Took the tank off, drained, cleaned and coated with POR-15. Hopefully that gets rid of my tank rust issues for good.
#3081
Posted 22 April 2018 - 09:25 pm
#3082
Posted 24 April 2018 - 09:47 am
just got it ready for MOT this afternoon added cheap handlebar guards got the orange led on them connected to indicators
also fitted some g10 led into the daylight on the fairing just poked in the legs and some glue gun work and bobs your uncle
Edited by madmopedracer, 24 April 2018 - 09:58 am.
#3083
Posted 24 April 2018 - 04:55 pm
went to start it (all checked yesterday) for mot only firing on 1 cylinder checked the spark at ht leads OK but have a duff cap
ordered cx500 ones should be here in a couple of days while i was at it fitted new set of plugs forgot what a hassle it was especially if the plug key doesn't hold the plug
manages to give the paint a good polish before rain came on
#3084
Posted 24 April 2018 - 06:50 pm
Is that a recommended mod? Haven't heard that yet.
#3085
Posted 24 April 2018 - 09:01 pm
sent my rear wheel off to the blasters, going to repaint as the front and fit a new rear disk as I fubarred that trying to get one flippin screw out.
#3086
Posted 24 April 2018 - 09:54 pm
did a search on here and it came up will let you know when they arrive
#3087
Posted 25 April 2018 - 07:57 am
I just ordered NGK plug caps for mine SD05FM-R as recommended by Apache, think he has them on both bikes.
Sorted and on the Road Mick
#3088
Posted 25 April 2018 - 04:08 pm
Does anyone have any little tricks or ideas on how I could seal these weather wise?
02C74184-133E-4F78-B215-4EEA67A515D1.jpeg 142.4KB
0 downloads
02BC392B-2D0E-47F0-A7D6-0A7FC6F8D521.jpeg 107.4KB
0 downloads
3CB65EE4-F9F8-48D0-9C35-EEB4F103AB83.jpeg 133.84KB
0 downloads
Edited by 7inarow, 25 April 2018 - 04:10 pm.
#3089
Posted 25 April 2018 - 07:23 pm
Scratched my a**e a bit over a tyre wear issue, i knew it was suspension related but couldn't remember what exactly
The symptom was a raised ridge, or burr, on the leading edge of each tread block, and after doing some googling found it was probably too much rebound damping. I checked the rebound adjuster and then i remembered that the last time I cleaned it I ran the adjuster to each end of the stop and then forgot to set it back because some other issue caught my eye.
Once I set it back to something more sensible and test rode it the rear has come more alive, it was feeling a bit wooden before.
Every day is a school day !
#3090
Posted 25 April 2018 - 09:09 pm
I took the panels off and had the lot lacered in, a permanent option but the only way I could see which would work....Put these decals on. Pleased how it came out, not perfect but pretty good for first attempt.
Does anyone have any little tricks or ideas on how I could seal these weather wise?02C74184-133E-4F78-B215-4EEA67A515D1.jpeg
Edited by Latestarter, 25 April 2018 - 09:10 pm.
#3091
Posted 26 April 2018 - 09:47 am
#3092
Posted 26 April 2018 - 07:00 pm
fitted plug caps for CX500 they are a good fit with height enough for me to try and fabricate the washer seal thingy
https://www.ebay.co....872.m2749.l2649
fixed rear brake light corrosion on the connectors
i had a problem of only firing on one cylinder i had checked the bike over when all the bodywork was off on a remote fuel tank(lawnmower) all ok
starts it up to go for mot only i cylinder long story short replaced plugs and caps no differance
then i thought i had put to in line taps so that i could remove tank easier low and behold they were too small and not enough fuel getting through
temp job drilled them a bit bigger jobs agoodun
Edited by madmopedracer, 26 April 2018 - 07:00 pm.
#3093
Posted 26 April 2018 - 07:21 pm
I think I need to do exactly the same thing. Didn’t know what caused uneven wear. Thanks fixitsan!
84 Honda XL600R ![]()
04 TDM900 ![]()
21 KTM 790 Adventure
#3094
Posted 26 April 2018 - 08:35 pm
This was one of many vids i reviewed.....
#3095
Posted 27 April 2018 - 08:34 am
Once running, everything is good. What a cracking bike!
Suspecting the fuel pump to be shot again ($10 Chinese one), will eventually install electric one lying in the shed. Fuel levels will be adjusted, and I will try the oil pressure switch on.
Happy days
#3096
Posted 27 April 2018 - 08:55 am
Would be interested to know if it was the fuel pump Bjorge, I've gok wan and I was going to fit it this year.
#3097
Posted 27 April 2018 - 10:43 am
Oops i hope not, i have one as well, thought a few had been fitted and ran okay..
#3098
Posted 27 April 2018 - 11:14 am
Think I've seen problems with float valves, flowing carbs if they're not good.
My carbs have stiffer springs (caused a need for serious adjustments on fuel levels), so I'm not worried. The leccy pamp is cheapo chinese one, though, so I'm planning to put spare unused vacuum one (also cheapo chinese origin) in tail compartment and try make everything reversible in case of an emergency.
#3099
Posted 27 April 2018 - 02:09 pm
That idea has crossed my mind as well, undecided yet though.
#3100
Posted 27 April 2018 - 04:47 pm
Been good for 18 years so far....Vaseline is your friend to slide the grommet back in place...snug fit..
