850 Destruction
892 replies to this topic
#261 dablik
Posted 02 August 2019 - 08:34 pm
Things have taken a back seat for awhile as it's taking over me life :)
Had a measure up of the oil pump gubbins, inner rotor in spec and the outer rotor just over spec by 0.01 but well within service limit.
Attached File  20190727_113337.jpg   179.73KB   0 downloads
Cleared out some space from the bedroom
Attached File  20190802_203751.jpg   141.45KB   0 downloads
Oh and i dont think i'll ever have a full bike powder coated again, what a ball ache, clearing up overspray the fookin clown left on everything is so time consuming, mind expect i should'nt grumble for the price, was prolly 1/2 wot i would pay at a proper bike only coaters, but i will :D
Edited by dablik, 02 August 2019 - 08:38 pm.
#262 dapleb
  • 18,394 posts
Posted 02 August 2019 - 08:39 pm
Sminky dabs.
#263 dablik
Posted 02 August 2019 - 08:40 pm
Yup looks noice and clean daps, old forks on to hold her up for now, off this week so hope the weather changes..
#264 dablik
Posted 03 August 2019 - 05:27 pm
Thought i would dress her up today and get an idea wot she's gonna look like.
Attached File  20190803_174232.jpg   159.06KB   0 downloads
#265 dapleb
  • 18,394 posts
Posted 03 August 2019 - 05:47 pm
Almost done;0)
#266 dablik
Posted 03 August 2019 - 06:53 pm
#267 gautrek
gautrek
  • 71 posts
Posted 04 August 2019 - 06:30 am
I like those risers
#268 wicklamulla
Posted 04 August 2019 - 02:21 pm
that 1994/95 bodywork?
#269 dablik
Posted 04 August 2019 - 03:50 pm
Yep Ken, been touched up over time, bought it to replace the crap bodywork on mine, which i hope to sort in the future, will have to find a matching mud guard though  or worse case get some paint and do it meself, current one is silver, you hiding one away per-chance :)
#270 wicklamulla
Posted 04 August 2019 - 07:30 pm
yes.
#271 dablik
Posted 04 August 2019 - 08:52 pm
yes.
Ooh :) do tell..
#272 wicklamulla
Posted 04 August 2019 - 10:58 pm
Ooh :) do tell..
oil climb up into the loft and have a look see.  I do have some spare front mudguards but i tink i may not have the colour yer after.
#273 dablik
Posted 05 August 2019 - 08:21 am
Cheers Ken :good:
#274 dablik
Posted 05 August 2019 - 07:44 pm
Cleaned another set of valves today, them from # 1 cylinder head wot's kaboshed, quite a few of them are pitted around the borrum of the stems, still they were working okay.
Decided to retap all the bolt holes today on the borrum crankcase after it was vapourised, got a small amount of debri out, glass media wot they used
Attached File  20190805_161139.jpg   133.76KB   0 downloads
Then i found this little lot in the oilway to the filter :huh:
Attached File  20190805_180810_HDR.jpg   117.9KB   0 downloads
So having found that i'll be pulling the oil relief gubbins out to check that an all, mind the vapour man did mention to check the relief valve as he could'nt get in properley, thank buggery i've been brushing me oil ways out..
#275 dablik
Posted 06 August 2019 - 06:27 pm
A bit more crud and half me ball bearing lost it's finish.
Attached File  20190806_140925_HDR.jpg   118.05KB   0 downloads
Attached File  20190806_140824_HDR.jpg   67.75KB   0 downloads
A lot of the blind bolt holes had some debri also, especially inside the rotor cover, very glad i decided to re-tap every hole.
#276 dapleb
  • 18,394 posts
Posted 06 August 2019 - 06:56 pm
Swarftastic....good finds.
#277 dablik
Posted 06 August 2019 - 08:24 pm
Just been have a ganders and a dabble with the output shaft gubbins.
I would of thought that the oil holes on the shaft would line up with the bigger bush but the bush is keyed in such a way it sits one spline over/above which is how it came off.
Attached File  20190806_203420.jpg   137.73KB   0 downloads
Attached File  20190806_203635.jpg   139.86KB   0 downloads
#278 Bjørge
Posted 07 August 2019 - 06:15 am
Could keep it that way and use it for getting home from the pub. With no engine - no problem being drunk 😁
#279 dablik
Posted 07 August 2019 - 08:13 am
I'm thinking of putting pedals on it instead :)
#280 dablik
Posted 08 August 2019 - 06:53 pm
Have a lick daps
Attached File  20190808_181954_HDR.jpg   123.75KB   0 downloads
Head skimmed, vaccum tested and she's tight, dont even need a lap i was told, might just do a fine lap maybe/maybe not.
Attached File  20190808_182007_HDR.jpg   155.54KB   0 downloads
Some more cleaning up today, bathtime...
Attached File  20190808_165705.jpg   71KB   0 downloads
A bit more glass out
Attached File  20190808_165442.jpg   65.85KB   0 downloads
and of course a blow dry
Attached File  20190808_170735.jpg   120.87KB   0 downloads
Got a problem here where the Input shaft is bolted the the crankcase with those 3 T30 Torx bolts, the one circled is not taking a bolt as the threads look fubbed, was a small metal bur at the bottom from drilling out which sided the tap, poo, so i'm thinking drill through and fit a bolt to match so long as it does'nt protrude inside the case and perhaps loctite around the bearing when it's driven in, any thought's peeps, dunno if next size up to 8mm is a good idea as all would have to be done i presume..
Attached File  20190808_190732_LI.jpg   122.33KB   0 downloads
Actually when i took the head in i asked about maybe needing to replace 2 of the exhaust valves, seems they are actually in fine fettle, it would appear i got lucky with this replacement head, well early days here's hoping.
