850 Destruction
892 replies to this topic
#361 dapleb
  • 18,394 posts
Posted 24 September 2019 - 10:29 am
This tool easier (but not as much fun) than cakey trolley. Put good fitting tube over handle to extend but careful to avoid case where clutch cover fits. Post?
Attached File  IMG_20190924_104425.jpg   199.04KB   0 downloads
Which bits of use? Will be cheaper post without burrings.
Wear to leading edge on housing.
Attached File  IMG_20190924_110321.jpg   356.02KB   0 downloads
#362 Favs
Posted 24 September 2019 - 10:38 am
Looks minimal chatter 2 smee :good:
#363 dapleb
  • 18,394 posts
Posted 24 September 2019 - 10:48 am
Yeah same as on most mk1 housings I've seen. Dabs could GENTLY dress edge if reqd.
  Dappers,   just out of interest is it virtually identical to an 850 HG barring the part number?
Nearly.
#364 wicklamulla
Posted 24 September 2019 - 07:59 pm
Nearly.
what a stupid question i asked!  I'd imagine the bore size of the 900 HG is larger than the bore size of the 850 HG so very different!!!  :rolleyes:  :istupid:  :rotflmmfao:
#365 dapleb
  • 18,394 posts
Posted 24 September 2019 - 08:19 pm
Not stupid. Haven't measured but very little diff. A tang and a hole looks like the only obvious diffs.
#366 dablik
Posted 24 September 2019 - 10:32 pm
Oh daps I have to openly declare my love for you
No need to send burrings me thinks as mine should fit fine and I'm sure I can bring out me gentler nature for some dressage.
Am popping over to the rough side of town on Thursday to see Chris (Matlock) as he is loaning me a cupla tools amongst which he informs me is a clutch tool holder ️
Good to see that pic of the 9r gasket also, so there all like that sir, nice one.
Edited by dablik, 25 September 2019 - 07:58 am.
#367 dablik
Posted 28 September 2019 - 12:58 pm
That clutch basket above does'nt look any worse than the one i've broken and that seemed to work just fine, have to get a pic.
Further to an earlier question re lapping the flywheel to the taper i had an amatuer blueing of the tapers only Red instead as it's nicer than Blue :)
Before
Attached File  20190928_103156.jpg   136.01KB   0 downloads
After
Attached File  20190928_103332.jpg   111.61KB   0 downloads
Looks to be a relativley good fit as it's only pushed on and rotated a cupla times, but still think a small clean up with fine paste could make it betterer...
Also wondered about a new woodruf key but this current one slides along the slot quite nicely.
Attached File  20190928_101652.jpg   126.81KB   0 downloads
Removed the broken basket
Attached File  20190928_105157.jpg   143.92KB   0 downloads
#368 dablik
Posted 28 September 2019 - 01:20 pm
Not much between them, if i dress the basket is it more likely to wear quicker !!
Daps
Attached File  Daps basket.jpg   87.44KB   0 downloads
Mine
Attached File  20190928_140102.jpg   126.5KB   0 downloads
#369 dapleb
  • 18,394 posts
Posted 28 September 2019 - 02:52 pm
It looks like every other mk1 basket so I wouldn't dress it but thought I would just highlight that it's there.
Bearings put it over 2kg and into post expensive. They are in good cond so if ewe need them can send separate if reqd.
That's a proper clutch holder. :0)
#370 dablik
Posted 28 September 2019 - 04:57 pm
Okay good, then that's one job i'll wait fur to break before i fixit, so long as she dont start walking at idle i'll be golden.
Cant see any issue with me clutch bearings but ya never know, stick em on the back shelf for now....cheers muchly :good:
Oh yea thas a gudn an all, can now hold me bit's proper :)
#371 Matlock
Posted 29 September 2019 - 09:19 pm
Good to see you made it back alive Cliff  :rotflmmfao:
#372 dablik
Posted 29 September 2019 - 10:00 pm
Good job i know you have a sense of humour Chris :D
#373 dablik
Posted 05 October 2019 - 06:33 pm
Set the timing today and gave the crank a cupla turns to set the tensioner.
That's close as it gets
Attached File  20191005_133429.jpg   173.65KB   0 downloads
Attached File  20191005_141037.jpg   150.1KB   0 downloads
Fitted the replacement clutch basket, cheers daps, then took it off, then put it back on as ya do, spent most of the afternoon cleaning the needle bearing inside the clutch cover for the bottom of the actuator arm, just full of glass from vapour blasting, a hot soak and bottle brush would'nt remove it all, so cleaned with the brush then cleaned the brush and back to the bearing, but took a long time until i was happy it was gone, you could hear glass on glass grinding yuk, originally tried to pull it out but it's so awkward to get at..
Had the speedo apart as now i've set the odo back to 6/10th's of a mile :lol: it's the one wheel i could'nt budge without taking all the tumblers out of the housing but if i attempted that i'm pretty sure it would break, looks like a press fit into it's housing.
Attached File  20191004_130026.jpg   70.35KB   0 downloads
Attached File  20191004_143943.jpg   100.38KB   0 downloads
It's set back to zero from 50506 for my benefit only, no attempt to declare it as a new bike as most of it's parts are around half my age.
Also cant find me rubber grommits to fit the lights and instruments so made do with some rubber washers for now, they may still show up..
Might get time to chuck the sump on tomorrow which will leave the engine ready to mount in the bike, wont even attempt puttin the flywheel back on and torqueing till then........everyone pray to the rain sun gods please, getting finished is very much weather dependant now,,
Edited by dablik, 05 October 2019 - 08:23 pm.
#374 dapleb
  • 18,394 posts
Posted 05 October 2019 - 07:01 pm
Very good that dabs, no tooth out dare.
#375 dablik
Posted 05 October 2019 - 08:19 pm
Photo is a bit decieving, it's about 1/3 rd of a tooth out :lol: on the exhaust which is the oppsit of how it came off after looking at me photo's, but that was a new chain not so many miles ago i believe and that's as lined up as it ever will be......
Having a real dilemma  wether just to tuck it all away until next year now or not, weather forecast for the long term is not so pleasant....hmmm :um:
#376 dapleb
  • 18,394 posts
Posted 05 October 2019 - 08:46 pm
Ya can get injun finished in dry this year? Rest of it can wait? If you have everything prepared the rest of it will go together pronto.
#377 Favs
Posted 05 October 2019 - 10:15 pm
Looking good good looking
#378 dablik
Posted 05 October 2019 - 10:46 pm
Could prolly still getit mounted, if i do though i want it run in and this shoite weather is gonna curb the dablik sitting on me shoulder :)
Decisions,decisions....
#379 ramo
ramo
  • 1,193 posts
Posted 06 October 2019 - 12:38 pm
A true scally, proud of ya Cliff ;)
(clocking it ) why not LOL  :good:
Get it on the feeking road :badgerrock:
#380 chrisr
Posted 06 October 2019 - 01:54 pm
Put the sofa in the garden!
