#2361 fixitsan
  • 4,855 posts
Posted 08 November 2016 - 07:20 pm
The exit pipe is 36mm diameter, about tge same as the inlet, and you could see through from one end to the other. Great deep tone but very loud
#2362 fixitsan
  • 4,855 posts
Posted 08 November 2016 - 09:26 pm
Just plumbed in the proper wiring for the heated grips (relay and fuse)....
...hmmm wouldn't it be nice to have hot water grips, tapped off the radiator....
#2363 PaydayGabe
PaydayGabe
  • 160 posts
Posted 09 November 2016 - 06:23 pm
Morning troops, , ? for Studley. In your post from yesterday, the Silver 850. Is that your machine? If so, I love it. Beautiful specimen. 👍 Tell me about the bash plate. Looks real stout. Thanks, G 😎
#2364 Got1now
Got1now
  • 240 posts
Posted 09 November 2016 - 08:59 pm
Took the battery off, put it on charge.........ready to see if it fires up. Is there an easy way to get the battery off on a '99 850? Seems a real pain, so will have to get a charger connection wired up, then hopefully I wan't have to do it again.
#2365 Studley Ramrod
Posted 09 November 2016 - 11:00 pm
Morning troops, , ? for Studley. In your post from yesterday, the Silver 850. Is that your machine? If so, I love it. Beautiful specimen. Tell me about the bash plate. Looks real stout. Thanks, G
Thanks Gabe, it was my first TDM. Sadly stolen and torched by thieving scum. :(  You can see what I did to it over the time I owned it in the photo below.
The bash plate/belly pan is this wan http://www.carpe-tdm...showtopic=33660
#2366 PaydayGabe
PaydayGabe
  • 160 posts
Posted 10 November 2016 - 06:48 am
Damn Studley, thats a freaking shame. Scum is an understatement. P.O.S. mother f#@k's. Karma will rule for those ass's. Hope their in jail.
Thanks for the reply. You do nice work.
Cheers, G. 😎
#2367 fixitsan
  • 4,855 posts
Posted 10 November 2016 - 06:26 pm
Taxed the mk2 and  :yahoo went :yahoo: fer :yahoo: a :yahoo: ride :yahoo:
First impressions - Absolutely neutral handling, it doesn't do what you don't tell it to do through the bars, and i really like that
Suspension - set up too hard (by me)....front forks I'll tweak, and probably reduce the preload and rebound on the rear, but because I think I'll be keeping it I might have the EMC rear shock rebuilt  (from the pile of spare parts sold me by Paul, the EMC shock was an MOT fail)
Tyres - actually got a bit warm, despite the 4 degrees celsius outside, and once the oil from the garage floor (ha !) had been run off they felt good
Engine - running sweet, no leaks or noises
Fuelling - a bit iffy, but that was as expected (but perfectly useable) ......  Going to try the lower mileage dynojetted carbs when I get a round toit, but the current carbs are working well, just some slight flat spots and feels like there's more to be had from the top end
Steering stick - the big Renthal sticks work well, but are canted slightly too far forward so I'll tweak them back a bit. Heated grips working well :)
Gearbox - much slicker than my mk1 was and a really pleasant surprise. I think I might try one tooth larger on the front sprocket, but haven't even checked yet to see what it's currently running
Doesn't feel too much slower than my 900, and if all goes to plan with the 4 degree timing advance I'll be trying, it should be a bit more satisfying.
Pretty sure that I'll be selling the 900 soon......great bike that it is, i can't justify keeping both
Edited by fixitsan, 10 November 2016 - 06:44 pm.
#2368 fixitsan
  • 4,855 posts
Posted 11 November 2016 - 07:01 pm
Another 50 miles on the mk2....feels really solid.....
There's a slight smell of fuel  which might be a slight fuel leak or it might be nothing like that, but there's no sign of wetness anywhere around the carbs.
As I'm going to work on the spare carbs i won't waste much time on this pair.
Clutch lever is more heavy than the 900, and even on minimum adjustment the biting point is almost all the way out at the end of the lever's travel, which even with my long hands is a stretch. I'm actually wondering if a 900 clutch cover with it's improved clutch release mechanism is a possible fitment. I might take the one off my 9er to find out.......unless anyone else knows any different ?
It feels good, sounds great, a few tweaks required but nothing to stop me from jumping on it tomorrow and riding a long way if the weather permits :)
#2369 Andy25
Andy25
  • 344 posts
Posted 11 November 2016 - 07:23 pm
Strange had the same issue with the clutch on my mk2 when I got it this year
A new cable and adjustable lever resolved the issue for me
Good to hear your enjoying the bike.
