900 Air Box Mod....fantastic!
312 replies to this topic
#181 hallrob1
hallrob1
  • 1,112 posts
Posted 20 July 2009 - 07:47 am
Just re-done the mod (The dealer had "reversed" it at the last service) and I'd forgotten what a difference it makes, just one question - I've sealed off the pipe under the tank but should I also seal off the opening to the metal cap it connects to?
#182 vicens66
vicens66
  • 252 posts
Posted 20 July 2009 - 09:48 am
QUOTE(hallrob1 @ Mon 20th Jul 2009, 08:47 AM) <{POST_SNAPBACK}>
#183 gpwheels
gpwheels
  • 37 posts
Posted 15 November 2009 - 08:43 pm
QUOTE(AzzA @ Mon 22nd Jun 2009, 02:54 PM) <{POST_SNAPBACK}>
Just an update on my experience:
I also enriched both cylinders about 10 points through the "CO Mode", adjusted the slack out of the throttle cable, and tweaked the clutch lever (for ease of use), all this made for a much improved experience.
Excuse my ignorance, but how do you get the CO Mode and is that what everyone uses to check their CO settings/make adjustments?
#184 AzzA
AzzA
  • 1,548 posts
Posted 15 November 2009 - 10:11 pm
QUOTE(gpwheels @ Mon 16th Nov 2009, 07:43 AM) <{POST_SNAPBACK}>
G'day,
Follow this link to JBX's site, it's all laid out there, you might have to click a few times though... his host service is a bit slow at times, but the information is worth the effort. (It's under the "DOCUMENTS" menu if you don't get connected straight away... you may even need to register, which is free and SPAM free too.)
There's no scientific/engineering method of testing; it's just what works for you and your bike. Aim for smooth take-off's and low (crawling) speed handling, without hesitancy on acceleration. You will know what's right and wrong; you'll feel it.
Since my last post I have found, a others have concurred, that plus 20-ish CO points (to your original settings) are the most beneficial. (NOTE: This has been for after-market or modified stock exhausts, so it may be less for stock due to less flow.)
Cheers,
AzzA
#185 gpwheels
gpwheels
  • 37 posts
Posted 15 November 2009 - 11:00 pm
QUOTE(AzzA @ Mon 16th Nov 2009, 12:11 AM) <{POST_SNAPBACK}>
G'day,
Cheers,
AzzA
Thanks for the reply Azza,
have been to JBX's site and printed the necersary docs.
#186 ibi
ibi
  • 23 posts
Posted 16 November 2009 - 03:33 am
Hello boys and girls,am new to this forum and i live in Australia.I own the 07 model and did the mod.1 what made a difference in low revs now am bit confused after reading some topics here about the CO mode.Hopefully someone can help,Why does some set up C1 on 16 an C2 on 20,does it make a difference,can someone explain bit more about the C0 mode and why do we need to adjust it.I have staintune aftermarket pipes on the TDm.Thanks boys
#187 ibi
ibi
  • 23 posts
Posted 16 November 2009 - 05:15 am
Just checked my CO mode settings and its shown as C1 14 & C2 16.I have aftermarket pipes on my bike and one thing is anoing me BACKFIRING mad.gif now am thinking if i change the settings of the CO will there be some changes to backfiring?CAn someone help me regards to this issue?Thanks
#188 Guest_graeme_*
Guest_graeme_*
Posted 16 November 2009 - 10:28 am
QUOTE(ibi @ Mon 16th Nov 2009, 04:15 PM) <{POST_SNAPBACK}>
Hi Ibi, the 14-16 seems to be a very common standard setting. After market pipes will almost show a great improvement to the backfiring as well as general running if you change them to ,say, 30-32. You can alter further or change them back, it wont hurt engine. Remember also to let the throttle go completely off to minimise any backfires, there is no fuel flow when "off" but a little as you open throttle, thats when the backfire will be at its worst.
cheers Graeme
#189 AzzA
AzzA
  • 1,548 posts
Posted 16 November 2009 - 11:16 am
QUOTE(ibi @ Mon 16th Nov 2009, 02:33 PM) <{POST_SNAPBACK}>
G'day and welcome to Carpe,
The CO settings are originally tuned in the factory, to make even any manufacturing variations. One bike might arrive for sale with C1=16 & C2=20, another with 12 & 5, another with -5 & 2, mine turned up with 8 & 8. Think of it as the "CO Lotto".
Generally you will want to keep the two cylinders even, so if you raise C1 by 5 points you should raise C2 by 5 also.
You would only want to change the CO balance when you rebalance the throttle bodies, or you were trying to compensate for a hot running cylinder etc... basically, just keep the balance your bike came new with unless you're doing a proper service with the proper instrumentation.
Cheers,
AzzA
Edit:
PS you will, most likely, need to adjust your idle speed to compensate for the change of mixture.
