850 Destruction
892 replies to this topic
#201 Studley Ramrod
Posted 28 June 2019 - 05:34 pm
Cool :cool:  What colour ya going for ?
Just looking at yer shadow, are you wearing a dress ? :huh:
#202 dablik
Posted 28 June 2019 - 06:21 pm
Colour, now that would be telling, summit like fifty shades :)
A dress, oh your reminiscing about our cupla days away last year :P
#203 Norwegian
Norwegian
  • 162 posts
Posted 28 June 2019 - 06:44 pm
That shadow is unmistakably that of the Dark Lord, Darth Vader.
#204 dapleb
  • 18,394 posts
Posted 28 June 2019 - 08:17 pm
Lolzio. It's not a dress...it's a nighty. Silhouette tease dabbers.
#205 dablik
Posted 28 June 2019 - 08:40 pm
:lol: sheer no less, it's just a pair of knee length shorts anu t shirt outside ya bunch of pervs  :P
#206 wicklamulla
Posted 29 June 2019 - 02:00 am
wonder if it's worth weld plating the frame as a 'just in case' ?
#207 dablik
Posted 29 June 2019 - 04:40 pm
The idea had crossed my mind Ken, in fact talked it over with aircooled as he's got a tig but he's far to busy, then i forgot, however it was all looking good when i inspected it, should it happen in the future well, guess i can always change frame colour eh :)
#208 dablik
Posted 30 June 2019 - 06:02 pm
Some fiddly bits getting started today.
Attached File  20190628_152709.jpg   239.17KB   0 downloads
Attached File  20190628_152631.jpg   150.92KB   0 downloads
Attached File  20190629_131437.jpg   107.15KB   0 downloads
Attached File  20190629_132448.jpg   163.7KB   0 downloads
The valves were absolutley rotten, even after a good soak in me secret formula the tops of the exhaust valves were rock hard carbon
Attached File  20190630_120212.jpg   131KB   0 downloads
Got handy with the dremel and a brass wheel at first, took most of it off after the soak, but not all
So the bigger tool came out
Attached File  20190630_142809.jpg   146.43KB   0 downloads
All in all i spent around 4-5 hrs cleaning the blighters, but the end result came good
Attached File  20190630_165201.jpg   123.22KB   0 downloads
Finished off on the stems with 1200 wet and dry in the drill.
Attached File  20190630_165212.jpg   139.27KB   0 downloads
#209 wicklamulla
Posted 30 June 2019 - 08:07 pm
So Cliff did that rotor come off in the end and was it corrosion holding it in situ?
#210 dablik
Posted 30 June 2019 - 08:14 pm
Still to do Ken, hopefully grind it off this week sometime fella.
#211 Studley Ramrod
Posted 01 July 2019 - 09:03 am
Been busy then. :)  Good to see.  Some of those valve heads are well pitted eh, looks like rust one the one in the workbench, wonder how that happened ?
Lemme know if a standard oil seal will replace the ones from the rear caliper halves please, ta. :good:
Keep up the good work.
#212 wicklamulla
Posted 01 July 2019 - 09:27 am
there is a rear caliper rebuild kit available which includes that small rubber O ring seal which was previously 'not available'.  The kit i bought includes stainless steel pistons.
#213 dablik
Posted 01 July 2019 - 02:35 pm
It looks like scale and it's rock hard, unless it's carbon burned white !! some of the valves are pitted, may have to clean up the other set and see what them is loike, defo dont want to be buying fookin new ones at 50 splongs a go, because the whole lot may as well get done and that's a bit rich even for me.
Will have a look at these pistons and see if they cant be polished, otherwise more spendies, wont shift without air though, the small seals are flat sided looking at them so dont think you could put a regular seal instead..
Edit....yep thems flat o'rings
#214 dablik
Posted 01 July 2019 - 04:53 pm
Just had another ganders at the valves and the pitting is pretty much restricted to the head of the valve, the seats really look okay to my eye but not been near them while cleaning up, one inlet valve was a bit sticky in it's guide when i oiled em up for the wibbly wobbly test, will find time to clean up the other set and see if any are a bit better.
Also the springs are all in spec albeit slightly different measurements and a couple have a very minimal slight lean of pizza going on i think ill take the best of the 20 i've got to use, if were buying new springs they would have to bed in anyhoos, or am oi barking up the wrong tree !! I know it's generally advised to put everything back together in the same place but if some new parts were needed that's scuppered innit.
When the head comes back prolly best to give it a fine lap and  lash all the gubbins back in with the camshafts and see what the clearances are like, then take it from that point..
#215 Studley Ramrod
Posted 01 July 2019 - 05:22 pm
I've got some flat o rings in my o ring kit. :)
Yeah, smooth valve tops help reduce carbon build up so any non- pitted swapsies would be good.  A gentle lap in and they should beef wine.  Swapping springs is ok too, they don't need breaking in when new.
#216 dablik
Posted 01 July 2019 - 06:10 pm
Now the valves are nice and clean it's quite easy to see the dots on em, middle valves have 1 dot and all outers 2 dots, nowt i can see on the exhaust valves.
Did you fine lap only on yours mucka, i'll post a pic when the heads back from vapourising, then off to crack test, arse way around but did'nt want to wait twice for vapouriseiringing.....
#217 Studley Ramrod
Posted 02 July 2019 - 09:24 am
From memory I think I used both the coarse and fine lapping pastes you get in the tin.  You might only need a fine lap though.
#218 dablik
Posted 06 July 2019 - 09:53 am
Not mush going on at the mo, been painting up a few fiddly bits.
Attached File  20190704_133500.jpg   119.13KB   0 downloads
Other fiddly stuff
Attached File  20190704_133521.jpg   111.89KB   0 downloads
All the friction and steel plates out of spec except for the 1st slick steel plate, Haynes mentions the last friction plate should have a hole in a tab which has to be placed in-situ, aint got one a them, guess they dont come with aftermarket kits then ?? and guess it's not such a big deal either !
Attached File  20190704_153427.jpg   109.41KB   0 downloads
Need to sort some seals out now, o'rings in particular, plenty of cheaper options around for o'rings but knowing what's proper appropriate is a bit of a shitfield, so many choices and will prolly end up being a humungous fowlers list for the most part ^_^
#219 Studley Ramrod
Posted 06 July 2019 - 07:42 pm
Lookin' good. :cool:
#220 Snowbird
  • 1,475 posts
Posted 07 July 2019 - 12:29 pm
I notice the blue spot calipers, did you change the master cylinder to a 14mm bore or keep the original 15.8mm one?
The reason I ask is I just picked up my first tdm and the front brake is rock hard as soon as I touch the lever (works fine though) whereas my fazer thou with blue spots has a lovely progressive feel to it with much more control but has the smaller bore cylinder so I'm thinking of changing it, my hands are not that big (I'm only a squirt) so I find the fazer brake much nicer to use and there are a few about on fleabay.
