#2201 fixitsan
  • 4,855 posts
Posted 06 September 2016 - 10:04 pm
Picked up the 4TX from Pabroom's today...I now have a '91 mk1,  '99 4tx and '04 9er !
mk1 will be going soon, the 900 will be my go to bike until the 4TX is sorted, I prefer the mk1/4tx geometry to the 9er, perhaps if i did a lot of motorway miles I might prefer the 900.
Anyway I've got a winter project for sure !
#2202 Sidarta
Sidarta
  • 845 posts
Posted 06 September 2016 - 10:15 pm
Sid, it looks good on the pistons. No wet oil.
Hi Fixitsan!
I also noticed it.
  It seems that the rings and pistons are within the limit.
Today took the head, (2 camshafts, and covers the axes) for a professional reconditioning engines.
He said that appears to be in good condition.
He asked me to return on Thursday to see the diagnosis.
Let's wait for the return.
Cheers!
Att
Sidarta
TDM850 ano 2001
 Honda XLX 250 1988
Honda CB350 1972 e 1973
#2203 fixitsan
  • 4,855 posts
Posted 07 September 2016 - 03:53 pm
Rode my 900 with my daughter on a hired 125......down into the Scottish Borders and back....
Almost 100 miles, the YBR125 sipped it's way through £3 worth of fuel, while the TDm didn't do too badly either considering the lower average speeds
Attached File  keekmebike.JPG   397.9KB   6 downloads
#2204 Favs
Posted 07 September 2016 - 04:31 pm
Fitted my switched, without extra switches, aux lamps (not DRLs), only to have 2 LEDs fail once I had everything buttoned up  - grrrrr - took em back off and isolated the wiring - making sounds of escaping pressurised steam due to boiling P.
PS - I used the audible warning button as a cancel for aux dip.
#2205 Studley Ramrod
Posted 07 September 2016 - 04:39 pm
Sounds like everone's having fun in the sun today, :)   'cept Favs. :(
Got my noo rear tyre fitted and also fitted the scottoiler, which is actually working. :D  Might go for an evening blast to scub the tyre in and see if my headlamps are any good, not used them in darkness yet. :huh:
#2206 Sidarta
Sidarta
  • 845 posts
Posted 07 September 2016 - 09:33 pm
Hi fixitsan!
Beautiful walk record. The 900 is very beautiful.
We also have the YBR 125, manufactured in Brazil.
Cheers!
Att
Sidarta
TDM850 ano 2001
 Honda XLX 250 1988
#2207 wicklamulla
Posted 07 September 2016 - 09:40 pm
yep this is the first ting i noticed when i tried a 900. 4TX is a 'roomier ride'.
#2208 Kelpie
Kelpie
  • 944 posts
Posted 08 September 2016 - 07:19 am
Lovely pic! Tell your daughter about the Facebook group Motorbike Women and also the all lady club, Curvy Riders MCC. They're a great bunch with lots of members in Scotland.
#2209 fixitsan
  • 4,855 posts
Posted 08 September 2016 - 02:24 pm
Thanks Kelpie, I've passed it on :)
#2210 richierex
richierex
  • 166 posts
Posted 09 September 2016 - 12:54 pm
put my standard cans back on and did the airbox mod again(reversed it for its first service)
Did you find the airbox mod worked. It made mine virtually unrideable, jerky and very rough when starting. Its a 2007 ABS model
#2211 frits44
frits44
  • 170 posts
Posted 10 September 2016 - 07:11 am
richierex,
If you do the airbox mod like JBX, then nothing can go wrong.
After you did the JBX mod on your airbox, you can modify the cover of your airbox
like I did and many other people.
All bikes run better with the modified airbox on the TDM 900
Until now I fixed 18 bikes and all of them run much better and smoother
New and better air filter, and modified airbox cover.
Greetings, Frits from holland
#2212 Latestarter
Latestarter
  • 676 posts
Posted 10 September 2016 - 07:15 am
Best mod you can do on a 900, done my 2003 and a completely different bike. I done the air box pipe, pulled it off from the air flap & put a self tap screw in it
#2213 richierex
richierex
  • 166 posts
Posted 10 September 2016 - 11:31 am
Well it didnt work on mine. 2007  ABS  like i said. difficult to start and very jerky, pop bang, put it back and it purrs. I think the later bikes are not as bad as the early ones, i certainly wouldnt recommend it.  And for those who think i am incompetant, I removed the wire from the ECU as described on here and put it back as a reverse of the procedure, not really rocket science, the hardest part was removing the side panel
#2214 Latestarter
Latestarter
  • 676 posts
Posted 10 September 2016 - 12:41 pm
@richierex sorry it never worked for your motor, there's a rake of technical support on this forum and I'm just posting up on what I've done and what I've read done by others regardless of the year of bike involved.
Not sure on your comment about incompatance, as I'd be shocked if anyone would think that on this forum from my experience.
We're a friendly bunch on here... We even talk to the odd GS rider now & again 😜
Ride safe my friend..
#2215 richierex
richierex
  • 166 posts
Posted 10 September 2016 - 01:26 pm
richierex,
I will bring mine to you because it certainly did not work by just removing the wire from the ECU, but I am not sure what I would achieve!
#2216 frits44
frits44
  • 170 posts
Posted 10 September 2016 - 02:07 pm
richierex,
I did the mod 3 on my bike plus mod. air box cover, plus Co setting higher from 14 to 54 on both cylinders
My bike runs very smooth and strong in very low rpm ( from 1200 rpm to the red sone)
No jerkynis or on of effect in low rpm.
I also removed my katyllic converters from my stock exhaust.
You can do it yourself, use the info from this site and from the JBX site.
http://www.jbx9.16mb...ex.php?page=AIR
Mod number 3 remove it al and modify the airbox cover, also remove 10cm foam on each site to get more air.
Use the info on this forum and you will be oke with your bike.
Put your Co settings around 25 or 30 on both cylinders with stock exhaust, with open exhaust go higher in your Co settings
You have the same ECU like I do, new model from 2007 to 2012.
http://s1175.photobu...html?sort=3&o=1
Succes with your mods.
#2217 Latestarter
Latestarter
  • 676 posts
Posted 10 September 2016 - 03:19 pm
richierex,
Option B was the route I took while doing a service and this very same document I've just emailed over to smid69 in PDF format :-)
#2218 Favs
Posted 10 September 2016 - 03:53 pm
New aux lamps fitted n working ~ testing tonight success 😆
Edited by Favs, 10 September 2016 - 08:54 pm.
#2219 PaydayGabe
PaydayGabe
  • 160 posts
Posted 12 September 2016 - 03:23 am
Spent the weekend bike tinkering.
Installed the spot lamps on the redhead. Quite easy after picking brains (bigmatt/g650xtdm).Thank gentleman. They work beautifully.
And had a new skin mounted for the Vstrom. Shinko 805. Mmm,meaty.
#2220 PaydayGabe
PaydayGabe
  • 160 posts
Posted 12 September 2016 - 03:44 am
I've tried to post some pics lately. Site Says their too big. Guessing its the resolution size. My phones lowest setting is 6 megpixl. Is it me or the phone? Cheers.✌
