Edited by Jim, 18 December 2016 - 07:43 pm.
#2421
Posted 18 December 2016 - 07:43 pm
84 Honda XL600R ![]()
04 TDM900 ![]()
21 KTM 790 Adventure
#2422
Posted 19 December 2016 - 09:48 am
Today I kept hold of my 900. I got a good trade in offer against a low miles Buell Ulysses which was very tempting. After a little thought I realised the TDM is a better bike for me at the moment. Wouldn't have minded the Ully though
A colleague of mine was looking at a Buell earlier this year, as he fancied a change from his beemerGS
He ended up trading in his BMW for a new Multistrada 1200
Last week i heard that he has sold the 'Strada for an R1200, apparently he found the Strada too fast and pokey ! - (EDIT, to be fair he is only about 5'5", if that matters)
The Buell looks the part, although a strada would be my choice (If ever i had that sort of money)
Edited by fixitsan, 19 December 2016 - 10:10 am.
#2423
Posted 19 December 2016 - 01:40 pm
Yes, Multistrada's are okay (basically a TDM copy aren't they
04 TDM900 ![]()
#2424
Posted 21 December 2016 - 12:21 pm
Dropped off a French EMC rear shock for the mk2 with Dunfermline Motorcycles to see about getting it rebuilt.
Paid up 250 quid for the damage caused when the same mk2 fell onto a brand new Volvo last week ..... the sticky sidestand has now been greased to buggery....
#2425
Posted 22 December 2016 - 11:36 am
I had a test ride on a Ulysses some years back. Sadly on a wet road so I didn't push it as much as I've have liked. Huge bike, massive vibration (indicators bounce up and down on tickover
), felt like you really needed to ride it like a hooligan. Somewhat put off by the fact the collector box was rusty on the very low mileage demo bike I took out.
#2426
Posted 23 December 2016 - 05:40 pm
You getting OCD about a bit of rust Chris ! - it was the rust that held your old Mk1 together FFS ! ![]()
The older I get, the better I was96 MkII in yellow & silver with bluespots, braided lines, Remus 2 into 1, Hagon rear shock & fork springs, bashplate, heated grips,Motech pannier racks, Road Attacks, Jockoiler, Baglux tank cover & bag. Gone to a far better place - hasn't it Remo?
Posted 24 December 2016 - 07:20 am
#2428
Posted 24 December 2016 - 09:39 am
Back on topic.
Forks rebuilt
new tyres avon storm 3d xm (great in wet)
new yss rear shock
oil and filter change
rear flashing brake light ( keeps knobs well away )
main stand
engine bars
new chain sprockets
that will do for now
Don.
#2429
Posted 24 December 2016 - 10:23 am
Front and rear wheels rubbed down, 3 coats of primer, 3 top coat black and 1 coat of lacquer. ( look surprisingly good when finished - I was dubious at doing them myself)
New set of bearings fitted to rear wheel - very easy to do
Front and rear brakes serviced and new pads fitted
Brake disc bobbins cleaned and released.
Forks removed and new dust seal slid in to place
Oil and filter changed
Replaced spark plugs
K&N air filter cleaned and re-oiled
New chain and sprocket set fitted (JT)
All silver painted surfaces 'T' cutted
Foot hangers removed and foot rests moving parts copper slipped
Foot hangers cleaned with autosolve
Black plastic parts cleaned with trim cleaner
Took about a week doing a couple of hours a day , lots of radio 2, gallons of hot splosh and bickies
#2430
Posted 24 December 2016 - 11:48 am
Just finished replacing shagged out sprocket carrier bearing
#2431
Posted 24 December 2016 - 12:00 pm
copper slip is only for using on non ferrus parts and ferrus fixings, it acts as a barrier and eases them to come apart. use correct grease for which ever application. I use moly for bushings (the black stuff) and LM grease for bearings, copper is for case scews etc
#2432
Posted 24 December 2016 - 03:42 pm
Rode the mk2 into Edinburgh to avoid all the traffic.....except there was no traffic ! Sods law.....So had fun on the emptyish roads and seem to have blown a hole in the exhaust downpipe 2:1 joint.... ooops
#2433
Posted 24 December 2016 - 07:52 pm
About 7 years ago I was using Texaco Multifac multipurpose grease on the hangers but when stripped down after 12 months the grease had totally disappeared, hence the copper slip which works and fine.
Not sure if the Texaco grease was out of date or something wrong with it but I have never used it since
#2434
Posted 27 December 2016 - 08:32 pm
I just got rear swingarm linkage bushings removed. Not as difficult as I feared. ![]()
Removed ton of oily blu-tack kind of stuff under the sprocket cover. Wonder what kind of chain lubricant previous owner used as there was so much crud packed in there.
#2435
Posted 30 December 2016 - 09:41 pm
Got mine all packed away and secure as I won't be riding before May due to health conditions.
Its so nearly done I'm annoyed I didn't get it finished this year. But hey ho you'll all get to see the finished lady one day!
I added up all the "up-grades" and not surprisingly its astronomical! Lets just say I can see a Multistrada in her shadow
Edited by ProudViking, 30 December 2016 - 09:43 pm.
#2436
Posted 30 December 2016 - 11:41 pm
Weather was so mild this evening i rode into Edinburgh to see the torchlight parade, and can confirm the mk2 does use some oil (at long last) After changing the output shaft oil seal 300 miles ago the oil level has dropped from slightly overfilled to just below full. I can live with that !
#2437
Posted 07 January 2017 - 06:26 pm
Changed the fuel pump (thought it was causing misfiiring at high speeds, then found one carb a little bit loose in the rubber, so tightened that one up. Also cut into the air intake to help with breathing. The bike seems as keen as mustard now, and looks almost the same colour as it too ![]()
While doing that the courier arrived with AliG's side panels, so they got fitted too Can't wait for the lower sides to arrive now !
intake.jpg 78.55KB
0 downloads
#2438
Posted 07 January 2017 - 10:34 pm
Great, the yellow ones are the fastes anyway ;D
-putt putt?
-braap?
-braaaaaap!!
#2440
Posted 08 January 2017 - 06:39 pm
Took it for a ride to Inverness as part of a Bikes Against Bullies run
Some fabulous scenery on the way up, lots of low hanging mist, and all for a good cause.
The mk2 was tremendous, although 0.6L of oil in 360 miles (Probably most of it gone on the quicker return journey
KS1.jpg 183.39KB
1 downloads
20170108_131844.jpg 204.67KB
1 downloads
The only TDM in the village.... https://www.facebook...?type=2