Edited by AzzA, 16 November 2009 - 11:19 am.
#190 ibi
ibi
  • 23 posts
Posted 22 November 2009 - 12:24 pm
Since i changed the Co mode to C1 30 & C2 32 i noticed i big change to my bike how its running.These no backfiring to the aftermarket exhaust and am really happy the way how it runs.I also did the airbox mode mod(JBX).Thanks to all who gave me some advise cool.gif
#191 Mikey B
Mikey B
  • 289 posts
Posted 14 April 2010 - 07:21 pm
Did mod #1 this week, Monday. Didnt ride the bike until today.
What a difference, bike didn't feel lumpy as if it was in the wrong gear and the roll on pick up was improved. Wished I had done this mod when I first bought the bike.
A big thanks to JBX for the mod and his easy to follow instructions.
#192 SeanW
SeanW
  • 4 posts
Posted 31 May 2010 - 03:17 pm
I just I'd add my four penneth to this topic. I bought an 03 TDM at the beginning of the year and was very disappointed by the low speed engine performance - very jerky. I read the forums in here and took it to Parkroad Superbikes in Southampton. They pointed it out that it hadn't received the TPS mod which they did FOC as part of a service. the performance was much improved but still not perfect. I then read on and discovered the air box mod. I have taken the hose off the top of the air box and blocked it up - at last a silky smooth ride.
PS - I enjoy it so much that I have bought a new TDM - (and that has benefited from the airbox mod as well)
In sum - a big thanks to the Carpe Forum - extremely useful advice!
Sean
Edited by SeanW, 31 May 2010 - 03:18 pm.
#193 td or sv? That is the question.
  • 111 posts
Posted 13 September 2010 - 05:30 pm
So you can get something for nothing! Just to add my thanks to JBX - the air-box mod fixes 90% of the snatching issues on my 2005 bike. I must check with Yamaha that the TPS has been changed, if affected. Can any dealer advise on this after all this time?
Now for the screen....
#194 val
val
  • 6 posts
Posted 27 March 2011 - 08:38 pm
Had my '05 TDM for a month and just done the air-box mod - wow makes quite a difference. Sooooo much smoother for traffic and can just put around between 2-3K without any hassles. Cheers for the tip.
Now got to find out if the TPS has been done. I couldn't see anything noted in the service book - is there a sticker to look for or is it a case of take it to the dealer?
#195 catsbum
Posted 27 March 2011 - 09:05 pm
Re-did mine today, agreed. Way smoother at low revs
#196 Baron
Baron
  • 1,076 posts
Posted 27 March 2011 - 11:27 pm
The low speed throttle response is also improved by rebalancing the throttle bodies though this is obviously a bit more involved than the air box mod.
#197 val
val
  • 6 posts
Posted 30 March 2011 - 08:45 am
Day 3 since doing the mod and all is well.
It seems to have improved the already excellent fuel efficiency as well. I still had 4 bars showing at 200km. Usually The bike drops to 3 bars at around the 180km. This may be due to being able to putt around at lower revs...?
Also found out by ringing Yamaha Australia directly that my particular bike hasn't had its TPS changed, despite several stamped Yamaha dealer servicing since the recall was issued in 2006.
They also mentioned that if the recall work has been done, there will be a sticker under the seat area with the date and recall number written on it. I will take a photo of it after mine gets done shortly. Not sure if this applies for other countries or not.
#198 maldac
maldac
  • 54 posts
Posted 10 April 2011 - 06:55 pm
did mine last night and what a difference it makes, my bike had a misfire at 3k which is all gone and it is much nicer to ride pulling away ay low revs . Happy oh so happy
got one at last
#199 NZTDMGUY
NZTDMGUY
  • 369 posts
Posted 10 April 2011 - 09:33 pm
I am not sure if this is the right spot to post this but a mod can move it if required.
I have only had the bike for 450 kms so cannot accurately judge changes yet, but I did the airbox mod yesterday, disconnected the rubber tube at the top of the airbox and blocked it off, but immediately afterwards, dropped my wife's Raptor off the sidestand and tore a hamstring muscle catching it. No damage to the Raptor blush.gif
My question/comment is, when I cleaned the bike and had a wee play with it, I removed the baffles in the Scorpion exhausts and was amazed at the amount of soot. That would mean that the bike is running very rich, in my opinion, but it has a Power Commander fitted. I have no idea of the mapping in the PC and even if I did I think I would be stuck.
Is it possible to still modify the ECU through the dash to lean the mixture even though there is a PC in the loop? Is the soot an indication of richness or just soot?
Any comments are appreciated.
2008 TDM900 in lovely red
Scorpion cans
Power Commander (under review)
#200 xs2jammu
xs2jammu
  • 55 posts
Posted 28 May 2011 - 05:21 am
Why, why didnīt I it earlier. Anyway now itīs done and I love it how it works now, perfect.
