850 Destruction
892 replies to this topic
#181 dapleb
  • 18,394 posts
Posted 21 June 2019 - 06:19 pm
Stupid colour coding!!!!
#182 dablik
Posted 21 June 2019 - 06:35 pm
Dunno why they could'nt just size them, prolly to simple for the luddites.
#183 dapleb
  • 18,394 posts
Posted 21 June 2019 - 06:50 pm
Good info though dabbers!! Have never put anything other than the bucket what came out back in so never even gived it a thought.
#184 Studley Ramrod
Posted 21 June 2019 - 06:53 pm
I'm wondering if the colour coding is only really meant for help with building the engwin in the factory ?  and mayhaps why ya need to remember where each bucket goes when ya do work on the top.
#185 dablik
Posted 21 June 2019 - 07:02 pm
Prolly matey but you would expect them to remain the same as from factory,unless of course they got mixed up at some point, i need to find a sucky thing to plop on cos i wanna see if they spin fine in situ, one of the buckets feels a bit loose which i would imagine is not the best scenario ? and then their gonna wear over time anyhoo.
#186 Studley Ramrod
Posted 21 June 2019 - 07:15 pm
Serial worrier you are matey. :lol:   Everything wears over time...apparently.  I wouldn't be concerned about it, but I know you're wired up differently to me. lol
Wonder if the paint blobs refer to summat else like the camshaft bearings ?
#187 dablik
Posted 21 June 2019 - 07:24 pm
:dunno:  Na i'm going with buckets, Red and Blue as they mostly corrosponded :D
Anyhoo all mine are labeled up to go back where they came from, but even if they got swapped i guess they would wear in, if i had to replace a bucket ie a new one it's gonna do the same.
#188 Studley Ramrod
Posted 21 June 2019 - 07:33 pm
No wear limit for buckets so difficult to know if they're within tolerance or not eh ?
Anyhoos, soon be time to start building. :)
#189 dablik
Posted 21 June 2019 - 07:47 pm
Yep some are a more firm/snug fit for want of a better description, rebuild hopefully starting in a cuplamore/3-20 weeks, will have the head skimmed, the barrells will go in to be measured and honed/rebored !! and crankshaft checked for runout.
Pulled these 2 hollow grub screws out today (oilway) the other for the output shaft, which were a little loose, i expect vibrated over time, i assume they are meant to be screwed all the way home seeing how their hollow anyway, can anyone comment.
Attached File  20190621_155317.jpg   133.7KB   0 downloads
Haynes gives it a mention but cant find it now, i'm guessing the point of these is to be able to have access to bog brushing the oilways..
Edited by dablik, 28 June 2019 - 07:51 pm.
#190 dablik
Posted 23 June 2019 - 03:25 pm
Gave the bucket bores a quick polish with turtle wax of all things :lol: as it's mild compared to other polishes using a felt dremel type mop, got me bucket which had difficulty to fit but one still really grabby on the inlet side, tried one of me old ones which coincidently has no colour or it's worn off and it slides much nicer :dunno:
Also..........fixed it :D
Attached File  20190623_153845.jpg   123.72KB   0 downloads
#191 dapleb
  • 18,394 posts
Posted 23 June 2019 - 03:48 pm
Snout polished out right nice dabbers hmmmm....
#192 Studley Ramrod
Posted 23 June 2019 - 05:05 pm
Ya gok an udder huan ?
Might be the tight fitting bucket was v slightly ovalled eh.
#193 dablik
Posted 23 June 2019 - 05:53 pm
Oi likked it to def daps ;)
You is doubting moi welding and ploshin skills studs :P
Never thought of it ovalling Ian, could well be, or diff sizes, gonna measure in a bit and see....
Edit.. .5mm difference, suspect your right.......again.
Edited by dablik, 23 June 2019 - 06:11 pm.
#194 Studley Ramrod
Posted 24 June 2019 - 08:53 am
I am if you are matey. :P
#195 dablik
Posted 24 June 2019 - 01:30 pm
Attached File  20190623_153855.jpg   131.69KB   0 downloads
#196 dablik
Posted 27 June 2019 - 08:37 pm
Oh why did i start this :oldgit:
Edited by dablik, 27 June 2019 - 08:42 pm.
#197 Bjørge
Posted 28 June 2019 - 06:18 am
I can feel your pain :sorry:
If it were simple, it wouldn't be as satisfactory when you experience your first test ride !  :pimp:
#198 dablik
Posted 28 June 2019 - 07:56 am
Aye Bjorge your right, it's very time consuming, speciallly when your a tortoise like me, anyway new day, another bit to do.
#199 dapleb
  • 18,394 posts
Posted 28 June 2019 - 08:54 am
Imagine the hourly rate required to make it viable to do a proper job!! It has to be a labour of love at this stage dabbers.
Noubt wrong with slow. You don't have a customer waiting on you. No need to hurry/bodge.
#200 dablik
Posted 28 June 2019 - 12:27 pm
Slowly slowly catchee monkey :)
This lots away to be powdercoated, back in a week or two.
Attached File  20190628_093104.jpg   213.9KB   0 downloads
