6039 replies to this topic
#3641 gautrek
gautrek
  • 71 posts
Posted 26 July 2019 - 09:03 pm
The Panther is a blast to ride. 55/60 flat out and cruises at about 50mph. The front brake doesn't and the back will lock the wheel. I can do 100 mile in a  day on that bike and only have a slightly sore arse. But the rough roads do hurt you back if you are not aware. After riding that I do have to be carefull with the brakes on any modern bike. I usually use way too much force the first few times I use the  twin disc set up.
I did try my light tonight when it got dark. With me sat on it it did seems a bit too high so i have adjusted the light down a bit. I tried looking from across the road at about car height and it doesn't seem to dazzle. I need to give it a try on an actual ride though
#3642 Denzel25
Denzel25
  • 12 posts
Posted 29 July 2019 - 06:40 am
That's a nice Panther!
#3643 Favs
Posted 31 July 2019 - 12:31 pm
V hot in shed.............
Seat off, front side panels & chicken fillets off, coolant out, radiator off, tank drained & off, airbox off, engine bar off (L),  thermostat & associated pipework off, cam cover off, plugs out and T-shirt wrung out.
That's all for today folks........
#3644 wicklamulla
Posted 31 July 2019 - 12:39 pm
ya doin the valve clearances?
#3645 Favs
Posted 31 July 2019 - 01:08 pm
Hi Wicklamulla
I heard (i think I did), a whirr on the overun while riding throiugh Germany. It was quite a hot day and I was making some spirited progress . Just checking my hearing as much as the bike, (if it had been a high pitched whine then I'd know it was my lugs)..
Valve clearances will be checked as routine (even though they were done around 6000 miles ago), as will camchain, oilways etc.
I'll take the XS play out of throttle cables too. General inspection n cleaning - aux wiring tidying ..........
It helps keep me out of the pub.....until tomorrow.
#3646 fixitsan
  • 4,852 posts
Posted 02 August 2019 - 12:33 pm
Rebuilt the back end of Muddy's old 900. Swingarm out, pedal hangers off, all bearings and bushings checked, cleaned and repacked with grease, new disk and pads. Moving on to the front soon :)
48438279411_378a41c291_b.jpgIMG_20190802_131121 by Chris Barron, on Flickr
#3647 Catteeclan
  • 2,574 posts
Posted 06 August 2019 - 05:28 am
Careful, Muddy's gonna want it back when you're done. :lol:
#3648 MipeTDM
MipeTDM
  • 92 posts
Posted 06 August 2019 - 08:10 pm
Received a pressure sensor to construct a DIY fuel gauge:
#3649 Favs
Posted 07 August 2019 - 01:58 pm
Post #3643 update
Assembled after investigating the phantom whirr - nowt amiss - so it's all in MY head :huh:
Oil & filter change then back in the shed as it's an Altea clutch replacement tonight.
#3650 drewpy
  • 1,790 posts
Posted 07 August 2019 - 09:02 pm
How would that measure fuel? No pressure, no fuel?
#3651 MipeTDM
MipeTDM
  • 92 posts
Posted 08 August 2019 - 07:59 am
The sensor can measure the static pressure of the fuel column above it. As the tank gets emptier, the pressure becomes lower.
Of course I would like to know the fuel is ALMOST gone, and not when the tank is empty...
#3652 drewpy
  • 1,790 posts
Posted 08 August 2019 - 11:51 am
that's a sensitive bit of kit. didn't know they existed.
#3653 MipeTDM
MipeTDM
  • 92 posts
Posted 08 August 2019 - 03:33 pm
Indeed, I had to seach for it a long time: the combination of fuel resistant and this sensitivity is indeed hard to come by. Especially for an acceptable price, as it will only be a fuel gauge, not a rocket to the moon :).
Now waiting for a hose barb adapter.
#3654 Catteeclan
  • 2,574 posts
Posted 08 August 2019 - 05:43 pm
Fitted a new Varta battery. Last Yuasa only lasted 3/4 years but I'm a bugga for letting it go flat.
#3655 fixitsan
  • 4,852 posts
Posted 08 August 2019 - 08:05 pm
How are you going to use the signal from this to communicate with you...the interface ? My mind wandered to thinking that as you go over bumps and leaps (maybe not leaps but crests) the pressure is going to fluctuate. Do you hook it up to a slow reacting meter ?
#3656 MipeTDM
MipeTDM
  • 92 posts
Posted 09 August 2019 - 05:12 pm
I will hook it up to an arduino programmable microcontroller. That way I can play around with it in the software and give the signal some filtering. In fact that way it behaves like a slow reacting meter. A tank's float (which my 4TX from 1997 does not have) will also bounce around a bit as the fuel flushes around. The pressure sensor is somewhat more sensitive, though.
#3657 fixitsan
  • 4,852 posts
Posted 09 August 2019 - 05:26 pm
I suppose that given the fact you don't expect the fuel level to drop quickly, and assuming the sensor outputs a variable DC voltage, just adding a  series resistor&capacitor, in parallel with the sensors will do all the filtering you need.
Google 'RC low pass filter'. Select a frequency of , 0.1Hz and you should be good to go, no rapid signal changes will get through
#3658 LAURENCEAUX
LAURENCEAUX
  • 233 posts
Posted 10 August 2019 - 12:25 pm
What have you done to your TDM 900A today?
I just nearly wept over her when I was presented with a £288 bill for the fitting of new HEL braided hoses and pads all round. I SUPPLIED THE KIT, PADS AND DOT4!!
Does anyone have an averaged time for completing such work and is it as complicated as these "experts" are telling me?
#3659 dablik
Posted 10 August 2019 - 04:38 pm
Well i have never done ABS to be honest and bleeding brakes can often be a pain but given that these are supposed to have the knowledge AND the equipment i think you have had ya kegs pulled down and been truly spanked, i just had 90% of me bike powder coated for that kind of money, it's hard to go back and get in someones face about it, did they give an explanation to the complication ?
#3660 drewpy
  • 1,790 posts
Posted 10 August 2019 - 09:27 pm
Did you get a quote for the job?
That's a lot of labour hours
