6039 replies to this topic
#2881 Bjørge
Posted 10 November 2017 - 10:52 am
I just replaced the rubbers on mine, but those were actually cheaper.
Where did you get them ?
#2882 dablik
Posted 10 November 2017 - 12:16 pm
Mine were off Ebay, for the mk1 not the 9r.
#2883 Bjørge
Posted 10 November 2017 - 12:18 pm
Got some really cheapo crappy ones off ebay, you got a link ?
#2884 dablik
Posted 10 November 2017 - 12:29 pm
Typically gone up a few quid now, these were the ones i bought.
Edit.. fitted with Red rubber grease underneath to prevent them siezing to the footpeg.
Edited by dablik, 10 November 2017 - 12:30 pm.
#2885 Bjørge
Posted 10 November 2017 - 01:04 pm
Looking good ! Marked them for later  :-)
#2886 fixitsan
  • 4,854 posts
Posted 10 November 2017 - 10:47 pm
Found a new use for one of these mirror mounts when fitting my handgrips controller....
https://www.ebay.co....872.m2749.l2649
Attached File  20171110_221507.jpg   36.17KB   0 downloads
Attached File  20171110_222308.jpg   38.97KB   0 downloads
#2887 TDMick
Posted 11 November 2017 - 11:05 am
Found out the battery is flat. :hide:
#2888 drewpy
  • 1,790 posts
Posted 11 November 2017 - 08:57 pm
just ordered a couple of of those mounts in black, cheers
#2889 fixitsan
  • 4,854 posts
Posted 11 November 2017 - 09:12 pm
They don't come with the large (M8 , M10 ?) allen bolt. Other than that they clamp really well !
Just thinking about it you can buy ram mount balls with M8 and M10 threads.... that would make an easy installation !
Edited by fixitsan, 11 November 2017 - 09:14 pm.
#2890 drewpy
  • 1,790 posts
Posted 12 November 2017 - 09:37 am
got loads of bolts collected over the years, Ram mount idea sounds good though
#2891 Favs
Posted 13 November 2017 - 05:54 pm
1" ram https://www.banggood...ur_warehouse=CN
#2892 JBX
Posted 13 November 2017 - 09:38 pm
Another ride of the day, maybe the last one before hibernation :
#2893 Studley Ramrod
Posted 13 November 2017 - 10:19 pm
Nice vid :good:
#2894 fixitsan
  • 4,854 posts
Posted 13 November 2017 - 10:50 pm
Nice vid :good:
Yup, and a nice jacket too !
#2895 fixitsan
  • 4,854 posts
Posted 17 November 2017 - 09:02 pm
Fitted the shorter dogbaons, raising the rear 33mm
I set the spring preload to minimum and the rear wheel still sits on the ground when the centre stand is deployed.
It rides a bit like I remember the mk1 doing, I have to remember to keep a bit more gentle positive throttle going through slow turns to counteract the tendency to fall in to the turns.. The roads are wet and cold so i didn't get to experience the ride under speed.
#2896 Favs
Posted 18 November 2017 - 09:33 pm
100 miles ride about on N Yorks Moors sunny 8oC Dirty roads & dirty bike now too.
#2897 g650xtdm
g650xtdm
  • 295 posts
Posted 19 November 2017 - 12:33 am
After unsuccessfully trying to buy OEM rotors a couple months ago, I pulled them in search of somewhere that could re-surface my originals.  After being laughed out of several places, I bit the bullet and ordered some EBC rotors.  Should be here mid-week.
#2898 drewpy
  • 1,790 posts
Posted 19 November 2017 - 06:37 pm
thought you can get new disks put on the original centres
#2899 g650xtdm
g650xtdm
  • 295 posts
Posted 19 November 2017 - 07:34 pm
I didn't know that.  The Mk1 discs are riveted to the center pieces, but I assume those could be drilled out.  But I didn't see anything listed anywhere, even searching internationally.  Not much for TDMs here in the US.
#2900 drewpy
  • 1,790 posts
Posted 20 November 2017 - 12:50 pm
its a uk supplier, but I'm sure there would have been something similar in USA
