6039 replies to this topic
#3321 fixitsan
  • 4,852 posts
Posted 26 July 2018 - 07:33 pm
Fitted a Michelin Pilot Power to the front and took it for a spin.....feels great !
#3322 steve27bha
  • 797 posts
Posted 27 July 2018 - 01:40 pm
.... But knowing my little brain that's all probably far too simple !
I once got intrigued by a bike I saw abroad and checked out the importing rules, just for my own info. like. I got thoroughly bogged down in procedures and documentation requirements. I concluded it was not worthwhile unless either as a business or for a very special bike.
That was just from official government / DVLA etc  websites. So I suggest you get Googling and read up.
It's far from impossible - I once had an ex-France VFR750 that had been personally imported and came with a load of documentation.
#3323 Apache
Apache
  • 561 posts
Posted 27 July 2018 - 05:02 pm
GP mot'd the rider. Grateful to say passed with no advisories. I was also given lifestyle advice by a lass that'd make your rear shock bottom out..hey ho :)
Edited by Apache, 27 July 2018 - 05:03 pm.
#3324 fixitsan
  • 4,852 posts
Posted 27 July 2018 - 05:39 pm
I'll look into it when things here quieten down a bit....but then someone just listed this   ....mmmmmmmmm.... https://www.ebay.co....od/323367594770
Sounds familiar....makes you want to try fronting it out and asking her if she has advice for you because you would like to lose a few pounds. ..... just stare sincerely and wait for the reply
#3325 Andy25
Andy25
  • 344 posts
Posted 27 July 2018 - 08:30 pm
[quote name="fixitsan" post="363576" timestamp="1532713140"]
Looks good
Just depends on the final price
Good hunting
Off to trawl ebay , see if anything jumps out at me
Edited by Andy25, 27 July 2018 - 08:31 pm.
#3326 Andy25
Andy25
  • 344 posts
Posted 27 July 2018 - 08:42 pm
Sounds like it could be a minefield , especially for a first timer
I'm sure One of my previous bike's was a grey import but that had been registered for year's
I'm Dubious about buying an unregistered import coz let's face it if it was straightforward you would register it yourself and increase the price
Accordingly = easier sale ?
#3327 madmopedracer
madmopedracer
  • 473 posts
Posted 28 July 2018 - 09:48 am
to register you need the ORIGINAL registration documents for the bike they must be ORIGINAL not copies
(ask how i know hence breaking a 3vd) along with a mot certificate done on foreign reg and a cheque for the fees and road tax
also another form cant remember what it was called but it was fairly straight forward there is good info on dvla website
#3328 Bjørge
Posted 28 July 2018 - 03:41 pm
..."won't ship to Norway".....shoite, too bad.....
#3329 fixitsan
  • 4,852 posts
Posted 28 July 2018 - 07:30 pm
It won't be mine either. I just bought an MT-03 with a curious unusual engine noise (and Akrapovic cans) , as a bargain. Private reg plate MT03 YAM  ...worth £750 apparently !   Just trying to organise a courier.
Edited by fixitsan, 28 July 2018 - 08:03 pm.
#3330 Kelpie
Kelpie
  • 944 posts
Posted 28 July 2018 - 09:57 pm
Rode it, lots.
#3331 Graks
Graks
  • 22 posts
Posted 29 July 2018 - 04:44 pm
Installed Laser slipons, got them used. Is there different db killers available for these?
#3332 fixitsan
  • 4,852 posts
Posted 29 July 2018 - 06:33 pm
Probably, look on ebay for db killer, you just need to know the internal diameter of the pipe flange
#3333 fixitsan
  • 4,852 posts
Posted 29 July 2018 - 08:31 pm
Meet prototype #1 of a novel fuel efficiency indicator
https://flic.kr/p/28ewEHP
The white bit on top is a full colour LED, which displays efficiency in terms of colour.
Beginning with low fuel consumption at idle, fuel flow is low (injector pulse width small due to closed throttle, and low rpm) so the led displays Blue  (That nice efficient blue ;) ). Then as the fuel flow rate increases, the colour changes smoothly through shades of blue to cyan to green, then on to orange and red for the highest fuel flow (throttle pinned at max rpm)
It automatically sets it's own range of operation so can be moved from a single cylinder engine to a multiple cylinder one, which includes diesel multijet (several pulsed fuel squirts per induction stroke).
The connections to the bike are a switched 12V supply, ground, and the sensing wire connects to the switched side of one of the injectors.
The reason I made it is to be nosy !  Sometimes it is more efficient to run at higher rpm with smaller throttle settings than at low rpm with a wider throttle opening....so I just wanted to get a better idea of what's going on, to find where the most efficient gear change points are Maybe I've got used to watching the car fuel efficiency/ consumption gauge and miss it when I'm  on the bike....I hope I haven't got that bad !
#3334 curlylegend
curlylegend
  • 331 posts
Posted 29 July 2018 - 11:19 pm
I like that !   If the electronics are there, use them !
#3335 Bjørge
Posted 30 July 2018 - 07:32 am
Checked 9er valve clearances - spot on! I've never seen cleanter engine internals - could eat off the valve cover  :)
De-rusted coolant pipe & sprayed with Hammerite before reassembly.
Installed new battery, the old one would probably survived if I weren't too optimistic about state during winter... Bike started immediately in March, last coupla months killed it.
Washed it, polished scratches & headlight glass - looks brand new  :pimp:
Put it out for sale on web.... :sorry:
Attached File  790_1210900611.jpg   81.18KB   0 downloads
....but found an old '02 for sale that need some TLC and priced due to this....maybe take a look at it today  :P
#3336 Studley Ramrod
Posted 30 July 2018 - 09:27 am
Sidestand has a yellow 9'er for sale Bjorge, also needing a bit of tlc.
#3337 Bjørge
Posted 30 July 2018 - 11:45 am
Are you kidding me ?  :pimp: That would be a good idea....
#3338 Studley Ramrod
Posted 30 July 2018 - 01:06 pm
Not kidding Bjorge, it's a low mileage yellow wan with yellow bellypan and other yellow bits.  It's got Ohlins suspension too. :)  Mick owned it years ago and then sold it on.  Then he bought it back from the person he sold it to, unfortunately the person didn't look after it as much as Mick had and it got a bit tatty, mainly the front of the engine where the weather has got to it.  Give him a ring if you're interested. :good:
#3339 fixitsan
  • 4,852 posts
Posted 05 August 2018 - 10:57 pm
had a good 150 miles down into the Scottish Borders .... I don't believe I would benefit from having another bike !
#3340 Andy25
Andy25
  • 344 posts
Posted 06 August 2018 - 07:20 pm
Just read this after getting back from 340 mile jaunt to Kielder for coffee and Cake today
Either Great minds etc or it was supposed to P*** down on the west coast so headed south instead
