850 Destruction
892 replies to this topic
#281 Snowbird
  • 1,475 posts
Posted 08 August 2019 - 07:08 pm
Can you drill and helicoil, they are easy to do but best done on a pillat drill or mill to keep tap straight.
#282 dapleb
  • 18,394 posts
Posted 08 August 2019 - 07:15 pm
Don't mind if I do .. lickety lick.
Head looks good.
Bugger about that bolt. Not much metal aboot that hole?
#283 dablik
Posted 08 August 2019 - 10:28 pm
I've drilled the original bolt out cos it was loctited with red and not blue, however it's quite shallow so cant really be redrilled to helicoil (done a good few) and the smallest helicoil wont fit me thinks, as daps say's not much metal around the bolt as i 1st thought maybe one size up to M8 but reckon it's a bit dicey so, now i'm thinking of drilling straight through the side case so a bolt right through the width of the side will support where the aluminium is drilled out, just might have to take it to the engineering shop for an opinion..
#284 Catteeclan
  • 2,574 posts
Posted 09 August 2019 - 05:39 am
7mm bolts are available?
#285 Snowbird
  • 1,475 posts
Posted 09 August 2019 - 06:22 am
How about a weld up and redrill option.
Edited by Snowbird, 09 August 2019 - 06:23 am.
#286 dablik
Posted 09 August 2019 - 06:34 am
Thanks, i did notice that last night might be an option possibly.
#287 dablik
Posted 09 August 2019 - 06:40 am
I did consider that also but, would need advice from eng shop as would need to be the correct grade alloy, otherwise if it's to soft were back to square one, i was pursuing the helicoil option again last night which might be vialble, said hole actu.ally only has a thread depth of approx 5mm so if it was possible to drill to a further depth off 5ml and put in a 2D or 2.5D helicoil.
#288 Snowbird
  • 1,475 posts
Posted 09 August 2019 - 06:52 am
Is there any reason that hole can't go all the way through to give a bit more thread for a slightly longer bolt? Also check out twinserts as they can take a bigger hole back down to original (a helicoil in a helicoil), we used some at work as one of the engines we do is a b'stard for pulling out cylinder studs and then pulling out helicoils leaving a stripdown and weld up the only option but twinserts have got us out of a few sticky situations.
If we can do it to aero engines a tdm should be fine, I'll bet yamaha castings are better quality than teledyne continental, the phrase 'aircraft quality' usually means a trail of paperwork for something that's worse than you can get off ebay.
#289 madmopedracer
madmopedracer
  • 473 posts
Posted 09 August 2019 - 07:28 am
what about a good quality chemical metal and retap
its only for retention and not under pressure like a cylinder head bolt
#290 dablik
Posted 09 August 2019 - 05:00 pm
Cheers, my 1st idea was to do just that,drill right through, i imagine a bolt all the way through will hold up the integrity of the c.case as it's fulla metal, also been having a look at ideas re inserts.
Yep i have Milliput which goes off really hard so it's an option, either way if i do it myself the thread hole will have to be longer, and i think it only torques to 12nm so some locktite around the housing could help also.....need to ponder awhile..
Edited by dablik, 09 August 2019 - 05:35 pm.
#291 dablik
Posted 12 August 2019 - 03:38 pm
The thread hole in question is actually a blind hole so dont know if that should make a difference really to how it's fixed so, dropped at the shop this morning for a proper fix, ya man was off today so not sure if it will be an insert or summit else.
#292 dablik
Posted 16 August 2019 - 08:11 pm
Got some shimerooing in on the bench.
Attached File  20190816_203302.jpg   166.76KB   0 downloads
Specs are....... Inlet 0.15 - 0.20 & Exhaust 0.25 - 0.30
                     Cyl 1                                             Cyl 2
Inlet   0.18     0.19     0.19                        0.19    0.19    0.18
Ex           0.29       0.29                                   0.29    0.29
Be interesting to see how quickly they tighten up once running.
#293 dablik
Posted 07 September 2019 - 06:00 pm
Been a bit quiet while awaiting parts, been painting which is really frustrating outside, now all the parts have finally arrived i can crack on..
Got a pair of these today, lovely quality, and a rotor to replace the destroyed one offa me boyfriend ;) you know who you are  :wub:
Attached File  20190907_183551.jpg   119.22KB   0 downloads
#294 Favs
Posted 08 September 2019 - 08:08 am
:drinks:
"It'll all be over by Christmas".............  :hide:
#295 dablik
Posted 08 September 2019 - 08:42 am
#296 Favs
Posted 08 September 2019 - 12:14 pm
Pressie to yourself :good:
#297 dablik
Posted 09 September 2019 - 06:36 pm
Things are not going as planned :rolleyes: visited Aircooled Sunday morning to beg borrow and steal some tools and udder stuff and as the afternoon got sunny took advantage and got a little more painting done.
I wanna know who stole the thrust washer then !! Haynes makes a point of telling you not to lose it but i aint got one in me replacement, and remember my original rotor got binned so no reference from that.. not one in the replacement starter i have either, i wondered if Haynes had made a goofy but Fowlers fiche verified it as well, guess i better get one then....you'll have a lot of fun iffin you go lookin for oneodem daps me old fruit :D
Attached File  20190909_174159.jpg   140.73KB   0 downloads
Attached File  Starter clutch.png   46.31KB   0 downloads
Also previously dismantled the output shaft as far as possible without resorting to pulling cogs of with gear pullers and ordered a replacement circlip per Haynes method of measuring only to find the fit is a bit looser than i would like, so phoned the nice chaps up at simply bearings for a bit of circlip info and repalcement on the way, had been wondering iffin the mk1 output shaft circlip (which is actually a snap ring) would fit the mk2 shaft but the mk2 2001 is approx 3mm wider in girth around the shaft groove, whodathunk it ?
And while i think on, the rotor windings bolts are always a pita to get out and often get drilled out, i wonder if they were originally staked like the other bolts in the pic above ??
Onwards..
Edited by dablik, 09 September 2019 - 06:39 pm.
#298 wicklamulla
Posted 09 September 2019 - 08:27 pm
Do ya mean the 4TX output shaft has a larger diameter versus the 3VD one? I guess they are different part numbers.
#299 dablik
Posted 09 September 2019 - 09:59 pm
The 2001 shaft for sure, dont know about previous mk2's though, i measured the shaft groove for the external circlip and compared it to a 92 mk1, 2001 is bigger,not checked part numbers though.
#300 dapleb
  • 18,394 posts
Posted 10 September 2019 - 05:30 am
So that washer should be captive in the rotor assembly dabbers!?? Don't think I have any other rotors pulled other than that 9er Juan.
Will have a brevity though not really sure what I'm looking for aS can't remember that part.
Weird that it wouldn't be in that spare rotor if part of assembly!!
