#2961
Posted 28 January 2018 - 09:36 pm
Not sure !
But the 1st one Drove a Honda Jazz
The second looked just like the first-person
And as everyone Knows the Honda Jazz is the car you buy just before your children put you in a Nursing home
Thinking back Both had same attitude ! Was my fault etc
Even though both failed to give way / look right on Roundabout
So yes you are probably Right
Just realised one of my Sister's is called Maureen works in Healthcare
Think I will just pop round and throw a couple of Half bricks through her windows
Might as well get in first etc
#2962
Posted 28 January 2018 - 10:00 pm
changed oil and filter, was gonna change fork oil for 15w but canna find it,
just checked online. I did buy some in September LOL
#2963
Posted 28 January 2018 - 10:15 pm
HeHe
Not sure !
Considering that so many people work for the NHS I suppose it comes as no surprise they have a lot of accidents.....
#2964
Posted 04 February 2018 - 05:58 pm
Refitted my Givi Wingrack and fitted the Top Saddlery seat > > https://www.flickr.c...eposted-public/
The seat is higher than the last and now i feel i'm leaning a bit forward onto the 791 Renthal bars..... The age old problem of making 2 simultaneous changes and getting a problem, not knowing which change is the cause, I might take the shortened dogbones off and restore the rear ride height (easiest thing first of course !)
#2965
Posted 06 February 2018 - 07:41 am
#2966
Posted 09 February 2018 - 12:18 am
New Avon tires, new battery, new coolant, and the ever important valve adjustment. The exhaust valves were fine but ALL of the intakes were needing adjustment.
Edited by nsr250, 09 February 2018 - 12:38 am.
#2967
Posted 09 February 2018 - 12:33 am
New Avon tires, new battery, new coolant, and the ever important valve adjustment. The intakes were fine but ALL of the exhaust valves were out of spec.
Hi nsr250!
I was surprised. When I was researching, everyone informed me that it was normal to find non-standard admissions.
Tendency to reduce standard measures. And the exhaust within the standard. Bingo .. this happened to me.
In your case I see that it was the other way around?
Cheers!
Att
Sidarta
TDM850 ano 2001 Honda XLX 250 1988
Honda CB350 1972 e 1973
#2968
Posted 09 February 2018 - 12:36 am
Hi nsr250!
Cheers!
Well, it would be better if I proofread before I posted. Oops. All the exhaust valves were fine. ALL of the intakes needed adjustments. Sorry, fixed my post.
#2969
Posted 09 February 2018 - 08:44 pm
Swapped my dogbones back to standard. After fitting the Top Sellerie seat i realise that the old seat was very prolapsed in the vertical direction. Very short dogbones with a higher up seat equals a seated position which is too tilted forward for me.
So while I was at it I greased the whole shock linkage. All pins slid out cleanly, the old grease was still clear and plentiful. Keep it greasy and it comes out easy !
Edited by fixitsan, 09 February 2018 - 08:52 pm.
#2970
Posted 11 February 2018 - 06:44 pm
Hey Nsr250!
Ok!. Thanks for meeting my question. So we are confirming what our friends in Carpe
Cheers!
Att
Sidarta
#2971
Posted 17 February 2018 - 04:34 pm
84 Honda XL600R ![]()
04 TDM900 ![]()
21 KTM 790 Adventure
#2972
Posted 20 February 2018 - 07:02 pm
Wheeled the 900 out of the shed, tidied the shed, rode the bike back into the shed & now I'm ready to do some motorcycle maintenance (not going Zen)/improvements while I'm having a few weeks off (its only taken me 4 weeks to get round to tidying the shed
), - valve clearances, clutch & springs, throttle bodies, gaiters, 15w oil for forks, oil & filter, suspension linkage service - blah blah routine stuff blah blah. Oh and test-fit new luggage addition one the rest is done
Where's my cup of coffee tea???
Posted 21 February 2018 - 02:18 pm
dropped the engine out of my spare parts 1993 3vd for
Jetwashjimblatant plug for anyone else wanting spares got a goo enterprise exhaust system on it as well
#2974
Posted 21 February 2018 - 02:59 pm
Clutch done & lots of tea consumed - additional luggage idea fail/scrapped
Posted 23 February 2018 - 10:20 am
Replaced my first LED front-end pilot-light with this one :
Glued a W5W type socket with araldite, then soldered it :
Brighter than the first one, much brighter than the W5W OEM bulb.
Neat.
With led's in series you can play GWROFF (guess which row fails first).... I have a lot of examples. The worst are Chinese products where the current limiting resistor is just small enough to keep the led's running at peak power, so they could sell a 2W led as a 3W led !
#2978
Posted 23 February 2018 - 07:50 pm
This is a Chinese product, I got 4 of them for less than 1€ so I don't mind at all any premature death !
It's a perfectly acceptable trade-off too.
I wonder if Chinese understand the reputation they are getting though ?
#2979
Repainted radiator and changed coolant, painted centre stand, fitted the heated grips relay properly (previous owner did a poor job) and general tidy up ready for another year. ![]()
Just need to figure out what tyres to fit and MOT time. ![]()
#2980
Posted 23 February 2018 - 10:44 pm
Michellin have brought out R5 the sucessor to PR4, ATM they are £215 a pair inc a £30 discount
