6039 replies to this topic
#3721 PeterM91
PeterM91
  • 70 posts
Posted 16 September 2019 - 12:10 pm
usually my windscreen is on brackets(selfmade) and higher(separeted from original windscreen) I've removed them and bolted the extension lower because I expect some offroading.
Bike looks very good!
Could you show us these selfmade brackets?
I'm curious how you've done that.
Wind protection is always a pretty hot item on a TDM :)
#3722 Andy25
Andy25
  • 344 posts
Posted 17 September 2019 - 07:25 pm
Well after replacing Front discs + pads , buying a refurbished set of Blue spots
The Bloody Master Cylinder has given up the ghost
Wasted a couple of hours trying to bleed them strip the cylinder
Now ordered another used one
Nothing much else can go wrong so should be back on Bike by weekend
Could do with a chain + Sprockets but that can wait till next month
#3723 pavel79
pavel79
  • 85 posts
Posted 18 September 2019 - 11:05 am
Replace my bent handlebar to Renthal 756. Became a little bit wider.
Next going to thread M16x1.5 and install original heavy ends.
#3724 drewpy
  • 1,790 posts
Posted 18 September 2019 - 11:25 am
are those the same form as the originals? If so what are the benefits?
#3725 pavel79
pavel79
  • 85 posts
Posted 18 September 2019 - 11:45 am
As for me the form is very close to original. About 20-30mm wider.
OEM 25-30 euro more expensive - this is my benefit  :)
#3726 catsbum
Posted 18 September 2019 - 05:54 pm
I did this today
#3727 wicklamulla
Posted 19 September 2019 - 01:24 pm
I did this today
Cats,  whas goin on with those lever nuts and bolts,  clutch side looks dome topped in one pic and ground down in another pic.  Also the brake lever one is a noice looking stainless allen dome head.  How can you sleep at night without the required symmetry!
#3728 chrisr
Posted 19 September 2019 - 01:48 pm
Shabby
#3729 Studley Ramrod
Posted 19 September 2019 - 02:57 pm
lol
Prolly won't see 'em with the handguards fitted. :D
#3730 Catteeclan
  • 2,574 posts
Posted 19 September 2019 - 05:34 pm
Shabby
:lol:
#3731 Andy25
Andy25
  • 344 posts
Posted 24 September 2019 - 06:33 pm
Managed to Lose a bolt holding the Front Brake caliper on way to work this morning
fooking scary noise and shuddering
So got creative for the journey HomeAttached File  20190924_143447.jpg   96.07KB   2 downloads
Ordered a new set from Fowlers
Must remember to double check that I've actually tightened properly ALL Bolts in future - cos finger tight is not enough
#3732 wicklamulla
Posted 24 September 2019 - 07:48 pm
FWR tyres in Kennington did this to my TDM back in 2002 after fitting new hoops and both bolts came out,  brake caliper was hanging down suspended by the brake hose so when i applied the front brake the brake fluid followed the path of least resistance and did nothing to slow my progress thru a sweeping left hander with a buxom pillion on board so the boike stood bolt uproight and i took the chance of running across the curve and into a bramble hedge. The boike remained upright and we were fine but had to have us and the TDM recovered back to south London. I now remove and refit my own wheels.
#3733 Norwegian
Norwegian
  • 162 posts
Posted 24 September 2019 - 09:17 pm
Buxom pillions are the BEST!
#3734 catsbum
Posted 25 September 2019 - 07:56 am
These arrived after I got a refund. Sat there for ages until Monday when I found 10 L brackets in Lidl for £2.
Need a switch and to move the RHS in a bit but I'm well pleased and how they fit
#3735 chrisbee
chrisbee
  • 413 posts
Posted 25 September 2019 - 07:40 pm
When you wire them up, can you do a write up.... i have tge same lights, bought them ages ago, just havent got round to fitting them.. not too sure if a relay is required or not
Chris
#3736 JMC
JMC
  • 265 posts
Posted 26 September 2019 - 08:21 am
Chris
Fit the relay, I tapped into the dims but also fitted a switch on the handlebars so I can switch them off if I need to, check back on a few of my posts for pics on the lights working
Hunter S. Thompson.
#3737 Favs
Posted 26 September 2019 - 08:33 am
Flip MRA touring screen thingy fitted.
Waiting for cable for electrical enhancements..
#3738 catsbum
Posted 27 September 2019 - 08:10 am
chrisbee.
Had a set on the previous bike. No relay. unscrew the alloy ring and you will find the smallest LED known to man. They were bright too
#3739 Snowbird
  • 1,475 posts
Posted 27 September 2019 - 09:26 am
Nice little spots, where did you get them and how many beer tokens?
#3740 chrisbee
chrisbee
  • 413 posts
Posted 27 September 2019 - 08:17 pm
Ebay
Less than £12...... got to be worth a try
