Breaking In - How To?
27 replies to this topic
#21 norty
norty
  • 161 posts
Posted 07 November 2008 - 11:31 am
QUOTE(TigersBlade @ Fri 7th Nov 2008, 09:54 AM) <{POST_SNAPBACK}>
Yeah I pretty much agree on that, 'cause the older I get the more I realise the less I know for sure. laugh.gif
I will get the TDM Dyno'd though just to satisfy my own curiosity.
What I like about this place is we can all throw our two cents / pence worth in & generally something useful comes out of it. wink.gif
Thanks all - seems to beside chaging the oil not that much difference - Just don't be to gentle - my usual riding style biggrin.gif
#22 wicklamulla
Posted 07 November 2008 - 12:41 pm
It will give you a very loose/general indication as to how much power yer boike makes and the fuelling characteristics, but unless you had it dyno'd new at the showroom before you wheeled it off their forecourt and now you have put some miles on it and have it dyno'd again it will tell you not alot atall atall excl.gif basically we need 10 people to buy new 900's and everyone to run it in differently and put some miles on (say 10k) then they are all dyno'd on the same day on the same dyno, that would prolly give some interesting results maybe ??
#23 Guest_GuyGraham_*
Guest_GuyGraham_*
Posted 07 November 2008 - 07:09 pm
QUOTE(TigersBlade @ Thu 6th Nov 2008, 11:54 PM) <{POST_SNAPBACK}>
As for Dapleb & no evidence. I still say look at Motoman's Photos. What would he have to gain from giving BAD advise apart from threat of death from
very upset bikers! Quite the contrary, from what I read they support his method.
Over on the Thumpertalk forum, specifically the DRZ400 section, the moderator owns a bike engine tuning business.
He lambastes people for not doing it the mototune way
He swears by it. He has the pistons to prove it.
Owners who are having oil burning issues, he gets them to post up pics of their pistons and you can see the blow by of the rings exactly like motoman says
Then there are others who have posted pics of their piston coz they are doing engine mods, who have done it the motoman way and sure enough the piston skirt look like new.
Indeed he can tell which motors have been broken in too gently
Now I 'm an engineer by trade, and it makes sense to me.
If an engine is going to make max power then it needs a good ring seal. FACT.
The late John Robinson (from PB mag) explains this is what is needed in his engine tuning books from the mid eighties
Be under no illusion, if you have a tight clearance in your engine from a manufacturing defect, no amount of gentle running in will fix it.
Yes it is possible to over do it
To avoid warranty claims the manufacturers advocate a simple, safe break in.
Not the best, but certainly prevents warranty claims
Just imagine if they put it in the hand book to be agressive and stress the engine
there would bound to be some who trash it form cold
They don't want to be forking out for this stuff, hence they are over cautious.
Ever seen a car at the end of the assembly line, on the rolling road?
if you think you need to baby you engine, it would open your eyes.
#24 norty
norty
  • 161 posts
Posted 08 November 2008 - 01:07 pm
A bit of nebie question this one - but what oil is a new TDM from the factory
#25 robelst
robelst
  • 1,844 posts
Posted 08 November 2008 - 01:27 pm
QUOTE(norty @ Sat 8th Nov 2008, 12:52 PM) <{POST_SNAPBACK}>
Not sure but it better have generous temperature reserves for those who are planning to fry their spanking new engines rolleyes.gif
That was not a banana, Dougal
#26 tdm850rider
Posted 08 November 2008 - 03:56 pm
QUOTE(norty @ Sat 8th Nov 2008, 08:52 AM) <{POST_SNAPBACK}>
Bikes come from the factory dry, (no oil no petrol) so it could be whatever the dealer has available. unsure.gif
Most likely it will be cheap oil to maximize the dealers profit...
that can be good since cheap oil generally has no additives to worry about.
(Whatever it is it will only be there for the break in (600 miles) and then you can pick some good stuff.)
I have been using semi-synth since new (16 years) and no oil problems.
#27 Toraneko
Toraneko
  • 364 posts
Posted 09 November 2008 - 10:24 pm
Firstly NORTY. I'd say ya won't go too far wrong with your chosen approach. The only reason you put EL CHEAPO car engine oil in for the first 100k is exactly that, 'cause it's cheap &
your gunna chuck it out after an hour or so riding.
The major difference between synthetic vs mineral oil, straight mineral oil wears out alot faster ( breaks down under heat & pressure, etc ) so should be changed more often. smile.gif
tdm850rider. you likely wouldn't have any problems with semi-synthetic oils, but from what I've read you're just paying a premium for something not much better that standard mineral oil.
robelset. I can't say I've ever noticed or heard of a new engine running significantly hotter than an older one. doubtfull.gif
wiklamulla. Quote "basically we need 10 people to buy new 900's and everyone to run it in differently and put some miles on (say 10k) then they are all dyno'd on the same day on the same dyno, that would prolly give some interesting results maybe ?? " Top idea! anyone got some spare cash for the experiment? laugh.gif
I'll be happy if my Dyno results are better than Yamaha spec's.
cheers, Shane from Tassie
#28 wicklamulla
Posted 09 November 2008 - 11:11 pm
QUOTE(TigersBlade @ Sun 9th Nov 2008, 10:09 PM) <{POST_SNAPBACK}>
you get my drift with my comment on running in 10 bikes though ??? rolleyes.gif basically your dyno results showing less or more than Yamaha's specs don't mean jack but they will give you that satisfied warm feeling if they are higher than Yamaha's claimed outputs.
