6039 replies to this topic
#3561 Studley Ramrod
Posted 14 May 2019 - 08:43 am
Tighten slightly, then loosen.  Worked for me when I was doing Lewis's carbs.
#3562 wicklamulla
Posted 14 May 2019 - 09:52 am
Hi Ian,  yes i did that and it worked on one carb.  I am carefully inducing some heat to each bolt head using a gas powered soldering iron which has helped too but i am struggling with the other carb. but will try again this morning.  *safety goggles worn and a foire extinguisher at the ready!     I do wonder if i simply refit the carbs without completely disassembling them and use the carb. cleaner as directed on the instructions would i 'luck out' and they'd start working as normal after a bit?!  Maybe maybe not is the answer. I have a spare set of 1999 MK2a carbs side be side and there are some slight differences in the castings (minute differences though)
I cleaned the needle as that was a bit gummed up and i inspected it using a magnifying glass and there appears to be extremely little or no wear atall atall.  The diaphram i removed looks mint too.
Edited by wicklamulla, 14 May 2019 - 09:54 am.
#3563 Favs
Posted 14 May 2019 - 12:57 pm
Ah've been to Rosedale :cool:
#3564 Studley Ramrod
Posted 14 May 2019 - 02:48 pm
Hi Ken, if you can get the float bowl screws out you'll have access to most of the carb internals. Try not to use anything to hit the screws as the carb casting can break real easy. If not then try refitting and using the carb cleaner perhaps ?  mk2 and mk2a carbs use a different airbox as the mk2a's inlets are wider.
Dusted off and washed my bike today. :)
#3565 dablik
Posted 14 May 2019 - 04:53 pm
Wickers ya mate Aircooled had great success using Seafoam on his stuck carbs, he put the whole bottle through the tank and left it to soak a few days.
#3566 wicklamulla
Posted 15 May 2019 - 01:16 am
Ok I've been messing about with carbs and coils / HT leads today. I had previously fitted Magnecor HT leads and new coils. I used a combination of self amalgamating tape and also shrouded the new leads with heat shrink as a belt and braces approach. Ironically the heat shrink gave up and cracked after several years so I removed it and used Plasti dip instead as it's longer lasting. It's hard to see but the heat shrink has crumbled away where the lead disappears behind that rusty bracket.
Edited by wicklamulla, 15 May 2019 - 01:20 am.
#3567 poppykle
poppykle
  • 89 posts
Posted 16 May 2019 - 04:25 am
Added mirror extenders to the TDM in an attempt to reduce buffeting.  Bought the extenders off ebay, reasonable price and simple to install.
I'll give them a test later in the week.
#3568 wicklamulla
Posted 16 May 2019 - 08:28 am
Ok I dipped the coils and leads twice more so thas 3 coatings of liquid rubber. These are the S&M rubber clad specials which would be at home on a 900.
#3569 Studley Ramrod
Posted 16 May 2019 - 08:37 am
Ooooh, rubbery job there Wicky. :)
#3570 Favs
Posted 16 May 2019 - 08:48 am
MOT FAIL yesterday and immediate PASS.
FAIL = Front tyre valve split (funny cos it was OK when I inspected them both last week at tyre inflation - maybe it was the tester bending it through 90 degrees wot showed the split up ahem ahem (not done to the Scottoil infested rear valve??? )). Anyway, valve is split = no ride away = no argue room available - supplied & fitted new valve for £5 and PASS acquired. BTW valve was just over 2 years old and fitted by...........the test station.
#3571 Studley Ramrod
Posted 16 May 2019 - 03:15 pm
:lol:  Not sure he'd make a fortune breaking and repairing air valves, sounds more like a clumsy, hamfisted tester.
Fired her up today, second time in 6 months and only took a minute to start. :)
#3572 Favs
Posted 16 May 2019 - 05:32 pm
Get your right leg over ...........
#3573 wicklamulla
Posted 18 May 2019 - 02:01 pm
removed all the fuses out of the fuse box,  disconnected all the block connectors  the reside beneath the airbox,  cleaned them all out using brake cleaner and blew them dry with the air lion, applied dielectric grease to each and and reassembled.  This helps prevent corrosion.
#3574 Gump850
Gump850
  • 9 posts
  • TDM model: 1995
Posted 19 May 2019 - 04:30 pm
Fitted a scottoiler, wired up my garmin zumo, fitted a chinese top box, and a tank lock ring for my tank bag. Off to Scotland for a few days tomorrow.
#3575 PICARD
  • 1,786 posts
Posted 19 May 2019 - 06:31 pm
That's a foin looking bike! Good luck in Scotland
EDIT....boike,sorry typo.
Edited by PICARD, 20 May 2019 - 04:59 am.
#3576 dablik
Posted 19 May 2019 - 06:44 pm
:wifgeni:
#3577 wicklamulla
Posted 20 May 2019 - 01:23 am
:wifgeni:
hawny looking 3VD roight there
#3578 Gump850
Gump850
  • 9 posts
  • TDM model: 1995
Posted 20 May 2019 - 07:41 am
Cheers fellas, I will post pics when I get back.
#3579 wicklamulla
Posted 21 May 2019 - 01:05 am
converted the Kappa Wing rack back to Mono Key as it was Mono Lock for years,  this i have done so i can use my new Givi E21 panniers rather than the bigger and unnecessary very old larger Mono Lock panniers that must be 38 liters each.
MonoKey mounts in position with the older Mono Lock one next to it for reference.
#3580 Bjørge
Posted 21 May 2019 - 05:51 am
Wow! 2 pairs of panniers ! Never saw that before... :good:
