6039 replies to this topic
#361 MickC
MickC
  • 432 posts
  • TDM model: 1995
Posted 18 January 2015 - 08:23 pm
Got mine MOTd friday after the rebuild-= http://www.carpe-tdm...topic=29790&hl=
Passed of course. :good: get the tax next week (cant do it online for some reason) then hope the snow stays away.Bikes not been on the road for close to 3yrs now- Engine rebuilt-Frame painted-Forks apart new seals everything else cleaned greased should be interesting first few miles.
Attached File  IMG_0368.JPG   227.58KB   0 downloads
When the bike came out of the MOT area I said to the tester did it pass, he said the brake light doesnt work on the back brake pedal but it works on the front lever. I said well it was working yesterday when I tried it and we both walked over to the bike and I tried the back brake-no light came on so I looked around and we were alone so I said to him but have you  passed it anyway all he said was Its an MOT faliure to that I went Noooooo and he giggled and said yes I passed it.When I got home to have a look I found a socket set ratchet caught between the frame and swing arm ( Took bike up in a van luckily) and the back brake light switch wasnt even there,left it in the parts box Doooh.
#362 Catteeclan
  • 2,574 posts
Posted 19 January 2015 - 06:48 am
Made and fitted a new charging system for Mandis old tom-tom and fitted it to the TDM. I used an in-car type usb charger, butchered it out of it's plastic case and hid it under the dash. To bloody cold to test run it.
Edited by Catteeclan, 19 January 2015 - 06:49 am.
#363 g650xtdm
g650xtdm
  • 295 posts
Posted 19 January 2015 - 10:24 pm
Removed my left side heated grip and added some heatshrink underneath, then re-installed.  I was losing too much heat into the bars on the left side.  I typically add heatshrink or SA tape to the bars when adding the under grip type heaters.  I didn't think this was needed with Oxford grips, but it helped immensely.  I also swapped out my ST handguards for the $20 Chinese ones like AliG got.  They're not very handsome, but they provide better coverage.  Lastly, I swapped out my 60W Osram headlight bulbs for two LED H4 replacements, freeing up 80W.
Took it for a test spin today, although it was a fairly "warm" 44*F/7*C, the setup worked very well.  Should be good for those 20*F/-7*C morning commutes.
The downside:  I did something to my clutch cable during the handguard install.  It functions ok, but has A LOT of resistance to it.  I don't notice anything strange about the cable run, but it must be caught up somewhere.  I also noticed that my brake line holder on the rear swingarm broke and the part is no longer available!  If anybody has a spare, please let me know.
#364 ChrisG
Posted 20 January 2015 - 05:14 pm
What have I done to my TDM? Moved it out the way to get the chainsaw out of the garage yesterday but that's the first time I've touched it since I moved it out of the way to put the BBQ away :(
#365 arthurbikemad
arthurbikemad
  • 573 posts
Posted 21 January 2015 - 10:32 pm
I like a good Chainsaw session :)
http://www.myalbum.c...to-L38GFX7X.jpg
Can't wait for the weather to just slightly get better. I am itching to get the TDM out :(
#366 ChrisG
Posted 22 January 2015 - 12:22 pm
Way to make me feel inadequate with only an 18" Ryobi :(
#367 danceswithmopeds
danceswithmopeds
  • 2,425 posts
Posted 22 January 2015 - 03:20 pm
Gently, led it out into sunshine.
#368 tediumwannabe
tediumwannabe
  • 198 posts
Posted 22 January 2015 - 04:06 pm
Waggled the ill fitting key/lock and got it started, wheeled it out of the garage to warm up and spent some time eyeing up the rear end stance while listening to that twin burble............then switched off and wheeled it back in the garage :lol:
Oh, once back in the garage and on the main stand, lubed the dirty chain. Just because.
Edited by tediumwannabe, 22 January 2015 - 04:16 pm.
#369 Catteeclan
  • 2,574 posts
Posted 22 January 2015 - 04:14 pm
Opened the shed door, looked at it, shut the door as I realised I was in the wrong shed.
#370 Limbo
Limbo
  • 486 posts
Posted 22 January 2015 - 04:55 pm
You forget
I am from the beer House came looking for the bedroom. :rotflmmfao:
Limbo
#371 Catteeclan
  • 2,574 posts
Posted 23 January 2015 - 06:45 am
You forget
Limbo
Now that sounds like a mix up. Drunken mix up?
#372 harvey krumpet
harvey krumpet
  • 2,065 posts
Posted 23 January 2015 - 10:40 am
Yeah, I thought it must be a huuuuuge chain saw if the bike had to be shifted to get it out. V8?
Been using the bike for work lately. Head light is still nominal but suspenders much better. A little twiddle goes a long way.
Edited by harvey krumpet, 23 January 2015 - 10:42 am.
#373 Staffy
Staffy
  • 223 posts
Posted 23 January 2015 - 11:38 am
Over a month now and still waiting to get my TDM back. I have nothing but kind words to say about the fella doing the rewind but the service mob are useless. I just want the bike back :'(
#374 yellabellee
yellabellee
  • 12 posts
Posted 23 January 2015 - 08:16 pm
Fitted some Datatool  Heated Grips, no raving about in the wiring harness to find an ignition feed, they detect when the engine not running and switch off, just 2 wires straight to the battery, and a nice sliding switch on the left bar you can work with your thumb.Doddle
#375 Catteeclan
  • 2,574 posts
Posted 24 January 2015 - 05:00 pm
Went to Norwich to collect some engine bars, got home and now fitted.
#376 mintex
mintex
  • 162 posts
Posted 24 January 2015 - 08:17 pm
Spent a few hours polishing my bash guard :)
#377 Sidarta
Sidarta
  • 845 posts
Posted 25 January 2015 - 08:06 pm
Hi Catteeclan!
I liked the engine bars. It seems very compact and is not an exaggerated aspect.
Your motorcycle is very beautiful
TDM yellow, reminds me of my first motorcycle. A Honda CB350 1973. The previous owner had painted yellow. The same color Goldwing 1000.
Att
Sidarta
TDM850 ano 2001
 Honda XLX 250 1988
Honda CB350 1972 e 1973
#378 Catteeclan
  • 2,574 posts
Posted 26 January 2015 - 06:49 am
HI Sidarta. They're only Givi bars so not the best quality but as you say quite discrete.
Bit of a sucker for yellow myself but normally one shade per bike.
#379 harvey krumpet
harvey krumpet
  • 2,065 posts
Posted 26 January 2015 - 08:18 am
Got any pics with bash guard at home?
#380 mintex
mintex
  • 162 posts
Posted 26 January 2015 - 11:01 am
No not at the moment, i need to lacquer it so it keeps its shine but i hope to have it done and on in the next few days so will post a pic in here when i do  :good:
