Carbs, Probably Not
282 replies to this topic
#181 dablik
  • 10,893 posts
Posted 06 June 2021 - 06:56 pm
No T mark Ian, it's the H mark then I mark for TDC ?
Edit..your testing me aint ya  :P
Edited by dablik, 06 June 2021 - 07:00 pm.
#182 Studley Ramrod
Posted 06 June 2021 - 07:05 pm
:lol: So it's not a T with a line under it at 90 degrees?  :P
Sorry for confusing you matey, I'm deffo a bit rusty when it comes to valve timing.
#183 Snowbird
  • 1,463 posts
I'm thinking by now you need the head off just to pacify your own head but can't help thinking you really need a fresh head to look at it first, it's horribly easy to go blind to something obvious especially when you get pissed off with trying to find the issue, it happens very easily.
#184 dablik
  • 10,893 posts
Posted 06 June 2021 - 07:07 pm
Well that might be, cant say i've noticed another another mark on the rotor though, did turn it a few times...
#185 dablik
  • 10,893 posts
Posted 06 June 2021 - 07:13 pm
See where your coming from Dave and am well and truly pissed off, wish i was'nt such a stubborn bugger but, the crankshaft should not be moving at any time when setting the valves, i've had the cams off and back on and in between rotated 360, even rotated 180 on the off chance i boogered that up without forcing the cams or caps anywhere, summit fishy i think....
I'll ask me mate to pop over next weekend, he's bang on with mechanics and TDM's, i still think the heads coming off though...
Swmbo told me to buy another and part this out  :huh:  :huh:
#186 Studley Ramrod
Posted 06 June 2021 - 07:24 pm
I was just kidding, it is a H mark.
Hey if Nadi's paying, get another bike mate,  them Guzzi V85TT's are peachy. :D  Can't see you parting it out tbh.
I remember fitting a replacement head gasket on the mk2a after the Wemoto one leaked smurfs.  Pretty straightforward with the motor still in the bike, trickiest bit was getting the head back on and compressing the rings.  That said, me and my knees were a good bit younger.
#187 Catteeclan
  • 2,569 posts
Wish you were nearer, it's bugging me too.
#188 dablik
  • 10,893 posts
Posted 06 June 2021 - 07:35 pm
I know the Guzzi is gorgeous but she was'nt being generous matey, it would be coming out of me own money   :huh:
Yea removing the head should'nt be a problem i can wup the carbs off pretty sharp, disconnect the oil pipe, throw the camshafts out to make it easier, just hope the pistons are okay, can turn the crank fine plugs out and cams out ?? compressing the rings is a tough one but Dave's got big hairy hands to do it, he'll have to come up for that...
Me an all Dave, dont understand how i may have bent a valve/s, big bang back awhile with the mk2a carbs or maybe i boogered summit when i redid the timing before hand, it's a mystery, gotta fix it i spose...
#189 Snowbird
  • 1,463 posts
Posted 06 June 2021 - 07:50 pm
Head off, compressing rings??? Am I missing something? Head off should not involve removing pistons surely?
I've not had one apart and also quite pissed now but things are not making sense to me.
Also getting really curious and wish I was closer and could take a peek but not a chance from south cambs. especially when the pubs are open. :drinks:
#190 dablik
  • 10,893 posts
Posted 06 June 2021 - 07:55 pm
S'alright Dave we was just thinkin "what if" i hope the pistons are good, oh i do i do i doooooooooo  :)  obviously not curious enough to leave the pub then  :P
#191 Studley Ramrod
Posted 06 June 2021 - 08:02 pm
Holy moly, I'm getting all confused myself, not even had a drink yet. :lol:   I think it was when I rebuilt the mk2a engine that I installed the barrels and head with the bottom half of the engine fitted to the bike.
Reet, no more posts from me for now. :lol:
#192 dablik
  • 10,893 posts
Posted 06 June 2021 - 09:07 pm
ya did, ya did, no confusion  :good:
#193 dablik
  • 10,893 posts
Posted 12 June 2021 - 06:28 pm
Well i pulled the head today and barring one exhaust valve which needed a tiny tap with a bit of wood i've not found anything to explain the problem..
Pistons not marked
Exhaust valves coking up after 350 miles
I can place the exhaust cam in the Cylinder head and rotate the cam shaft so that the timing marks line up with the crankcase, which in turn opens the valves on cylinder 2 ?  cant do that when it's all in situ and of course that wont allow me to set the timing either as too much resistance, i think i may remove the exhaust valves and check out the valve springs, they were re-used as were showing in spec.
Quite confused now actually  :huh:
#194 Studley Ramrod
Posted 12 June 2021 - 06:50 pm
Yeah, sounds about right opening the valves on no.2.  Wonder if the exhaust valve you had to tap cudda had anything to do with it not rotating ?
Confusing indeed. Is Dave coming over this weekend Dabs ?
#195 dablik
  • 10,893 posts
Posted 12 June 2021 - 07:55 pm
Was'nt much of a tap to be honest, i could push all the others a little wid me thumb, but possibly, have the tools so i will take em out and look see...
Not got hold of Dave but nowt for him to see really now the heads off, i initially wondered if a valve was rocking a piston and moving the crank a bit, that's the big mystery innit, something making the crank move ever so slightly ? Not a mark on the pistons though.. hm, wondering if the rotor has slipped a tad ?
Have to see if removing the exhaust valves shows anything as well..
No gaskets in stock either at Fowlers, anyone know where else i can get oem in the uk..
#196 dapleb
  • 18,387 posts
Posted 12 June 2021 - 08:10 pm
Ewe could try damerells dabs
https://www.damerells.co.uk/
Sorry I don't have anything constructive to say about yer timing issues. 乁( _ )ㄏ
#197 Studley Ramrod
Posted 12 June 2021 - 08:54 pm
Allus good to have a second opinion/looksie and as you said, he's spot on with mechanics and lectrics.  Dunno how the rotor could have slipped a tad, woodruff key and huge bolt holding it there.
Can't help thinking that not tightening up the cam caps to spec might result in the cam not turning freely.  I'll have a scout ferra oem head gasket.
#198 drewpy
  • 1,788 posts
Posted 12 June 2021 - 09:09 pm
 i use yam head gaskets but athena for all other
https://www.ebay.co....EMAAOSwztRe-zeV
from fowlers
#199 Studley Ramrod
Posted 12 June 2021 - 09:25 pm
Fowlers have the head gasket for a 95 tdm as 4NX-11181-00    https://www.fowlersp...view/4NX1118100
CMSL also have the early mk1 head gasket as superseded with the 4NX-11181-00  Soooo, why don't Fowlers have the superseded wan for the early mk1's ?
#200 dablik
  • 10,893 posts
Posted 12 June 2021 - 10:35 pm
Cheers boy's
was looking for 92 but 95 just fine and it's cheaper, wot's that about then !!  92 showing not in stock and up to 10 days delivery, i think a 95 will do nicely then... good spot Studs  :good:
