6039 replies to this topic
#3541 TKH
  • 2,201 posts
Posted 24 April 2019 - 07:10 pm
Changed the oil, bled the front brakes, knackered the rear calliper trying to bleed the rears. :blush2:
#3542 Matlock
Posted 27 April 2019 - 02:26 pm
New rear disc (EBC) & pads (OEM) prior to this afternoon's MoT; which was passed (as usual). One advisory on the rear tyre being worn close to limits. No mention was made of the slightly noisy front wheel bearing, although there's no detectable play. The old girl is up to 99,257 miles now  :clapping: Should tip over the 100k mark in the next month.
#3543 wicklamulla
Posted 28 April 2019 - 12:21 pm
yesserday i drained the fuel tank which contained a lot of fine and coarse rust particles as i had neglected to either properly 'winterise' the bike by either completely emptying the tank or brimming it full of fresh fuel so rust took hold,  the in tank fuel filter that is part of the pet cock has failed so the rust got as far as the main remote fuel filter.  I cut it open ferra look and it was a bit gunged up so a new one is on order. Carbs need to be cleaned as she'll only idle on full choke so they must be gunged up.
The original red fuel tank will be filled with vinegar ferra day or 2 and i will try to remove all the rust in a bid to 'save it'. In the mean time i have a silver tank in my spares stash to go on to No.7 which is mint internally and is complete with petcock and fuel level float etc so all i need to do is swap over the filler cap so it matches the ignition key.
A bespoke built Nitron rear shcok is goin on shortly to replace the troublesome Fournales shock i've had on there in recent years.
#3544 madmopedracer
madmopedracer
  • 473 posts
Posted 28 April 2019 - 01:03 pm
when briming up for the winter use premium fuel as it will not attract water the same as unleaded
#3545 TKH
  • 2,201 posts
Posted 28 April 2019 - 06:57 pm
Fitted replacement rear calliper today and bled it. I feel a ride out coming on tomorrow to make sure all works ok.
#3546 drewpy
  • 1,790 posts
Posted 29 April 2019 - 11:11 am
the fuel people also change the composition in summer and winter due to the temp changes
#3547 TKH
  • 2,201 posts
Posted 29 April 2019 - 11:48 am
Just to clarify, Despite the ‘Premium’ label, Premium Unleaded (95 RON) is actually the most commonly-used petrol across the UK and Europe, and is suitable for almost all petrol engines.The other is super unleaded with higher octane rating of 97/98/99 (RON).
The majority of unleaded 95 Octane petrol sold in the UK contains up to 5% ethanol  as required under the Government's Renewable Transport Fuels Obligation (RTFO). There is currently no requirement for renewable fuel (such as ethanol ) to be present in super unleaded (97 grade petrol) - source esso.
The ethanol in premium, as madmopedracer says, can absorb water.
#3548 MipeTDM
MipeTDM
  • 92 posts
Posted 01 May 2019 - 12:16 pm
You can also de-rust it with a dc power supply and baking soda water solution, see my picture here:
https://tdm-trx-trac...t&comment=50910
I've performed that several times on different tanks, and the result is surprisingly good.
#3549 Favs
Posted 01 May 2019 - 12:38 pm
Can't see the image - sign-in reqd :(
#3550 MipeTDM
MipeTDM
  • 92 posts
Posted 01 May 2019 - 03:48 pm
No problem, here's the photo:
It's called electrolytic rust removal
Edited by MipeTDM, 01 May 2019 - 03:50 pm.
#3551 MipeTDM
MipeTDM
  • 92 posts
Posted 01 May 2019 - 05:04 pm
Here's some more picture below on the 1st tank I did:
https://www.motor-fo...9/post-26466854
#3552 Timbo1866
Timbo1866
  • 224 posts
Posted 03 May 2019 - 04:44 pm
Woohoo MOT passed with 1 minor rear tyre low had a laugh with The tester he always puts something down said it will last a wile yet so
Scotland he I come (well in 5 weeks)
#3553 Studley Ramrod
Posted 03 May 2019 - 05:53 pm
Family outing Tim ?  Be nice to know how yer trip goes. :good:  Where in Scotland ya heading to ?
#3554 Timbo1866
Timbo1866
  • 224 posts
Posted 03 May 2019 - 09:00 pm
Hi Studers
Just me and the eldest Jools on this trip
but meeting up with a few lads from the GS 500 forum weve been meeting up for a few years there are a couple of locals one who acts as our tour guide
Were of to Tyndrum in the highlands between Glencoe and Loch Lomond
Will try to get some decent photos
#3555 Studley Ramrod
Posted 04 May 2019 - 08:42 am
:good:
#3556 Graks
Graks
  • 22 posts
Posted 04 May 2019 - 03:44 pm
Cleaned up front sprocket housing and polished the silencers.
#3557 Favs
Posted 13 May 2019 - 04:49 pm
Ridden it up Teesdale & back down Weardale this morning.
#3558 wicklamulla
Posted 13 May 2019 - 05:27 pm
No.7 was running badly and would only idle on full choke and would stall if the throttle was touched so i removed the carbs. and puttem on the bench,  read the instructions on the can of carb. cleaner which states 'remove the air filter and start the boike,  apply part throttle and spray the carb. cleaner into the intake till the enjun starts to falter,  allow it to work fir a few minutes and repeat as necessary'.
Guess i shudda tride dat first!  Well the carbs are off not so i may as well try to remove the top covers and the float bowls and have a look see. The bolts are very toight though so i'm trying to tap em' gentle loike inna bid to break the grip the threads have on the bolts.
#3559 PICARD
  • 1,786 posts
Posted 13 May 2019 - 06:29 pm
JIS screwy fella and a bit o heat'll do it.....learned that after yeeeears of strippin'em and effin' an' bloindin'.
#3560 TDM900OZ
TDM900OZ
  • 72 posts
Posted 14 May 2019 - 04:29 am
Washed all the weekend crap off it, gravel dust, cow shit and mud, an a good half that is from my " driveway" :rolleyes: :rolleyes:
