Day Of Fettling
188 replies to this topic
#21 Moose
    Master Cake Baker
  • 3,312 posts
Posted 20 October 2009 - 03:15 pm
QUOTE(TonyDevil @ Tue 20th Oct 2009, 03:40 PM) <{POST_SNAPBACK}>
that would be me =)
From what i saw you might wanna stick a cuppla cannon balls on the bottom, might last ya a bit longer ya loon rotflmmfao.gif rotflmmfao.gif rotflmmfao.gif
JG, I can get to you as early as ya like, bacon is good for me whatever time of day rotflmmfao.gif I'll get the carb kit and might as well change the lot while we're in there if thats ok
Cheers for the cool down info, makes sense when ya fink about it istupid.gif so luckily wifgeni.gif
#22 Moose
    Master Cake Baker
  • 3,312 posts
Posted 20 October 2009 - 03:26 pm
QUOTE(Studley Ramrod @ Tue 20th Oct 2009, 12:00 PM) <{POST_SNAPBACK}>
Moose, your gonna need to allow time for the engine to cool down completely before you can check the valves. So, you might find your gonna be pushed for time if your also balancing yer carbies. It's definitely dooable though ! (in an ideal world !)
My Yam dealer gave my bike about 4 hours to allow it to cool down.
Anytime you have access to the carbs, is a good time to swap yer tubes.
You should only need to get the emulsion tubes, but you might need some new float bowl gaskets, depending...http://cgi.ebay.co.u...=item3ca57f6e82
Or order direct from straightline racing.
I know it sounds like a kop out cheap bar steward option but is there a cheaper option as with all that it's looking to out price the value of my bike rotflmmfao.gif
#23 TonyDevil
Posted 20 October 2009 - 03:27 pm
if the carbs havent been apart since new i would replace the floatbowl gaskets as you'll only have to go back and sort it out later when it starts leaking petrol all over the place
£40ish for emulsion tubes
£25ish for carb & airbox rubbers
£10ish for floatbowl gaskets
and a few sprays of carb cleaner
sorry i wont be able to make the fettling day
#24 Moose
    Master Cake Baker
  • 3,312 posts
Posted 20 October 2009 - 03:34 pm
QUOTE(TonyDevil @ Tue 20th Oct 2009, 04:27 PM) <{POST_SNAPBACK}>
Gonna be busy trying to grind the rest of ya hero blobs down? rotflmmfao.gif
Might have to just balance the carbs then til i can fund the parts, Xmas coming up and 3 demanding kids rotflmmfao.gif
#25 TonyDevil
Posted 20 October 2009 - 03:37 pm
i know i have atleast 1 set of spare carb rubbers in my box'o'bits and i gotta do tha 'toobs' on me TRX this week, so once thats out the way i may be able to send you a set
hows ya maths?
when i did the carb service thing on my TDM i gained an extra 10% on my mpg, 30% on my XTZ and expecting similar back from my TRX
work out the mileage you do and see how long it would take to save your money wink.gif
#26 Moose
    Master Cake Baker
  • 3,312 posts
Posted 20 October 2009 - 03:57 pm
QUOTE(TonyDevil @ Tue 20th Oct 2009, 04:37 PM) <{POST_SNAPBACK}>
i know i have atleast 1 set of spare carb rubbers in my box'o'bits and i gotta do tha 'toobs' on me TRX this week, so once thats out the way i may be able to send you a sethows ya maths?when i did the carb service thing on my TDM i gained an extra 10% on my mpg, 30% on my XTZ and expecting similar back from my TRXwork out the mileage you do and see how long it would take to save your money wink.gif
When it comes to baking cakes it's spot on otherwise i'm ficker than the tread on my tyres rotflmmfao.gif
if the carbs havent been apart since new i would replace the floatbowl gaskets as you'll only have to go back and sort it out later when it starts leaking petrol all over the place£40ish for emulsion tubes£25ish for carb & airbox rubbers£10ish for floatbowl gasketsand a few sprays of carb cleanersorry i wont be able to make the fettling day
Are those the tubes that go from inside the airbox and fit on the top of the carbs?
Edited by Moose, 20 October 2009 - 03:58 pm.
#27 TonyDevil
Posted 20 October 2009 - 04:14 pm
with a little artistic license...
assuming £20 a week fuel and with a 20% saving it would take roughly 3months to break even wink.gif
airbox rubbers fit inside the airbox and attach to top of carbs
carb rubbers are between the engine and carbs
you may find they are fine, if they arent cracked at all just hard put them in hot water to soften em up and then refit
if they are cracked they'll eventually leak air/fuel
#28 Moose
    Master Cake Baker
  • 3,312 posts
Posted 20 October 2009 - 04:19 pm
QUOTE(TonyDevil @ Tue 20th Oct 2009, 05:14 PM) <{POST_SNAPBACK}>
The Rubbers from airbox to carbs were a little hard about 3 months ago so like ya say i put them in hot water and refitted them and they were fine and no cracks
Think we'll just go with the balancing for now and then do the rest when i can get some sheckles together
Cheers for ya help
#29 JollyGiant
Posted 20 October 2009 - 04:30 pm
QUOTE(TonyDevil @ Tue 20th Oct 2009, 04:14 PM) <{POST_SNAPBACK}>
I stuck mine in hot water and they fitted better after than they ever did before!!
