#2441 dablik
Posted 08 January 2017 - 06:45 pm
Think you actually had the best of the weather today Chris for a change, no need to change oil for you then  :D
#2442 fixitsan
  • 4,855 posts
Posted 08 January 2017 - 06:59 pm
Aye. Continuous replenishment systems are the way forward ;)
#2443 sidestand
Posted 08 January 2017 - 08:37 pm
I actually charged the batteries & turned them over ............
Then fitted my new MRA screen & Akra end can to my S1000  :badgerrock:
#2444 drewpy
  • 1,790 posts
Posted 08 January 2017 - 09:45 pm
snapped the exhaust studs off the left cylinder, they wont go with a welded nut on so its a drill out job :(
getting there....slowly
#2445 fixitsan
  • 4,855 posts
Posted 12 January 2017 - 08:15 am
Booked the mk2  in for an MOT on Saturday....hopefully it will be snow free !
#2446 perryman666
perryman666
  • 11 posts
Posted 12 January 2017 - 10:56 am
Opened garage door, and apologised for dropping him last Sunday, then closed door quickly. Stuffed my back in proper, as I tried to hold on and limit the fall impact.No riding til better😣
Any of you peeps live in or around N Devon?
#2447 ChrisG
Posted 12 January 2017 - 11:00 am
Ouch, did you do much damage to the bike?
#2448 perryman666
perryman666
  • 11 posts
Posted 12 January 2017 - 11:22 am
Bike's fairly well scuffed on both fairings anyway (not by me), so I can't say. Cracked one plastic mount on the right side handguard, but nothing else.
Love the bike, but it is a bit heavy for 79kg me.
#2449 ChrisG
Posted 12 January 2017 - 01:07 pm
You can solve that problem with the liberal application of cake :)
#2450 wicklamulla
Posted 13 January 2017 - 11:22 am
rotflmao!
#2451 fixitsan
  • 4,855 posts
Posted 14 January 2017 - 12:13 pm
Went for a slippery road MOT.
Failed due to a broken rear number plate (slipped my mind)...and a binding front brake (recent seals so perhaps another bleeding will sort it out)
Just had a message saying my 2nd hand 900 mirrors are available for collection. Just as well because one of these 850 ones is only just hanging together with epoxy !
Edited by fixitsan, 14 January 2017 - 12:15 pm.
#2452 perryman666
perryman666
  • 11 posts
Posted 17 January 2017 - 07:38 pm
Cake .....and beer.
#2453 JBX
Posted 18 January 2017 - 12:36 am
It depends on your fat/muscle ratio. ;)
#2454 perryman666
perryman666
  • 11 posts
Posted 18 January 2017 - 08:35 am
A£$ !!
Off to the gym I go then.
#2455 fixitsan
  • 4,855 posts
Posted 20 January 2017 - 04:43 pm
Received a call from Dunfermline Motorcycles to say my EMC shock was ready for collection. Once again I can only give praise for what they've done (last year they rebuilt my standard 900 shock.)
I got this EMC (French apparently) shock in a box of spares with my recently acquired  mk2 850. It had lost it's gas but is apparently designed to be rebuilt.
The work carried out amounted to  drilling the . body and fitting a refilling valve, replacing the gas control valve with an Ohlins part, fitting Ohlins seals, and fitting a heavy duty CRF450 rose joint for the connection to the swingarm.
£115 including vat :good:
I know that some people would be desperate to repaint it.....but it's on the inside where the good stuff happens ;)
Attached File  EMC.JPG   333.23KB   25 downloads
Edited by fixitsan, 20 January 2017 - 04:45 pm.
#2456 fixitsan
  • 4,855 posts
Posted 21 January 2017 - 03:33 pm
Mk2 went in for it's MOT retest and passed. All i had to do for the binding front brakes (new seals in November) was clean up the pad edges again (hazards of winter riding) and bleed the lines again. Now the pads pull off the discs cleanly.....
Have received the side panels/lowers which  AliG sold to me so I'm hoping to get those fitted in the coming days.
EDIT....fitted the fairing lowers. Had some of the yellow checker vinyl left over from the mk1 so made discs of that and applied it to the scratched area on each side.
Also fitted my old bar muffs. It's possible that I might be riding to York next weekend for a Bikes Against Bullies run, so my hands wimped out and demanded some windproofing  !
Edited by fixitsan, 21 January 2017 - 06:43 pm.
#2457 Andy25
Andy25
  • 344 posts
Posted 21 January 2017 - 08:18 pm
Looking good Fixitsan
I know they offer bugger all protection in an off. but for keeping hands warmer
Ski gloves are great ( using a £5 pair from Aldi at the moment )
Don't even bother with the heated grips
Andy
#2458 Matlock
Posted 21 January 2017 - 08:24 pm
Cleaned a load of oil off the rear wheel & tyre sidewall after my Scotoiler feed pipe worked loose from the joint at the tee piece to my Henty dual feed oiler. Luckily I spotted it before it got bad. Replaced the silencer securing band on the RHS that was badly corroded and while it was off, stripped & cleaned up the rear caliper. the 6 months old piston was already starting to corrode. Bloody salt  :rant:
#2459 fixitsan
  • 4,855 posts
Posted 21 January 2017 - 09:17 pm
Andy
Do you retain finer control of switchgear ?  When i think of ski gloves i imagine huge mittens !
#2460 Andy25
Andy25
  • 344 posts
Posted 21 January 2017 - 10:09 pm
Yep total control . Was surprised myself but the pair I'm using are pretty thin and feel like they won't keep the cold out but are better than winter gloves costing £60 -£70
Like I say wouldn't want to come off wearing them.
Actually used them last month ( Dec ) was freezing cold left Dundee heading for Oban
Had to stop in Crieff to buy another pair of socks and thermal insoles but hands were fine
Normally on daily commute hands / fingers are starting to get numb and that's only 5 miles
Might actually buy a good pair before end of winter as long as I don't crash I'll be fine
Andy
Edited by Andy25, 21 January 2017 - 10:11 pm.
