#2381 Studley Ramrod
Posted 13 November 2016 - 04:33 pm
Just looked at the wiring diagrams and the mk1 doesn't have the white wire, strange that the learner mode wasn't introduced until the mk2 came out.  Mk1 is a lot smoother at low revs though. :D
Do you know if disabling it has improved the bike at all ?  Or is it possible that the replacement carbs have made the difference you mentioned ? :unsure2:
#2382 fixitsan
  • 4,855 posts
Posted 13 November 2016 - 05:33 pm
It's definitely made a difference. I disabled it lastnight and got 20 minutes on it this morning, before changing the carbs
One easy way to check if it has already been disconnected is the next time you take the left side panel off, disconnect the 6 pin plug (only 4 wires wired into it) from the ignitor, and check with a multimeter in resistance mode for continuity between the white wire terminal of the plug and earth of the frame (battery negative)...If it has been disconnected there should be no continuity to ground shown when you move the gear lever between neutral and 1st gear
The mk1 doesn't use it, but it has very simple ignition, less to go wrong with it, but without a throttle position sensor the timing cannot be advanced when you crack the throttle open in response.....mk1 timing is only advanced relative to engine speed
#2383 JBX
Posted 13 November 2016 - 06:41 pm
Strange enough, the TRX850 share the same engine with the 4TX but it does not have the 1st & 2nd gears wires.
Also strange is that the 4TX have longer 1st & 2nd gears than the 3VD, so wheelings should not be the right reason imo.
#2384 fixitsan
  • 4,855 posts
Posted 13 November 2016 - 07:10 pm
True yes, but the 3VD has a less potent advance mechanism
The throttle position sensor, TPS, of the mk2 has no effect on fuelling, only on ignition timing. It enables an amount of advance to be used in response to demands for acceleration.
The 3vd is not demand sensitive, but if it were it's overall performance would be improved.
#2385 chrisbee
chrisbee
  • 413 posts
Posted 14 November 2016 - 07:25 am
Thanks Gabe, it was my first TDM. Sadly stolen and torched by thieving scum. :(  You can see what I did to it over the time I owned it in the photo below.
The bash plate/belly pan is this wan http://www.carpe-tdm...showtopic=33660
Amazing transformation....
 Keep up the good work
#2386 Got1now
Got1now
  • 240 posts
Posted 14 November 2016 - 04:12 pm
Took the carbs off......ready for the strip and inspection, I think the emulsion tubes may be worn, it's been running but rich.
'Twas a fiddly job though, especially when you're trying to work in a small shed! The stripdown of the carbs will be done in the warmth and space of the front room............when she's out one day :angel:
#2387 Favs
Posted 16 November 2016 - 08:46 pm
Ridden it to do some selfish Christmas shopping (I had no Aperol & Prosecco left darling), a hew heater for the shed was also required, - nearly had to switch the heated grips on cos I stayed out playing  enjoying the ride on dry roads in the sunshine (an excuse to empty the tank prior to some maintenance). :P
#2388 Got1now
Got1now
  • 240 posts
Posted 20 November 2016 - 12:48 pm
Stripped l/h carb. Emulsion tube doesn't appear to be badly worn, but will probably do it anyway, as it's apart now. Float bowl had a very interesting brown dust (rust) in it, so full carb strip and clean is in order..... One carb top screw was pretty tight, but gave up after a while!
#2389 sidestand
Posted 20 November 2016 - 12:55 pm
Well, yesterday I sold one of mine - the Mk2A has gone to a new home  :good:
Room in the garage  for another bike now  :badgerrock:
#2390 Got1now
Got1now
  • 240 posts
Posted 20 November 2016 - 02:34 pm
#2391 jono49
jono49
  • 1,183 posts
Supertenere on it's way then? :good:
#2392 Studley Ramrod
Posted 20 November 2016 - 05:22 pm
Look forward to seeing the noo steed. Not at all envious, oh no. :lol:
You lucky, lucky boy. :lol:
#2393 chrisbee
chrisbee
  • 413 posts
Posted 20 November 2016 - 08:55 pm
New owner of the Mk2a reporting for duty......
First job is to change the fork oil
#2394 Studley Ramrod
Posted 20 November 2016 - 08:58 pm
Congratulations on yer noo steed Chris.  :good:
#2395 fixitsan
  • 4,855 posts
Posted 20 November 2016 - 09:31 pm
Took the mk2 out for a 50mile run....very smooth, much fun....pretty filthy now !
Started to price up how much a programmable FI system would cost...
Programmable ECU - £180
Throttle bodies - £50
Fuel pump - £40
£270 for fully programmable fueling and ignition....But i find these well tuned carbs to be 'adequate' just now :)
#2396 Kelpie
Kelpie
  • 944 posts
Posted 21 November 2016 - 11:39 am
Rode it from Harlow to Potters Bar to meet up with pals at 0630 am on Saturday for the journey up to the NEC Bike Show in -2 Deg C.  Bought ear plugs and rode it home again in 3 deg C.  Lost BSM in the dark on the M6 (yes I was worried!) and found him again on the A14 (happy days).  Rode it to the Bike Shed in London yesterday and home again, not so cold this time.  Have I mentioned I love my TDM?
#2397 Studley Ramrod
Posted 21 November 2016 - 11:44 am
Ear plugs. :lol:
#2398 Kelpie
Kelpie
  • 944 posts
Posted 21 November 2016 - 11:50 am
Ear plugs. :lol:
BSM knows how to treat a lady. :rolleyes:   :rotflmmfao:
#2399 Bjørge
Posted 28 November 2016 - 01:58 pm
Rear axle stuck - hammered out bit by bit in approx. an hour (phuh)...
Disassembly for taking to the paint shop - almost there  :lol:
#2400 g650xtdm
g650xtdm
  • 295 posts
Posted 28 November 2016 - 02:06 pm
Fuel pump - £40
Details?  I wouldn't mind converting my Mk1 to FI as a bit of a project.