#2370 fixitsan
  • 4,855 posts
Posted 11 November 2016 - 07:29 pm
I might look into that.Andy. thanks
#2371 fixitsan
  • 4,855 posts
Posted 12 November 2016 - 02:43 pm
Ended the year on the mk2 in Glencoe, where i started it on the 9er
Attached File  20161112_132839.jpg   118.81KB   0 downloads
Attached File  skyfall-bond-and-m.png   197.03KB   0 downloads
#2372 dablik
Posted 12 November 2016 - 04:45 pm
The new Bond bike  :)
#2373 fixitsan
  • 4,855 posts
Posted 12 November 2016 - 06:30 pm
More from today... Glencoe, Glen Etive, Rannoch moor and Loch Katrine
Attached File  Katrine.jpg   229.57KB   0 downloads
Attached File  etive1.jpg   271.91KB   0 downloads
Attached File  etive2.jpg   279.85KB   0 downloads
Attached File  etive3.jpg   273.12KB   0 downloads
Attached File  etive4.jpg   316.45KB   0 downloads
Attached File  etive5.jpg   359.67KB   0 downloads
Attached File  etive6.jpg   262.76KB   0 downloads
Attached File  glencoe2.jpg   254.21KB   0 downloads
Attached File  glencoe3.jpg   337.14KB   0 downloads
Attached File  glencoe.jpg   211.64KB   0 downloads
The mk2 seems to have used a ton of oil....but then again they do, although i wish i had of been a bit more patient and got some new piston rings in it. not to worry though because it rides great !
Edited by fixitsan, 12 November 2016 - 06:33 pm.
#2374 Andy25
Andy25
  • 344 posts
Posted 13 November 2016 - 12:10 pm
Cracking pics
Wasn't planning on any more trips up that way this year
But now I may have to just to keep me going through the winter
Must remember it's now time to wear more than a T shirt under my jacket no matter how mild it feels when I step outside
#2375 fixitsan
  • 4,855 posts
Posted 13 November 2016 - 01:41 pm
Cracking pics
Every year i say I won't ride through the winter....but then you get an odd dry day in December when the weather gets as high as 6 degrees .....
Ive got a pump action garden sprayer which i fill with hot soapy water as soon as I'm home to spray off most of the salt with.
I used to courier through winter here in Edinburgh so i dont feel its abnormal to want to go out and get some 'me time' even in bad weather.
For me the worst is wind....i can ride in sleet, you just take care, but high winds on the motorway tire me right out quickly
#2376 fixitsan
  • 4,855 posts
Posted 13 November 2016 - 01:49 pm
Disabled 1st and 2nd gear learner modes on the mk2, and fitted spare set of carbs which had apparently been professionally set up.
Bike runs so smooth in power transitions on/off throttle and the hunting at 5000rpm when cruising is gone (15t front sprocket)
Happy days !
#2377 Andy25
Andy25
  • 344 posts
Posted 13 November 2016 - 03:43 pm
Commute all year round ( only bike license ) only 5/6 miles to work .
But your right about the winds make things really tough
Did leave the Bike at home couple of days ago because of wind
Got blown over on driveway haha
#2378 drewpy
  • 1,790 posts
Posted 13 November 2016 - 03:44 pm
Happy days !
whats 1st 2nd gear learner mode?
#2379 fixitsan
  • 4,855 posts
Posted 13 November 2016 - 04:11 pm
The ignitor unit is set to restrict maximum torque in first and second gear. Quite common among many bikes,some Suzuki and other brands models invoke it in 3rd gear too). Torque limiting is achieved by retarding the ignition timing
It serves several purposes, among which are that it makes the bike easier to handle at low speeds, it's less likely to wheelie, and it protects the gearbox to a certain extent too.
The switch contacts are on the neutral switch assembly, and they go back to the white wire of the 6-pin plug connected to the ignitor, I've just removed the white wire from that plug and tucked it inside the sheath of the harness.
Attached File  Torque.jpg   532.56KB   0 downloads
Edited by fixitsan, 13 November 2016 - 04:16 pm.
#2380 drewpy
  • 1,790 posts
Posted 13 November 2016 - 04:24 pm
thanks interesting to know, my bike shoots off in first so wonder if this has been done already.
always something to learn on these bikes, brillant :badgerrock:
