#2001 fixitsan
  • 4,855 posts
Posted 11 July 2016 - 08:20 pm
Also worth fitting new valve stem seals. :)
Have a full gasket set, including seals on it's way now.  :)
Considering new oil rings on the pistons while they're out. The MK2 doesn't seem to use as much oil (from what I've read) I was wondering of the oil rings, or main rings were different....time to delve into the parts manual !
#2002 Bjørge
Posted 12 July 2016 - 05:10 am
Made a bead breaker out of 2 pieces of wood, a threaded bar, 3nuts, 3 washers and a post base for casting into a concrete base. Success at 1st attempt ! Will show pics later.
Part of the project "fixing-up-my-mate's-er6-that-fell-over-last-year-and-has-only-barely-been-ridden-since-new-in-2006".
Next project: Finding a 14mm unbraco bit to loosen that f&5#!@€ front wheel bolt.
#2003 Studley Ramrod
Posted 12 July 2016 - 01:21 pm
They both use oil tbh.  A cyclinder hone and new rings helped reduce oil consumption on the mk2a I had.
#2004 ChrisG
Posted 12 July 2016 - 01:32 pm
It did on your Mk1 as well, and new valve stem seals reduced it even further.
#2005 Studley Ramrod
Posted 12 July 2016 - 01:38 pm
:wifgeni:
#2006 fixitsan
  • 4,855 posts
Posted 12 July 2016 - 02:30 pm
Thanks for that
I'll see what the budget can stretch to and do the best for the bike that I can.
#2007 Favs
Posted 12 July 2016 - 04:24 pm
New tyres fitted n balanced today.
#2008 ChrisG
Posted 13 July 2016 - 08:02 am
Thanks for that
The gaskets are the most expensive bit so it's worth seeing what else you can do while you're in there.
#2009 fixitsan
  • 4,855 posts
Posted 13 July 2016 - 08:36 am
I know...... and I knew it would all go this way once I started poking about looking for weak spots, lol.
I have a reputation for rebuilding an engine and then wanting to keep the bike it's in....so if that holds true in a few weeks or so I might be selling my 9er, but we'll see...one of them will have to go though, my daughter is doing her CBT in three weeks and I need room !
#2010 ChrisG
Posted 13 July 2016 - 08:45 am
I planned to rebuild by Mk1 when 3rd gear started playing up, but baulked at the price of all the gaskets and parts needed to do it, so I bought a 9er and sold the Mk1 to AlunL, who bought a niner and sold the Mk1 to Studley, and 5 or 6 years on it's still running about with 4.5 gears :D
#2011 Studley Ramrod
Posted 13 July 2016 - 08:56 am
Still on my 'to do' list although I've found it to be perfectly rideable as is. :D  Hoping it won't need another top end refurb as it uses very little oil thanks to Chris's efforts. :)
Tbh, if you're splitting the casings on the engine and it's done a fair few miles you're probably wise to refurb the top end whilst your at it.  I tried not doing this on my mk2a with 43,000 miles but ended up with an engine that used more than twice as much oil as it previously did.  2-3 months later I did a top end refurb as using 2 liters of oil per 1000 miles was annoying to say the least.
#2012 fixitsan
  • 4,855 posts
Posted 13 July 2016 - 09:02 am
By top end refurb do you mean the valves and guides too ?  These are all in pretty good nick and sealing well in the guides as far as I can tell, was just going to change the stem seals and maybe dremmel a few bits to smooth the ports, then clean and lap the valves
#2013 fixitsan
  • 4,855 posts
Posted 13 July 2016 - 09:25 am
I have this set of gears from my MK1....if the gear you need isn't fixed to the output shaft you can take them
#2014 Studley Ramrod
Posted 13 July 2016 - 07:08 pm
Whatever is needed really.  ChrisG had new guides, I didn't need them.
Thanks for the offer but I've already got a spare mk1 gearbox. :good:
#2015 Bjørge
Posted 14 July 2016 - 09:12 am
I've always meant that 3rd gear is overrated. This supports my view !  :pimp:
Part from that, I talked to a guy about painting my old cow. Cheap !
#2016 Favs
Posted 14 July 2016 - 05:14 pm
Fitted one of these (not from this seller), http://www.ebay.co.u...XgAAOSwQPlV-R8B
Not the brightest but good enough.
Also one of thesehttp://www.ebay.co.u...AgAAOSw~gRVuZJQ
to the position light (there is room for 2).
Edited by Favs, 14 July 2016 - 05:17 pm.
#2017 dablik
Posted 14 July 2016 - 05:24 pm
Just got one of those reflectors in the post today Favs, silly sod sent a white one instead of red so it can go upfront, also ordered today a 3rd brake light which is the same as you bought tother week, wot's the flash like, did ya mount on back box then !! shove a piccie up  :giveusahug:
#2018 Favs
Posted 14 July 2016 - 08:52 pm
OK,I'll shove it up for you tomorrow as I'm busy drinking beer tonight. Droop.
Flash is effective as it backed a few off last Sunday on my overnight run north from Farnborough.
Both pics taken with flash to reduce the glare/flare factor
tail lights only
Brake lights
Edited by Favs, 15 July 2016 - 07:20 am.
#2019 Timbo1866
Timbo1866
  • 224 posts
Posted 14 July 2016 - 09:15 pm
Well at last got my lights sorted on my top box, LED tail light with integral fog and high level stop light
Also fitted a internal light it comes on when I open the lid 👌
All ready for the GTG
#2020 dablik
Posted 15 July 2016 - 08:01 am
Cheers Favs you da man  :good: so you have a nice slot for that 3rd brake light, think mine might look a bit odd right on top of the box, still going there though, do you have the choice of 2 brightness levels on that reflector !!
PS still sore from last time you were droopy  :P
    Bing (1)
