#2061 dablik
Posted 27 July 2016 - 08:01 am
Obviously not tweaking hard enough matey  :P
#2062 fixitsan
  • 4,855 posts
Posted 27 July 2016 - 10:12 am
Worth rubbing some copper grease on them nipples before popping them back in
#2063 AliG
Posted 27 July 2016 - 11:05 am
Keep it clean lads!!!!!
#2064 fixitsan
  • 4,855 posts
Posted 27 July 2016 - 12:26 pm
You have a filthy mind !
#2065 Favs
Posted 27 July 2016 - 01:47 pm
Nipples-they get on everyone's tts.
#2066 Studley Ramrod
Posted 27 July 2016 - 03:13 pm
I'm a stroker, not a twanger. :D
#2067 fixitsan
  • 4,855 posts
Posted 27 July 2016 - 09:00 pm
New valve spring compressor arrived, not bad for £9 !
Used it to reassemble the mk1 head
Attached File  head.jpg   264.49KB   0 downloads
#2068 PaydayGabe
PaydayGabe
  • 160 posts
Posted 31 July 2016 - 01:00 am
I'm feeling the pressure. . Literally.
Installed the new/used m/c, 5/8"diameter bore from a honda. VG condition. Took a total of about 7hrs to get the system blend. Christ, , though I was gonna loose my mind. Used the mity-vac, and kept getting bubbles. Though I may be sucking air around the pistons.? I must have cycled a gallon of fluid through this thing.
Anyway, gave it a rest and buttoned everything up. Some gentle pumps on the lever and gradually stiffer feel. Thank God. 😆
Tied the lever w/less than half travel to the bar, checked for any leaks. Everything is great. I'm riding the redhead to work tomorrow. Fuckin A.👍
#2069 arthurbikemad
arthurbikemad
  • 573 posts
Posted 31 July 2016 - 12:16 pm
After months and months of work I got to go for a ride, to work! Anyhow got to take some pics of my old plodder in the brick yard.
#2070 Kelpie
Kelpie
  • 944 posts
Posted 31 July 2016 - 12:28 pm
Great pics Arthur. Gotta love the Greys.
Took ours out to the Hideout bike shop yesterday to replace my ancient Hein Gericke gloves. Popped into Finchingfield for compulsory icecream on the way back. The Red and Grey are bonding nicely.
#2071 arthurbikemad
arthurbikemad
  • 573 posts
Posted 31 July 2016 - 01:50 pm
Thanks, your right Kelpie, them grey ones rock :D
#2072 Studley Ramrod
Posted 31 July 2016 - 01:57 pm
Cleaned the bluespots, replaced the pads and brake fluid 3hour job including bleeding them :D  Then went for a Sunday bimble to the Sherwood cafe.  Not often you see a Firebolt, a Rocket, an RSV4, a Panigale and a TDM900 all lined up. :)
The Panigale was being ridden by a lovely lady. :wub:
#2073 perryman666
perryman666
  • 11 posts
Posted 31 July 2016 - 03:37 pm
Cleaned it, and had a 140 mile blast around Devon on it.
Beautiful weather here today.
#2074 fixitsan
  • 4,855 posts
Posted 31 July 2016 - 05:55 pm
Rode the 900 to South Queensferry for a charity custom bike show (RNLI ) and took some nice pics.
Met a fellow 900 rider, who has a lot of bikes, and he summed up the 900 well saying 'I bought it just to ride'
Then i came home, got my act together and rebuilt the bottom end of the mk1 engine. Need to hone the bores before i finish rebuilding itAttached File  20160731_160637.jpg   138.51KB   0 downloads
#2075 dablik
Posted 31 July 2016 - 06:14 pm
250-300 miles around Yorkshire today with a red stallion
and a red donkey  :P
#2076 arthurbikemad
arthurbikemad
  • 573 posts
Posted 31 July 2016 - 06:24 pm
Oh lots of pics, love the pictures :)
#2077 fixitsan
  • 4,855 posts
Posted 31 July 2016 - 10:05 pm
Some pics from today's fundraiser at South Queensferry
https://www.facebook...77901193&type=3
#2078 PaydayGabe
PaydayGabe
  • 160 posts
Posted 01 August 2016 - 05:44 am
Well, , too much pressure. 🤐
Took the redhead for a quick test ride through the complex this am. 50mph down the backstretch,& stood on the front brake. Worked great till I got home.
Both calipers locked up at the front door.
Hmmm, , thats not good. 👎 had to crack both bleeders so i could get the rig in the house.
I have 2 thoughts I'd like to run past you folks.
1) the honda m/c is not compatible w/these calipots? 5/8"bore is too Lg.
2) the initial test boiled the fluid causing it to expand and lock. Don't know why though. One hard pass? The lever was completely stiff also. ? ?
Your thoughts, suggestions please. Pd G.
#2079 fixitsan
  • 4,855 posts
Posted 01 August 2016 - 06:57 am
Is the m/c new ?
Do the pads pull away slightly from the disc after braking ? (They should) ....are the calipers seized ?
#2080 ProudViking
ProudViking
Posted 01 August 2016 - 08:42 am
You've just convinced me to get some gaiters Arthur... ordered!
