Oil Pressure Light / Switch
42 replies to this topic
#21 Guest_leehenty_*
Guest_leehenty_*
Posted 21 April 2010 - 12:38 am
QUOTE(aytcat1 @ Tue 20th Apr 2010, 09:55 PM) <{POST_SNAPBACK}>
I thought of this idea,my offroader has a two stroke autolube oil tank,on top is a switch operated by a float and wondered if it would be possible to use this system on the 4TX oil tank so when oil is low the dash light comes on as it does when the two stoke oil tank is low.Problem was the oil level switch is about 4"long but came across these and there a lot shorter.Of course it would mean drilling a diam hole in top of tank but seeing as it is a tight rubber seal i wondered if it could possibly work http://www.chingtsan...ycle-parts.html
How are to going to be sure the oil tank is free of swarf from the cutting ? A cone cutter would do the job if you went slow.
BTW anyone making up a switch adapter for this must ensure it has a cross drilling or you will block off the oil supply. Also, as this is after the filter, it must be absolutely clean. A bit of swarf here would be instant death to the engine.
#22 Guest_leehenty_*
Guest_leehenty_*
Posted 21 April 2010 - 03:50 am
If you want the ultimate and can find a non moving place to mount the gauge, you can use one of these and have a oil pressure light and a gauge for the ultimate TDM. Just screw on the adapter.
http://cgi.ebay.co.u...#ht_1189wt_1166
#23 aytcat1
aytcat1
  • 1,093 posts
Posted 21 April 2010 - 04:46 pm
The 4TX oil tank top cover comes off, with the gasket below the sight glass for the oil level check
Edited by aytcat1, 24 April 2010 - 06:12 pm.
#24 Guest_leehenty_*
Guest_leehenty_*
Posted 22 April 2010 - 06:02 pm
Ok Guys here it is.
The Intermotor 50770 Switch modified to go in an 850. Two 10mm copper washers complete the job. Hammerman is the lucky guy selected from a host of applicants to test it. rolleyes.gif
Here are the photos hope it all works.
http://s923.photobuc.....20Switch Mod/
#25 3vd
Posted 22 April 2010 - 06:46 pm
Beautiful job! This is just what I spent hours searching for, for my 850, without any luck!
I'd like to do this mod on my '08 900.
#26 TheThigh
TheThigh
  • 443 posts
Posted 22 April 2010 - 07:02 pm
QUOTE(leehenty @ Thu 22nd Apr 2010, 07:02 PM) <{POST_SNAPBACK}>
Ok Guys here it is.
Hi Guys
If successful does this mean it will be avaiable for general 850 consumption? Also will hammerman be doing an oil switch installation for dummies guide complete with photos as penance for being the 'chosen one'?
Charlie
Currently - 2008 Red 900 ABS - 19k - 12v Socket - K & N Air Filter - Power Commander III - Mirror Extenders - Hepco & Becker Junior Panniers and Top Box - Fuel Exhausts - Pilot Road 2 Tyres.
To Do List - HID Bi-Xenon Projectors - MRA Vario Screen.
#27 Guest_leehenty_*
Guest_leehenty_*
Posted 22 April 2010 - 08:20 pm
QUOTE(maximuspetrolhead @ Thu 22nd Apr 2010, 07:46 PM) <{POST_SNAPBACK}>
Ah hang on a minute,
900's are a very different kettle of fish due to the oil tank clearance above the banjo. To do it on one of those will take some development of a brass horizontal port adapter, much more difficult. Watch this space though....
This is now sorted o another thread
Edited by leehenty, 03 May 2010 - 07:54 pm.
#28 Guest_leehenty_*
Guest_leehenty_*
Posted 22 April 2010 - 08:27 pm
QUOTE(The Thigh @ Thu 22nd Apr 2010, 08:02 PM) <{POST_SNAPBACK}>
Hi Guys
Charlie
I am happy to mod 50770 switches and supply the two copper washers to fit it for 850's, for a nominal fee.
Can we all please wait until Hammerman has proved the mod works, then I will make available for general consumption as a mod service.
We must get the design right first. This switch mod is the cheapest option, the next up is a brass adapter. I suggest you all scour ebay for the 50770 switches.
900 boys will have to wait a bit until I have developed one for my 900.
I would think it a fair price for Hammerman to do a photo installation guide. The 10mm copper wide section washers are a bit rare but I have 100 so far. So we can do about 50 to begin with if it all works ok.
#29 Guest_leehenty_*
Guest_leehenty_*
Posted 22 April 2010 - 08:38 pm
Hi Guys
Charlie
Edited by leehenty, 22 April 2010 - 08:40 pm.
