850 Destruction
892 replies to this topic
#321 dablik
Posted 13 September 2019 - 07:36 pm
Nice one! What were you doing wrong?
Excuse me :D nothing but if anyone ever gets stuck at the same place i'm sure i can help em out ;)
Veritas mantler par excellance :clapping:
Merci boo coop monsewer :wub:
#322 dablik
Posted 13 September 2019 - 07:50 pm
Well i think i've earned the name Captain slow by now, ho hum perfection was never made in a day, bit behind schedule but that's okay.
Working snuggly, opted for the mark one stopper wheel and spring, can always change down the road if needed.
Attached File  20190913_134725.jpg   136.12KB   0 downloads
Attached File  20190913_174748.jpg   137.66KB   0 downloads
All snugged up
Attached File  20190913_174551.jpg   144.47KB   0 downloads
oopsala :D
Attached File  20190913_190912.jpg   119KB   0 downloads
Who forgot to order balance shaft o'rings then, them's seriously goobered, pretty sure i can just pull the shafts out later actually so i'll crack on, it's really quite slow going when ya having to check and re-check ad finitum, still enjoying though :good:
#323 dablik
Posted 15 September 2019 - 05:17 pm
Some more progress
Attached File  20190914_152436.jpg   124.56KB   0 downloads
Attached File  20190914_150751.jpg   116.48KB   0 downloads
Attached File  20190915_142814.jpg   160.65KB   0 downloads
Attached File  20190915_145926.jpg   168.66KB   0 downloads
Attached File  20190915_172301.jpg   158.56KB   0 downloads
#324 dapleb
  • 18,394 posts
Posted 15 September 2019 - 05:35 pm
Great progress dabbers. Lookin good. Alot of work in that.
#325 dablik
Posted 15 September 2019 - 06:11 pm
Yep indeed, plodding along, would liked to have put the pistons on along with the head but i'm gonna have to flip the engine over again to torque the balance shafts and put new seals as forgot them in the initial order..
Can somebody with a bit more knowledge give an opinion on this thrust washer for the starter clutch on the back of the rotor (flywheel) below is a picture of it in-situ inside the sprag clutch which then has the large starter gear inserted on top, it's the black ring in the middle which is quite thin. i thought perhaps the thrust washer would be as wide as the face it sit's on ?
Attached File  20190914_153947.jpg   187.1KB   0 downloads
Attached File  20190914_154023.jpg   125.98KB   0 downloads
That part above is listed for 92 850 and when you click on the part on Fowlers it the shows a fiche for the FJ1200 transmission which it also fits plus a whole bunch of Yam utility vehicles which is normal, the 2001 thrust washer (below)  looks a bit more substantial ie, wider and thicker looking at it in a photo.. wonder if its more suitable !!
Attached File  2001 Thrust washer.jpg   8.25KB   0 downloads
#326 dablik
Posted 18 September 2019 - 05:37 pm
Okay so your all as fookin useless as me then :P
Prolly not to clear where i was going with that prev post, basically was wondering if Haynes had made "one" of their mistakes re thrust washer as the placement seemed a bit odd to me, the 4tx service manual explains this somewhat more clearly along with order of refit as opposed to a bad photo in Haynes.. ordered the other thrust washer as well to see which i prefer to fit.....
carry on, carry on....
#327 Favs
Posted 18 September 2019 - 07:03 pm
Coming along nicely  :good:
#328 dapleb
  • 18,394 posts
Posted 18 September 2019 - 07:07 pm
Sorry dabbers can't remember washer at all.
#329 dablik
Posted 18 September 2019 - 08:10 pm
No worries daps, washer must of fallen off at some point and it's all learning, interestingly the 4tx manual also makes mention of which way to check the sprag clutch as it's a one way assembly, imagine bolting that all up and having to remove the blinkin rotor to change if assembled wrong :huh:
Other bits arrived now so will crack on getting the engine finished up..
#330 wicklamulla
Posted 19 September 2019 - 01:19 pm
i guess yule have been cross referencing the 3LD, 3VD, 4TX and maybe even the 5PS manuals  to help figure it all out?
#331 Studley Ramrod
Posted 19 September 2019 - 02:55 pm
If the washer was as wide as the face it sits on, it's prolly going to stop the woodruff key from sliding into the groove.
#332 dablik
Posted 19 September 2019 - 04:36 pm
Aye Ken, the 4nx and 5ps both share that same thrust washer which i think will slot in just nicely and i assume it was an upgrade from previous..
Studs the woodruff key slides in on the inner diameter, i meant the face it sits on as in from the inner diameter where it sits on the shaft to where it would meet the springs in the sprag clutch.. the 3vd washer looks to be a bit weak compared to the other 4nx washer, but one of em will need to go in..
#333 dablik
Posted 20 September 2019 - 06:11 pm
Ferfooksache :rant: :rant: :rant:
Attached File  20190919_145940.jpg   136.58KB   4 downloads
Man it's grating on me bloody nerves a bit now..
#334 dapleb
  • 18,394 posts
Posted 20 September 2019 - 06:30 pm
Oops!!!
Devonia this weekend but can have a dig next week if time allows dabbers? Else get yersen down here and help yersen.
#335 dablik
Posted 20 September 2019 - 08:18 pm
Have a dig please daps, meanwhile i'll get looking around, if i had a spare bike would be nippin down for sure, oh Aircooled :D
#336 wicklamulla
Posted 20 September 2019 - 09:36 pm
Cliff he'll not let you take that 'Glitterball TDM' to Devon!  :rotflmmfao:
Is it possible to TIG weld that broken bit on the basket or would it throw it off balance?
#337 Favs
Posted 21 September 2019 - 04:19 am
Can't ya break summit cheap?
I'd have the toys out of the pram.
I hope a replacement isn't too painful.
Chin up and stiff upper etc.
Tea an cake required soldier
#338 dablik
Posted 21 September 2019 - 07:31 am
At least the "Glitterball" would get a decent run eh  :) I'll ask him he's nippin round later.
To fragile to weld Ken, doubt it could be trusted either.
Aye Al i was so angry, they heard me in France, made a diy holding tool and the bugger slipped, end up costing more in the long run than just buying the proper tool.. am well annoyed, it's taking over me life again now... oh well gotta crack on.
#339 Snowbird
  • 1,475 posts
Posted 21 September 2019 - 07:41 am
Be greatful it's a bike not a boat, I got quoted £850 for an oil cooler when one of mine was leaking, luckily I managed a reasonable repair for a fiver but it was touch and go ( it was touch'n'cloth as well), a dead tacho was going to be £300 and the new one wouldn't match the other one so I'd have to buy a pair (fitted Wema's at £70 each), new fuel tanks were £1500 plus the hassle of lifting two engines out to get to them (at 1/2 ton each) over water.
Bikes are easy! Keep away from Volvo Penta.
#340 madmopedracer
madmopedracer
  • 473 posts
Posted 21 September 2019 - 08:01 am
as the old saying goes if it has wheels floats or fuc$! rent rather than buy
