6039 replies to this topic
#3821 Favs
Posted 30 December 2019 - 07:29 pm
Good job, it fit okay i guess but fook me the welder must have had parky's :lol:
:rotflmmfao:
#3822 Nig
Nig
  • 217 posts
Posted 30 December 2019 - 08:33 pm
Hahahahaha - that was my first thought when I saw it - severe case of the Charlie Drakes or what! Thought I was going to have to repackage it and send it back - but been for 30 mile blast and it is holding up OK.
Mind you - you only get the top 2 rubber bush fixings to hold it in place - the side ones are not there but it is still solid. All it means is that you don't have the left hand strap that holds the cheak panel push clip. I had to enlarge the 4 x fan shroud bracket holes to 10mm also to get it aligned. There are no upper tabs to hold the mesh protector either,but once the screws are tightened it is pretty solid. All in all its OK.
Edited by Nig, 30 December 2019 - 08:59 pm.
#3823 dablik
Posted 31 December 2019 - 12:08 am
Main point is it's doing the job for you, i spose it could have been a bit chancey but it's worked out fine all in all :good:
#3824 leehenty
  • 5,325 posts
Posted 02 January 2020 - 06:44 pm
Steadily reassembling the niner after fitting fancy plugs for my Nano II gear position indicator. Just a few things to tidy before mot.
#3825 leehenty
  • 5,325 posts
Posted 03 January 2020 - 07:36 pm
Put my inner dash in, screen on, all nice shiny screws, new rubber well nuts everywhere, about to put side panels on, I thought I better try out me lights and that.
Lights worked, meters suspiciously dead, unresponsive and unlit.  Why ? because the spanner man forgot to plug in the meter pod :istupid:
So I had to take it all apart again, dammit.  :hide:
#3826 leehenty
  • 5,325 posts
Posted 04 January 2020 - 04:42 pm
The lower frame suspension bush slid straight out,coating everything in moly grease must have worked. All cleaned and repacked with new grease, seals looked a bit worn so I replaced those.
#3827 chrisr
Posted 04 January 2020 - 09:45 pm
He’s human after all!
#3828 leehenty
  • 5,325 posts
Posted 05 January 2020 - 12:59 am
It's me age, best I get some adventure before dementia, before it's too late.
#3829 leehenty
  • 5,325 posts
Posted 05 January 2020 - 07:11 pm
DRL's going on.
#3830 dablik
Posted 06 January 2020 - 01:06 pm
Lee, i assume you've had no issues with the plastic tool/bits holder next to the engine !! you got them on the Enfield also i remember..
#3831 chrisbee
chrisbee
  • 413 posts
Posted 06 January 2020 - 05:24 pm
DRL's going on.
Are these the cheap DRLs off ebay???
How have you wired them up?
I have some of these, i keep meaning to fit...
Chris
#3832 leehenty
  • 5,325 posts
Posted 06 January 2020 - 07:22 pm
wire through a relay so lights can only be on if side lights are on taking the relay coil feed from side light circuit. Plus a switch in coil feed of relay to switch off if you want to. Fuse at 3 amps power from battery as close to battery as possible. I used 10 amp wiring for feeds so I can upgrade to Cree lights later on. The cheap chinky lights I use also as machine lights on lathe and miller using a 12 volt supply.
A job they do very well for hours on end.
Edited by leehenty, 06 January 2020 - 10:41 pm.
#3833 leehenty
  • 5,325 posts
Posted 06 January 2020 - 07:34 pm
No issues with the plastic tool tubes on the TDM, on the RE they sit much further out in the crash bars. It's worth knowing a 0.47 litre Stanley Classic flask and a 1litre alloy drink bottle fit inside the tool tubes exactly.
The flask can save time at coffee stops. Buy a big coffee to go and fill up flask. Drink whats left over. Next stop no queuing up.
Start with flask full and hot each day. I did this in Spain and it saved me loads of cash. On the RE, the right side had 1 litre of engine oil in alloy fuel bottle as Ruby drinks oil a bit in hot weather.
On the TDM oil is not needed, so one is water the other coffee.
Tools go in another tube under topbox rack above tail light.
Edited by leehenty, 06 January 2020 - 07:42 pm.
#3834 leehenty
  • 5,325 posts
Posted 06 January 2020 - 07:41 pm
Also fitted a new Surflex complete clutch kit both friction and plain plates, plus a new cable today.
This should stop the screaming on take off. The old friction plates measure at almost service limit.
Old cable was on it's last two threads inside the curved tube at the top stopping the lever returning properly.
Don't know why, it's been lubed each year without fail with a cable oiler.
#3835 chrisr
Posted 06 January 2020 - 08:57 pm
You got away with that Lee, what’s the mileage on the clutch?
#3836 steve27bha
  • 797 posts
Posted 06 January 2020 - 09:57 pm
.....It's worth knowing a 0.47 litre Stanley Classic flask .....
With or without a handle?
I did not know about these so did a Google to see two different versions.
ADD I've followed the links and it seems only larger sizes have a handle - your 0.47l size is the smallest and handle-free.
Edited by steve27bha, 06 January 2020 - 10:03 pm.
#3837 leehenty
  • 5,325 posts
Posted 06 January 2020 - 10:29 pm
without handle, for flask, mileage on clutch is 30,500. I think cable sticking has been causing slip as some of the plain plates are blued.
I want to make sure it's in tip top fettle for the Picos de Europa, as I have to keep up with younger brother on his mighty 1200 Crosstourer. His mate is on a Pan Euro 1300.
Edited by leehenty, 06 January 2020 - 10:39 pm.
#3838 dablik
Posted 07 January 2020 - 08:41 am
Think i'll need a bigger one for my 2 litre Stanley  :)
#3839 PICARD
  • 1,786 posts
Posted 08 January 2020 - 06:18 am
Come on jono, he's left the door open for you there....
#3840 Andy25
Andy25
  • 344 posts
Posted 16 January 2020 - 08:12 pm
Had it Cleaned + Treated with XCP by All year Biker Dundee
Bike hasn't been this clean in a long time
Well worth the money - especially when someone else paidAttached File  20200116_130222.jpg   184.39KB   0 downloads
