#2601 fixitsan
  • 4,855 posts
Posted 28 May 2017 - 09:58 am
I will double check the rubbers and clamps. With vacuum pipes, do you mean the ones from the inlets? The funny thing obout those is that if you connec these to the morgan carbtune, the bike will stop after a short while. then you have to put one of the pipes back on the vacuum pump. start it up and then reconnect the carbtune again.  :unsure2: Is it suppose to be like this?
'a short while'...how long ? If you disconnect the pipe from the pump then there's no fuel going to the carbs and you are just emptying the float bowls.  Having said that it doesn't sound short of fuel when you rev it........but, you have also moved the tank, do you know if the tank filters (internal on the pipe connection) are intact, perhaps moving the tank has disturbed dirt which is now in one of the jets ?
#2602 Victor
Victor
  • 30 posts
Posted 28 May 2017 - 10:42 am
short while = 1-2 minutes. When i filmed the video the vacuum pump was installed thats why only one instrument is active on the carbtune. Hmm maybe dirt but it puffs through both carburettors, so it feels like little bit unlikely?! What about the air/fuel mixture screws?
Maybe i should start a new thread...
#2603 fixitsan
  • 4,855 posts
Posted 28 May 2017 - 01:08 pm
My understanding is that without the vacuum line the pump isn't working. Then again i think i have read that fuel bypasses the pump anyway, even when it isn't running (but then why have a pump in the first place ?
When I had the mk1 I disturbed debris in the tank and the filters weren't present...the pump diaphragm and pump valve got contaminated which gave similar results
I would connect the vac pipes to the gauges and feed the carbs directly from the tank. but first i would check that the filters are fitted in the tank or else everything else will be a waste of time until you strip and clean the carbs.
Edited by fixitsan, 28 May 2017 - 01:15 pm.
#2604 g650xtdm
g650xtdm
  • 295 posts
Posted 28 May 2017 - 11:48 pm
I believe gas will get to the carbs so long as you have gravity on your side.  When the tank is in place, even if your pump has gone bad, it will work until the fuel level drops low enough it can't make it to the carbs on their own.  So if you are balancing your carbs, if you still have the tank connected, it may not be high enough to get fuel to the carbs without assistance from the pump.  The only way I can really manage it on mine is with a separate fuel supply suspended above the carbs.
Someday, I plan to install T-fittings to remote the vacuum lines to be able to balance the carbs a little easier.  But "someday" never seems to come . . .
#2605 Talltom87
Talltom87
  • 381 posts
Posted 29 May 2017 - 09:16 pm
Jet washed the whole thing, oiled chain and went for a spin to dry it off. Got a bit of water in right spark hole. Had to dry it out. Noticed oil dropping down the side stand, hoping it is just excess oil from chain.
#2606 MalS7
MalS7
  • 36 posts
Posted 29 May 2017 - 09:25 pm
Fitted new chain and sprockets. Ahhh that makes a wonderful difference to driveability
#2607 Bjørge
Posted 30 May 2017 - 06:19 am
[...]Noticed oil dropping down the side stand, hoping it is just excess oil from chain.
Well, hope it's not thye dreaded side stand oil leak ....... :hide:
#2608 fixitsan
  • 4,855 posts
Posted 30 May 2017 - 03:38 pm
quite a bit judging by their website,  If I had a 9er I tink i'd go down that route.
Posted my spare ECU to Samios....should be a week or two before I get to try it out :) Stay tuned !.
#2609 GrandPaul
GrandPaul
  • 97 posts
Posted 30 May 2017 - 07:14 pm
All I did with my TDM today was glance at it as I walked around the client's bike I'm working on.
Sad state of affairs...
GrandPaul
Author "Old Bikes"
Does not use emoticons
#2610 Bigmatt
Bigmatt
  • 48 posts
Posted 30 May 2017 - 11:10 pm
Didn't do anything but ride ! Just returned from an 8 day, 3000 mile camping trip. Left San Antonio, TX and went through New Mexico, Arizona and into Utah. Had a short visit with family and then headed back. Last day was from Gallup, New Mexico to San Antonio, TX and was about 850 miles. Bike ran very well except when above 6500 ft and then it was low on power below 3000 rpms. Gas mileage averaged about 46 MPG with a low of 41 and a high of 51. It was windy most of the time and I ran between 70 and 75 MPH. Used a little over a quart of oil. This bike still brings a smile to my face ever time I ride it !
#2611 GrandPaul
GrandPaul
  • 97 posts
Posted 30 May 2017 - 11:58 pm
Now THAT is a ride.
GrandPaul
Author "Old Bikes"
#2612 drewpy
  • 1,790 posts
Posted 31 May 2017 - 08:07 am
got my oilite bushes with oil seals for lower shock and fitted them...nice
awaiting scottoiler next so I can fit that when the bike is partially stripped at the back
#2613 dhatfiel
dhatfiel
  • 63 posts
Posted 01 June 2017 - 07:27 pm
New Mich PR4s and rebuilt rear caliper. Prepping for my trip next week to the head of Columbia River (from Portland Oregon) in Canadian Rockies. The Banff and Jasper Nat. Park country. This on my Vivid Cocktail Red 1992er.
Looks just like yers, Bigmatt. Except not stock exhaust. Two in to one single Delcovic muffler.
Edited by dhatfiel, 01 June 2017 - 07:30 pm.
#2614 fixitsan
  • 4,855 posts
Posted 01 June 2017 - 10:43 pm
Had a test ride on a Ducati Scrambler...it's nice and light. Surprised how well those tyres grip, really good fun chucking it around but no fun at high speed, I have a large frontal area......   Then got back on the 9er to ride home and think I like it more than the scrambler :)
#2615 Got1now
Got1now
  • 240 posts
Posted 03 June 2017 - 09:18 pm
Took the bike out for a decent run in the Peak district, then noticed a few drops of oil under the bike when it was parked up at lunchtime......ooops!
Came back home, and traced the problem to the output shaft (oil seal), so cleaned it all up, ready to ring Fowlers Monday to order replacement seal......
Still......an enjoyable day......and a chance to spend a few more pennies on the bike :)
#2616 fixitsan
  • 4,855 posts
Posted 03 June 2017 - 10:01 pm
What was your bikes recent oil consumption like out of interest ?
#2617 Got1now
Got1now
  • 240 posts
Posted 04 June 2017 - 08:22 am
No idea fixitstan, I bought the bike last year as a non-runner, and this was the first decent run out on it! So it will be interesting to see what it does once this is fixed.....
#2618 fixitsan
  • 4,855 posts
Posted 05 June 2017 - 11:22 pm
I'm pretty sure that mine improved after changing the seal, which i decided to do after noticing the fresh oil behind the front sprocket, despite neglecting to lube the chain for a while !
#2619 Got1now
Got1now
  • 240 posts
Posted 06 June 2017 - 07:42 am
Double bonus!!!!
#2620 fixitsan
  • 4,855 posts
Posted 06 June 2017 - 08:46 am
Double bonus!!!!
It doesn't mention the automatic chain oiler in the manual, but some bikes seem to have it !
