_*
Guest_Emmett_*
Posted 11 April 2007 - 10:42 am
#6 cupasoop
cupasoop
  • 367 posts
Posted 11 April 2007 - 12:53 pm
#7 Saxo
Saxo
  • 17 posts
Posted 12 April 2007 - 11:12 am
G'day Alan,
Ummmmm....... I'm confused!
You say "you will feel a raised part on the exhaust cam as TDC is approaching - then turn the crank 1 FULL TURN from there and that's the left cylinder firing". But surely if you can feel the lobe of the cam rising, that means the exhaust valve is closed and you are on the compression stroke immediately prior to firing. If you turn the crankshaft 1 FULL TURN more, the exhaust valve will be open and you will be on the exhaust stroke.
Seeya
David
#8 dandywarhol
Posted 12 April 2007 - 12:25 pm
Sorry to confuse you Saxo, and any others................it's the portion of the exhaust camshaft which the sensor picks up from that you're feeling. You would initially think that the "raised" bit would be the sensor pickup BUT it's not! another 360 deg. of crank and the left cylinder is at the end of compression
#9 wicklamulla
Posted 05 August 2018 - 08:55 am
Alan,  does  'at the end of compression' mean TDC ?
#10 fixitsan
  • 4,836 posts
Posted 05 August 2018 - 04:08 pm
G'day Alan,
Seeya
David
The cam sensor doesn't look at cam lobes, instead there is a separate cast raised mound on the camshaft away from the lobes which the sensor is reading
#11 dandywarhol
Posted 05 August 2018 - 11:44 pm
Yes
#12 wicklamulla
Posted 06 August 2018 - 01:44 am
Yes
wank yew very crutch.
