Service On A 9er
59 replies to this topic
#21 dapleb
  • 18,397 posts
Posted 23 February 2009 - 08:50 pm
Moved to the ole Knowledge Base for those who cant see CB's blog.
#22 Guest_badger_*
Guest_badger_*
Posted 20 March 2009 - 07:50 pm
CB,
Just changed plugs & air filter.
Wouldn't have had a scooby about getting to the plugs using the manual so thanks for the easy to use guide.
Cheers mate
Edited by badger, 20 March 2009 - 07:51 pm.
#23 dapleb
  • 18,397 posts
Posted 20 March 2009 - 08:21 pm
Nice user name and welcome badger.
#24 tdm850rider
Posted 21 March 2009 - 01:37 am
QUOTE(dapleb @ Fri 20th Mar 2009, 04:21 PM) <{POST_SNAPBACK}>
#25 rami
rami
  • 89 posts
Posted 06 April 2009 - 02:00 pm
QUOTE(divvxj @ Sat 24th Jan 2009, 09:38 AM) <{POST_SNAPBACK}>
excellent pictures good.gif and description good.gif as i will be doing this in a couple of weeks and i didnt realise that there were two drain bolts , drinks.gif
Great pictures and write up, i usually pay to get my bike serviced, but think i'll have a do myself next time blink.gif unsure.gif
Touring screen,front fenda extanda,touring scottoiler,engine guards,hand guards, givi v46 topbox, bagstar leather tank cover with tank bag.Belly pan fitted. Rack and backrest fitted to top box
Would like some louder cans(on the way, now fitted) and may be a power commander.
#26 catsbum
Posted 11 April 2009 - 01:51 pm
CB, used for techno for the plugs.
Cats
#27 raymac
raymac
  • 61 posts
Posted 26 July 2009 - 09:38 am
Just done plug replacement / oil change. the pictures for plug change very handy, Many thanks good.gif , and as I had the side pannels off lifted the tank and did the air box mod as well.
By pure chance was given the wrong oil filter, but had already droped the oil out of bike. So had to leave bike at my mates bike shop ( having mate who owns motorcycle shop is very handy, but I want to do all work my self cos thats how you lern and save money ) so put housing and drain plugs back in/on , as bike may have to be moved around workshop wilst waiting for correct filter to come in the post. so next day go back and take out/off drain plugs housing and was expecting a wee drible of oil but about 50ml or more came out, so if you are going to change your oil don't be in a hurry best to leave it for a while, cos if had right filter would be running with some old crapy burnt oil mixed in.
#28 Fiasco
Fiasco
  • 158 posts
Posted 06 September 2009 - 03:39 pm
Just changed the oil filter for the first time, thanks for the info CB
One problem, I couldn't get the gallery bolt undone, it is well hidden behind the frame, and my ring spanners were just chewing up the bolt - any tips anyone ?
In the meantime, any other warning signs I should look for if all is not as it should be ?
Thanks again
Edited by Fiasco, 06 September 2009 - 03:40 pm.
The early bird catches the worm, but the second mouse to the trap gets the cheese !
#29 dapleb
  • 18,397 posts
Posted 06 September 2009 - 07:59 pm
Use a decent socket not a ringy ding spanner. It should not be that tight. Torque spex is only 10nm or something equally not overly tight.
#30 Fiasco
Fiasco
  • 158 posts
Posted 06 September 2009 - 10:23 pm
QUOTE(dapleb @ Sun 6th Sep 2009, 07:59 PM) <{POST_SNAPBACK}>
Hmm leaves me wondering if I am looking at the right bolt, because it is behind the frame with no chance of getting a socket on it ?
#31 Guest_celticbiker_*
Guest_celticbiker_*
Posted 06 September 2009 - 10:27 pm
It is the right bolt Dave.
If you have rounded it off you will have to use a small stilsons or similar to undo it.
#32 dapleb
  • 18,397 posts
Posted 06 September 2009 - 10:32 pm
QUOTE(Fiasco @ Sun 6th Sep 2009, 11:23 PM) <{POST_SNAPBACK}>
#33 Fiasco
Fiasco
  • 158 posts
Posted 06 September 2009 - 10:33 pm
QUOTE(celticbiker @ Sun 6th Sep 2009, 10:27 PM) <{POST_SNAPBACK}>
Not going totally mad then !!
#34 crispy
crispy
  • 213 posts
Posted 09 September 2009 - 12:46 pm
QUOTE(Fiasco @ Sun 6th Sep 2009, 11:33 PM) <{POST_SNAPBACK}>
I thought i was going mad last month when i was doing it aswell. Back 20 odd years ago when i used to rebuild honda 50 engines we used to loosen off one of the 4 studs that held the whole topend (barrel/head/rocker cover) together as this was an oilway and you could see the oil reaching the topend of the engine after a rebuild....I was expecting to see a bit more of a pressurised oil flow not the fast dribble that i got.... ohmy.gif
I don't like YZ250's anymore.........check out my avatar, one literally kicked me in the ass
#35 Onanist
Onanist
  • 448 posts
Posted 12 September 2009 - 04:21 pm
Thanks, CB excellent instructions, changed oil and filter this afternoon.
I've got fresh coolant to go in so may take some piccys as I go and update.
#36 roys
roys
  • 173 posts
Posted 22 March 2010 - 02:19 pm
hi,
thank you very much for this. a huge help for somebody new to the TDM (did the BMW K100 maintanance myself but it is so different!).
I have asilly question (one of many to come) when asking local suppliers for parts I need to give them SKU's or clear part mfg and name at least.
can someone pls name /give SKU for the air filter and oil filter.
also - How does one go about replacing the fuel filter in this bike - is it in the tank? any write up about that?
thank you,
Roy
Thank you,
Roy
1987 K100 (2v)
2006 TDM 900
post-19792-0-23739400-1358674634_thumb.j
#37 tezmondo
tezmondo
  • 28 posts
Posted 04 August 2010 - 01:04 pm
Thanks that's great
By disconnecting the hoses - will fluid spill everywhere?
Or will you just lose a little and need to top up at the end?
Or do you need to drain the radiator and replace fluid?
ta
#38 TonyDevil
Posted 30 August 2010 - 06:19 pm
ps. how good are those rickycross bars?
do they stop the panels touching down in the even of a drop?
#39 Guest_celticbiker_*
Guest_celticbiker_*
Posted 31 August 2010 - 12:42 am
Thanx Tony.
The Ricky Cross bars have done me proud on a 40mph road drop, an 'I forgot to put the sidestand down' drop and a reverse into it and knock it of the centre stand.
Are you coming to Snowjoke this weekend?
If so you can have a closer look at them.
#40 TonyDevil
Posted 31 August 2010 - 06:20 am
