6039 replies to this topic
#3181 spike240
spike240
  • 91 posts
Posted 25 May 2018 - 08:53 pm
Being relativley new to this site - I didn't like to say owt.
But like JBX I for one would appreciate all the above. Not that bothered about cake though.
#3182 fixitsan
  • 4,853 posts
Posted 25 May 2018 - 10:15 pm
Yesterday's result are encouraging.  I will be fastening it all to a board today - siphoning when idle check.
If anyone is interested, costs so far in GBP:
PWM 1.86 Ebay/Banggood
Pump 5.99 Eurocarparts
Timer 2.44 Banggood
My time = free2me
Inline NR valve is around 1.50 Ebay
If I go for a solenoid valve, then it would be another 5 - 6 quid
More fiddling in the bikeshed today...........
UPDATE deffo siphons past pump. Solenoid valve from Banggood £3.53
Or...see if you can find a cheap 12V peristaltic pump. They inherently prevent flow in any direction when not turning. I use them at work but they're 24V types and a little large.
Sometimes also called dosing pumps.  no check valves needed.... https://www.ebay.co....5.c100005.m1851
Here's the search results on ebay...you can get a suitable pump with a variable speed controllerm so lots of folk must be playing with them.... https://www.ebay.co....g pump&_sacat=0
Edited by fixitsan, 25 May 2018 - 10:17 pm.
#3183 Favs
Posted 26 May 2018 - 09:18 am
@JBX & Spike240 If/when finished and working as intended, all will be revealed with photos, full component listing/source & wiring diagram.
Fixitsan - those dosing pumps look good and may become part of the final system - I chose the windscreen washer pump as I guesstimated it would have enough power to pull the different grades of Scottoil from my >750ml reservoir, would be reliable/endurable and I had a tiny PWM laid idle in the tricks box to control pump speed.
#3184 fixitsan
  • 4,853 posts
Posted 26 May 2018 - 10:16 am
you should be fine eh. Not sure if a washer pump could self prime with oil, they're often just a centrifugal pump with a large internal vane clearance, but because they're usually mounted at the lowest level of the wash bottle they water usually floods them straight away  But, priming it isn't difficult, just suck on the exit tube ...usual  health and safety precautions, always wear yer wellies :)
Peristaltic pumps can operate with a wide range of fluid level 'head', they self prime, they prevent flow in either direction when the power is off  (self closing) and can provide accurate small volumes if required. .... if you do decide to go down that route the best tube material is 'Tygon' which is inert to most oils, acids etc etc .... other oil resistant types are available, I think silicon will also cope with oil reasonable well
We use them on printing machines which I work on, with very nasty inks, which need to be circulated around in precise amounts. Through the first 80% of their life they often dose accurately based on the length of time they run for, but after that the tube inside flattens a bit and doesn't hold the same volume as a new one. I just replace the ink tube inside when that happens, and some of the ones I saw on ebay have replacement tubes so you should get plenty of use for years. Tygon tubes are often rated for 1000hours of use before flattening out too much. The only types of failure are motor burnouts (some thick inks are difficult to pump) and splits in the tube, which happens when the last engineer was a lazy mong.... :)
Edited by fixitsan, 26 May 2018 - 10:48 am.
#3185 Favs
Posted 26 May 2018 - 10:55 am
You're right Fixitsan, the washer pump won't self-prime, it's not problematic for me. The reservoir capacity is so large that refilling is infrequent, (one fill will easily do my summer hols miles). Refilling does not involve removing the scavenge end from the oil, so no need for a re-prime.
H&S - I like powdered latex gloves :rolleyes:
#3186 fixitsan
  • 4,853 posts
Posted 26 May 2018 - 11:05 am
Thats what i thought, once you're up and running you won't need to keep repriming.
I can't use powdered latex gloves because of the risk of the the powder contaminating the printheads, and a replacement printhead costs £9000 !  Got to be nitrile for me :)
Heres three weeks in a minute or two of an installation
I'm halfway through a 2 week training course for this puppy...it prints on wood, glass, almost anything....
Edited by fixitsan, 26 May 2018 - 11:14 am.
#3187 Favs
Posted 26 May 2018 - 11:28 am
That kit looks a bit involved! :good:
I though £20 for an new HP XL cart was a bit dear.   ;)
#3188 fixitsan
  • 4,853 posts
Posted 26 May 2018 - 11:36 am
HP call ink 'liquid gold' . one machine i work on uses virtually identical HP ink, we provide it in 10L tubs costing £400. 10L at HP prices is something like £20000 !
But if you have no other option what can you do.
#3189 fixitsan
  • 4,853 posts
Posted 26 May 2018 - 09:36 pm
Went for a blast with mates on their sports bikes. It's surprising how well the TDM goes when asked to do so :)
 > > https://www.flickr.c...eposted-public/
#3190 Favs
Posted 28 May 2018 - 03:34 pm
Ridden it wearing an open face lid - hateful. Lid back in the box & bike back in the shed.
#3191 Studley Ramrod
Posted 28 May 2018 - 04:00 pm
Think ya need a face loike Cliff's for wearing an open face lid Favs. :lol:
Just ordered a new front tyre as mine only has 1.2mm tread. :huh:   Went for an Avon Storm 3D X-M ( Extra Mileage ooooh)  £65 from M&P.  Rear has loads of tread so couldn't really justify buying a new one yet.
#3192 dablik
Posted 28 May 2018 - 04:43 pm
There's a compliment somewhere, just cant find it :P
#3193 Favs
Posted 28 May 2018 - 05:32 pm
I like Avon Storms and Cliff's face - both good in the wet............
#3194 Gdogg
Gdogg
  • 1,204 posts
Posted 28 May 2018 - 05:38 pm
What !!!!!!!!!
:cake eating:  :cake eating:  :cake eating:
:rotflmmfao:  :rotflmmfao:
Priceless Favs
Edited by Gdogg, 28 May 2018 - 05:39 pm.
#3195 dablik
Posted 29 May 2018 - 08:04 am
Glad to be of service :D
#3196 fixitsan
  • 4,853 posts
Posted 29 May 2018 - 06:16 pm
Ordered a Pilot Power 3 (rear) for when I return from the Netherlands. The Pilot Road 3 has been really great and I was going to get another to work with the front (which isn't worn much when compared to the rear)....but I just thought I'ld try something different :)
#3197 boltonwill
boltonwill
  • 71 posts
Posted 29 May 2018 - 07:00 pm
Attached File  3 generations.jpg   165.07KB   0 downloads
HAD MY PICTURE TOOK WITH 3 GENERATIONS INTO BIKES
#3198 drewpy
  • 1,790 posts
Posted 29 May 2018 - 07:09 pm
nice one Will
#3199 DavG
DavG
  • 19 posts
Posted 30 May 2018 - 02:32 pm
Both Wheels off today ready for a new set of BT023's tomorrow, Front mudguard bolts seized in as I expected them to be (glad to say there finally out ).. all brakes stripped cleaned and lubricated where needed and the swing arm cleaned while I can get to it.. :good:
#3200 drewpy
  • 1,790 posts
Posted 30 May 2018 - 03:24 pm
started her up today, then got a load of brown fuel pumping out all over the place aaghhh!
turns out the engine filled up with Bp's finest whilst the wheel was being done.
Luckily no damage done.
then the bolt to the carb top sheared off - drilled and helicoiled that
then the throttle cable seized in the carb- had to cut that off and order replacement
then the intake manifolds were breaking down - ordered a new set
just cost me £102 and 1 gall of fuel
