Valve Clearance Check
132 replies to this topic
#21 ronoc88
ronoc88
  • 24 posts
  • TDM model: 1995
Posted 01 May 2010 - 11:56 am
QUOTE(dapleb @ Wed 14th Apr 2010, 06:29 PM) <{POST_SNAPBACK}>
Thanks for all that, yes I had ground the shims to suit but have now replaced them with new ones. I didn't realise they were hardened.
I have the timing done, still looks a small bit out, could this be from chain wear? When should the chain be replaced? Theres 60K on this bike.
Conor
On the road. - '95 TDM 850 MK1
Off the road. - '04 Sherco 290
#22 ChrisG
Posted 01 May 2010 - 07:58 pm
The chain should be ok until the tensioner runs out of adjustment. I've got 67,000 miles on mine and there's still plenty of room on the adjuster.
#23 gilbert
gilbert
  • 83 posts
Posted 11 May 2010 - 09:04 am
sorry to be off track, but i cant seem to find any post regarding changing of timing chain. any kind soul to guide me through it?
#24 tdm850rider
Posted 11 May 2010 - 04:29 pm
QUOTE(gilbert @ Tue 11th May 2010, 05:04 AM) <{POST_SNAPBACK}>
Timing chain for a 900 here. That may get you started. I don't know the differences (if any) from a 3VD to a 900.
#25 gilbert
gilbert
  • 83 posts
Posted 19 May 2010 - 03:35 am
QUOTE(tdm850rider @ Wed 12th May 2010, 12:29 AM) <{POST_SNAPBACK}>
thanks dude, however seems like the link bring me back to this same topic.. smile.gif
Edited by gilbert, 19 May 2010 - 03:42 am.
#26 3vd
Posted 04 June 2012 - 12:57 pm
It's not going well today, this is another thread with dead pictures and links sad.gif
#27 dapleb
  • 18,399 posts
Posted 04 June 2012 - 01:12 pm
Yup thats the problem with a broken gallery and no on-site piccie hosting. I intend to clear out all of the KB posts which are now pictureless so now is the time to reinstate the pics if possible.
#28 ChrisG
Posted 04 June 2012 - 04:38 pm
That's weird, the photos are still showing up on Facebook so they must have changed their storage system so the links no longer work.
Try this https://www.facebook...mp;l=4d458f092a and I'll see if I can relink the photos in the original post
#29 dapleb
  • 18,399 posts
Posted 04 June 2012 - 04:44 pm
#30 3vd
Posted 04 June 2012 - 04:46 pm
Quick, print!
Edited by MaximusPetrolhead, 04 June 2012 - 04:47 pm.
#31 ChrisG
Posted 04 June 2012 - 04:51 pm
I've relinked both the first post with the checks and the later one with changing the shims, so hopefully they should work ok. Until FB change their bloody system again. Might be worth me putting them on my webspace I suppose
#32 carvell
carvell
  • 15 posts
Posted 23 April 2013 - 10:27 pm
I think they've changed their bloody system again...!
You wouldn't be able to update the pics would you please?  I need to do this job soon.
#33 Studley Ramrod
  • 19,373 posts
Posted 24 April 2013 - 08:54 am
Chris, you could put the pics in the fully functionizing & permanentable Carpe gallery where they'll be revered and reviewed for an eternity :)
#34 Kyotoviking
Kyotoviking
  • 27 posts
Posted 15 July 2014 - 12:41 am
First of all, I have to say I'm so thankful for carpe-tdm. I've learned a lot, and currently trying to do all the servicing and fettling on my own 900.
Now I checked clearance, and swapped around almost all of the shims. I had a couple of 0.12-13 on intake and two 0.22 on exhaust. I opened them up to 0.16-17 and 0.26-28. I left the 0.16 as is in intake, and the 0.24 on exhaust. I think I did everything according to the manual, but the valves are now really loud. I mean, REALLY loud. I didn't bother with adding moly grease under the buckets. Just used a dash normal multi grease. And I forgot to splash some oil over the cams before I closed the lid. Are all engines this loud after a shim change (clearance opened up so much) Should I drain it and open again? No problems with the cam chain tensioner btw.
#35 Geordie Guy
Posted 15 July 2014 - 04:52 am
Hi Chris,
where's the pictures gone !!!!!!
#36 Studley Ramrod
  • 19,373 posts
Posted 15 July 2014 - 06:26 am
Just wondering if you pushed the shims in fully, they are a tight fit. I used to swap the shims then replace the bucket and give them a firm tap with a small hammer to make sure they were fully bedded in.
You might find that they bed in over a few days and make less noise.
After you fitted the shims, did you turn the engine over manually and then measure the valve clearances again ?  Or did you just fit them ?
#37 Kyotoviking
Kyotoviking
  • 27 posts
Posted 15 July 2014 - 06:57 am
I made sure they were seated fully. A really tight fit. And I turned the engine around a couple of times. I have a sneaking suspicion I forgot to tighten the cam sprocket bolts. Had to redo the timing following day, due to too much cake/beer at first attempt. Think I'll pop it open anyway. No sweat now that I know the drill.
#38 Bjørge
Posted 27 August 2014 - 03:55 pm
You can now put the cam shaft back on (remember the lobes on the left cylinder face away from each other) and torque it up correctly (10Nm), though I leave the guard that goes over the chain off until I’ve got the timing set. The front side of the chain will be tight, but the rear will be loose because the tensioner’s not in. Using screwdrivers or allen keys as levers though the holes in the middle of the cam shaft rotate the shafts towards each other to get the timing marks aligned and the front side of the chain is tight. You’ll find you can easily turn the cam the other way a bit and skip the chain on a tooth if it’s not quite right. Once it’s in place put the tensioner back in, then the tensioner spring, and check the timing again.
I've seen a few complaints on how to keep it all timed while getting sprockets fastened - there is a tendency of cam chain skipping a few teeth on the intake sprocket. I found a solution to this, maybe one could do this before removing camshaft sprockets ?
Attached File  CIMG0627_20perc.jpg   175.75KB   1 downloads
#39 Borderraider
Borderraider
  • 180 posts
Posted 27 August 2014 - 04:39 pm
First valve clearance check @24k and all within tolerance.
Not so happy with the condition of the coolant pipe.Attached File  image.jpg   137.34KB   2 downloads
2007 BMW R1200GS Adventure
2007 Kawasaki Versys 650
2009 Yamaha TDM 900
2013 Kawasaki Versys 650
#40 ChrisG
Posted 28 August 2014 - 10:21 am
It appears all my pictures have buggered off again, bloody facebook.  I've bunged a link to the album in the first post for now but it would make sense if I sorted this out as it appears to be useful still.  Does the gallery on here now work to host the pictures?