If they are cracked smear some clear mastic over the cracks and it fills them and they'll be fine good.gif Did this on my old GPZ and they were ok for 3yrs before I sold it yahoo.gif
#30 TDMTAM
Posted 20 October 2009 - 04:33 pm
QUOTE(Jolly Giant @ Tue 20th Oct 2009, 05:30 PM) <{POST_SNAPBACK}>
I used to use Silkolene Pro-Prep on the old YPVS inlets, it seemed to rejuvenate them.
Edited by TDMTAM, 20 October 2009 - 04:34 pm.
#31 TonyDevil
Posted 20 October 2009 - 04:44 pm
#32 JollyGiant
Posted 20 October 2009 - 05:33 pm
QUOTE(TonyDevil @ Tue 20th Oct 2009, 04:44 PM) <{POST_SNAPBACK}>
I used to be known as "Billy Bodger"?? Yeah I have always fixed my bikes with the least amount of money possible! If not for free...
#33 Studley Ramrod
Posted 20 October 2009 - 09:46 pm
QUOTE(Moose @ Tue 20th Oct 2009, 05:19 PM) <{POST_SNAPBACK}>
Cheers for ya help
It's the 'unknown' extras that you may or may not need that needs to be accounted for. So a £40 tube swap becomes a potential £80 swap. BUT it makes sense to wait until you can afford to buy the lot should you need to.
JG, there's no real difference in the mk1 and mk2 carbies, fitting the tubes in both is an identical jobbie as such.
On the subject of cost, Wemoto prices seem to be getting up there. If you needed 10 valve shims you'd be looking at nearly £90 !!!! YES £90 !
That means I made a profit buying a head for £50 as the shims are worth £90 crayzeee hehe
Might be an idea to buy them tubes sooner rather than later as a) they might go up in price and b) they could run out of stock AGAIN ! 4 month waiting time.
Edited by Studley Ramrod, 20 October 2009 - 09:50 pm.
#34 Kaustic
Kaustic
  • 204 posts
Posted 20 October 2009 - 10:31 pm
QUOTE(Jolly Giant @ Tue 20th Oct 2009, 03:24 PM) <{POST_SNAPBACK}>
Kaustic could those Ti thingys be used as sliders on me boots??
If you can find a way to attach them , then yes I suppose. You could drill and counter sink a hole through the center but they are only 5 mm thick. Ill grap a couple more tomorrow.
k
TDM Mk2a
Mods (so far) : Heavy duty chain & sprockets, Braided metal hose (front), DL650 handguards, Hyperpro progressive fork springs, Ohlins rear shock & Oxford Heated grips
Wish list : Home made panniers & frames, LED side light, crash bar, centre stand, oversize foot for sidestand.
#35 Kaustic
Kaustic
  • 204 posts
Posted 20 October 2009 - 10:43 pm
When I had problems with cold running last year I had a look at the rubbers, there was some signs of cracking so I used super glue and black kitchen sealant tongue.gif which is what I had available. at the time.
TDM Mk2a
#36 JollyGiant
Posted 20 October 2009 - 11:55 pm
QUOTE(Kaustic @ Tue 20th Oct 2009, 10:43 PM) <{POST_SNAPBACK}>
The only prob with super glue is it's brittle and melts rubber/plastic!! But if it worked it another great bodging fixing idea clapping.gif
#37 harvey krumpet
harvey krumpet
  • 2,065 posts
Posted 21 October 2009 - 05:20 am
Any of you guys fancy popping down here for a weekend of fettling, cake & barbecues? I'm jealous! drinks.gif sad.gif
#38 ChrisG
Posted 21 October 2009 - 06:58 am
QUOTE(Studley Ramrod @ Tue 20th Oct 2009, 10:46 PM) <{POST_SNAPBACK}>
The Mk2a (ie the one with a fuel gauge and digital dash) has different carbs though and you can't change the tubes on them.
Whoever it was mentioned the damping on each fork leg being different, it probably means you've got more oil in one side than the other, which in turn probably means a leaking seal. You can check the oil level fairly easily (fork off bike job but not too hard), and can change the seals with a bit of inginuity, but if the seals have gone I'd personally change the bushes as well which is a bit more tricky.
#39 Guest_Catteeclan_*
Guest_Catteeclan_*
Posted 21 October 2009 - 07:18 am
Sunday the 8th is ok for me but we then have no-where open to get shims if needed.Come to think of it, I had to order what I needed last time anyway.
Edited by Catteeclan, 21 October 2009 - 07:19 am.
#40 Kaustic
Kaustic
  • 204 posts
Posted 21 October 2009 - 09:31 am
QUOTE(ChrisG @ Wed 21st Oct 2009, 07:58 AM) <{POST_SNAPBACK}>
Hi
(Model Mk2a)
I THINK unsure.gif the problem lies with the rebound damping adjuster on one fork leg only. The setting is done by a number of clicks from fully in. I double check that I set them both the same whenever I change them. I think that over a period of time (weeks ? ) the adjuster on one side is jumping out of position. The effect is quite unpleasant ohmy.gif .
I reset them at the weekend & will give it a while & recheck again to confirm my hypothesis when it starst to feel all wrong againl . blink.gif
k
TDM Mk2a