#30 Guest_leehenty_*
Guest_leehenty_*
Posted 22 April 2010 - 11:03 pm
Having looked around for the 50770 switches, my Intermotor contact says they are obsoleteo, so I am going to make adapters in brass to fit a VW sensor as per the JBX TDM site drawings. BTW I have posted a comment with piccy links on there also.
If anyone can find the 50770 switches, I can still mod them. The prototype should be with Hammerman by Monday or Tuesday. He will no doubt be eager to try it out.
I am having a go at the 900 version this weekend.
Edited by leehenty, 22 April 2010 - 11:05 pm.
#31 dallasRUS
dallasRUS
  • 52 posts
Posted 23 April 2010 - 01:36 am
leehenty,
great job, thank you!
#32 Guest_leehenty_*
Guest_leehenty_*
Posted 23 April 2010 - 02:41 am
The 900 is a no go for the bottom banjo. Can't get the double banjo bolt in. Going for the banjo on the back of the cylinder head for this next. Sorry 900 boy's it's going to take some time.
Now sorted on another thread
Lee H
#33 hammerman
hammerman
  • 705 posts
Posted 23 April 2010 - 08:09 am
Hi Guys
Charlie
Yes, I'll be doing the installation guide with photos
#34 Guest_leehenty_*
Guest_leehenty_*
Posted 23 April 2010 - 08:55 pm
Sorted now on another thread
Edited by leehenty, 03 May 2010 - 07:55 pm.
#35 Guest_leehenty_*
Guest_leehenty_*
Posted 24 April 2010 - 07:06 pm
I have made up some brass adapters as per the JBX TDM drawings. This for 850's ONLY. If any one wants one PM me for costs and delivery.
I also have five of the citroen LNA switches coming to be adapted as previously posted. Again PM me for costs and delivery. These switches are difficult to get at reasonable prices. I bought all the supplier had at the time. BTW I have figured out how the image thing works now.
The Citroen modified switch,
I have modified Citroen switches for sale in the FOR Sale section, Brass adapters are waiting for a VW sensor to appear from the clutches of Royal Mail.
Edited by leehenty, 24 April 2010 - 07:29 pm.
#36 JBX
Posted 24 April 2010 - 10:53 pm
Great stuff leehenty, you're the oil pressure switch guru !
Edited by JBX, 24 April 2010 - 10:53 pm.
#37 hammerman
hammerman
  • 705 posts
Posted 24 April 2010 - 11:41 pm
OK folks,
Lee has done the switch so here's my photos of the wiring (Just needs switch installing now - it should arrive soon)
http://www.flickr.co...s/47339542@N08/
I'll do a proper write up in the week when I get time
Basically on the TDM 850 3VD, you tap the brown wire going to the temperature gauge as this comes straight from the fusebox, The warning lamp is then earthed through the oil pressure switch.
Great job on this one Lee
thanks
ps the warning lamps was one of these
http://www.vehicle-w...photo/l1260.jpg
http://www.vehicle-w...rninglights.php
I just removed the chrome bezel, and cut it down to make it into a filter for a bulb behind it (the bulb in the lamp as it is, is not replaceable)
Edited by hammerman, 25 April 2010 - 06:43 am.
#38 Guest_leehenty_*
Guest_leehenty_*
Posted 25 April 2010 - 07:01 pm
This is now possible on a 900, Look on the other thread.
Edited by leehenty, 03 May 2010 - 07:56 pm.
#39 Guest_leehenty_*
Guest_leehenty_*
Posted 28 April 2010 - 11:18 pm
I have been burning the midnight oils and have found the following.
The only types of M12 banjo sensors that can be modified are Intermotor 50770 (Citroen LNA 0.7) or Intermotor 50910 (Citroen Axel 1.1) ONLY. There are no other ones in the world. No other sensors have a fitting long enough to modify. Both of these are obselete.
For the brass adapter well near anything, provided it is switch normally closed, but those which fit the M 10 x 1 brass adapter are:
Intermotor 50660 (Landrover 110)
Intermotor 50760 (might be obselete)
VW part no 056 919 081
Volvo 1257137
Porsche 911 606 230 00
Aprilia sensor as per the JBX TDM drawing.
If we can't get those then its a big re-think on the adapter.
Lee H
#40 krasimiroff
krasimiroff
  • 13 posts
Posted 20 June 2010 - 08:48 pm
Anyone measured oil pressure at that point - where oil pressure switch is mounted?
At idle with hot oil.
