#2541 fixitsan
  • 4,855 posts
Posted 29 April 2017 - 09:55 am
Any tips for doing the disk bobbins, fixit
Scissors and graphite for sure !
Scissors which have flat sharp edged backs to the blades. IE when the scissors are closed the 4 outer edges of the blades are machined flat and have a sharp edge. The blades are tapered. Keep the scissors closed and push them into the sprung side of the bobbins. The 4 blade back edges will cut slightly into the inside of the bobbin to grip it, and the large handles will give you some purchase.
Before trying to turn the bobbins I fill the opening between the inner disk hub and the outer disk rim at the bobbins with fine graphite powder of the sort locksmiths use -  http://www.ebay.co.u...-8AAOSwPCVX9lYY
The graphite powder is obviously perfect for lock preservation (non liquid so it doesn't attract dust and build up crap)...but it is also good on the bobbins, so I worked a good amount into the gap around the bobbin edge and could see, and feel, that the bobbin was loosened up quite a bit. It doesn't wash off easily or dribble onto the disk face to contaminate it
#2542 PICARD
  • 1,786 posts
Posted 29 April 2017 - 11:01 am
Bolt through bobbin hole, tighten nut onto it and use a spanner to turn it. Use brake cleaner or in stubborn cases, WD40 to release and turn. Be sure to clean off any WD with brake cleaner before riding.!!! Works for me.
#2543 fixitsan
  • 4,855 posts
Posted 29 April 2017 - 12:48 pm
Usually works for me too !
#2544 redrex
redrex
  • 84 posts
Posted 29 April 2017 - 02:02 pm
Rebuilt and fitted forks, fitted master cylinder, (cheers Drewpy), bled the brakes, took it for a little ride round town, scared a few people backfiring, booked the MOT, "fitted" some bmw handguards, that really don't fit. Thought about changing the carbs, fell asleep instead.
#2545 GrandPaul
GrandPaul
  • 97 posts
Posted 29 April 2017 - 02:34 pm
...scared a few people backfiring...
Those days are over for me!
New emulsion tubes.
GrandPaul
Author "Old Bikes"
Does not use emoticons
#2546 Favs
Posted 29 April 2017 - 02:42 pm
Replaced air filter with Yamaha OE, removed aux lamps for relocation, removed aux power socket for relocation.
New C&S + pair of tyres delivered.too.
#2547 dablik
Posted 29 April 2017 - 04:34 pm
Worked for me also but now dont have the luxury of bobbin holes   :sorry: looks like i need a wubber ammer !!!
A bit of painting today
[URL=http://s868.photobucket.com/user/doggsie/media/Mobile%20Uploads/20170429_171218.jpg.html]20170429_171218.jpg
Edited by dablik, 29 April 2017 - 04:33 pm.
#2548 drewpy
  • 1,790 posts
Posted 29 April 2017 - 06:01 pm
nice one, glad they were OK for you :)
I raised the screen 10mm using alloy spacers cut to size.
I see the modern bikes have this to balance out buffeting, we'll see
#2549 Favs
Posted 30 April 2017 - 11:50 am
Test ridden for combined modifications - airbox gubbins removed (spare box), new air filter installed and GPR exhaust fitment - C1 &  C2 set to 50 for first run & seems to pull much better now, exhaust pipes not blue either :)
New front pads bedded in and deffo not as good as OE so they will get swapped out very soon. ABS light still works.............bit breezy this AM.
#2550 madmopedracer
madmopedracer
  • 473 posts
Posted 30 April 2017 - 07:18 pm
fitted low pressure facit electric pump ran well then fitted some handguards refitted all the plastic damn thing wont start now no spark
clutch switch?
#2551 Studley Ramrod
Posted 30 April 2017 - 07:45 pm
Killswitch ?
#2552 Talltom87
Talltom87
  • 381 posts
Posted 01 May 2017 - 12:01 am
Might be the plug for the starter, burns out quite often. down the right hand side of the tank under the seat. I just connected mine together at each end, will sort it out correctly in the winter.
#2553 madmopedracer
madmopedracer
  • 473 posts
Posted 01 May 2017 - 11:42 am
starter works took power from kill switch for electric fuel pump its working
turns over fine just no spark not much time to work on it at the moment due to other comitments
#2554 Bjørge
Posted 01 May 2017 - 08:24 pm
Got it back on the road, with new paint on plastics, tank, wheels. Refurbished front calipers, all wheel bearings new. Most important: New gear lever rubber  :pimp:. New PR3s
Very happy with colour, looks black when no sun and explodes in shiny purple sparks :yeyeye: when lit.
Old looks (well, it looked this way 3 years ago):
Mk1 before (3 years ago, actually)
New bling paint (transparent black with purple flake):
New paint (2)
New paint and logo (4)
New paint
Edited by Bjørge, 01 May 2017 - 08:25 pm.
#2555 fixitsan
  • 4,855 posts
Posted 01 May 2017 - 09:04 pm
Noice....
#2556 redrex
redrex
  • 84 posts
Posted 02 May 2017 - 08:15 pm
Ooooh that's nice. Very 1970's. You should get the seat covered in something furry.
#2557 MalS7
MalS7
  • 36 posts
Posted 03 May 2017 - 05:52 am
Today I got the big banana through NSW registration.
Cost me an eye-watering $700 + and will soon need tyres and chain and sprockets but I am still smiling cause I'm off on an autumn ride this weekend.
#2558 Bjørge
Posted 03 May 2017 - 05:55 pm
70's Come back all the time.....
#2559 fixitsan
  • 4,855 posts
Posted 04 May 2017 - 07:20 am
got home early from work yesterday, sun was shining, wife was going to organise dinner, so went for a meandering blast on the mk2. I was thinking how it will be nice to try the 900 on Saturday when it goes for the MOT. I always preferred the way the mk2 steered over the way the 900 steers, but the 900 now has a 17" front wheel and new PR3's ....and as I was riding the mk2 I realised that with the EMC rear shock and rebuilt front forks the 9er will have to be much better than it was.
Either way i still don't know which I'm going to sell and it would be nice to keep both but that's not practical
Edited by fixitsan, 04 May 2017 - 07:21 am.
#2560 Andy25
Andy25
  • 344 posts
Posted 05 May 2017 - 06:56 pm
Fitted a set of engine bars
Purchased from Rafal @ RM-G
