Such a small resistance might be difficult to measure by a poor tester device. I will make the measurements with another tester device just to make sure.
Matthieu
Posted 21 June 2011 - 05:16 pm
Posted 18 July 2011 - 03:45 pm
Posted 08 September 2011 - 05:43 pm
Posted 03 March 2013 - 08:32 pm
Hi, Thanks for the great advice on your post. I am about to tackle this as my battery dos not appear to be charging.
I have followed the steps as per the Haynes manual and the resistance between the 3 white wires is well in excess of what it should be for the 850.
The only point which is brought up in the manual is to check the problem is not in one of the white wires between the connector and the stator. i.e. a broken wire.
I have to say the wires look in pretty poor condition, so it could be the problem. Or is it the case that when you send the stator away to Robin he replaces the white wires as part of the work?
I have an multimeter for checking resistance etc, however not sure how the white wires are connected to the rear of the stator, it has 3 Phillips screws holding it in place, which look as though they are going to be a nightmare to get out, (currently got them soaking in WD40). If I do manage to get the stator out, will this give me access to take some readings and check the condition of the white wires?
Any advice is much appreciated.
Posted 03 March 2013 - 11:33 pm
The 900 has allen bolts holding the stator in place. I would think an impact driver would be your best bet for removal of Phillips head screws.
Once removed you could carry out a continuity check on the wires but I don't think they will be the problem.
Does he put new wires on?
Well to be honest, that's a good question. The first time I sent mine I cut the plug off (don't ask) and so asked him to put 500mm of new wire on for me, when I got it back I soldered it all back together.
When I got it back this time it was all neat and tidy with an insulating sleeve over the whole thing and it never occurred to me to check to see if the wires were new or not.
He's an amiable enough chap though, so a phone call couldn't do any harm.
Posted 04 March 2013 - 08:42 am
Aly, unlike the 900, a new stator for the 850 is much cheaper to buy.
http://www.electrexw...07.html#aG7#aG7
Posted 04 March 2013 - 09:58 am
Fantasic, thanks very much to both studley ramrod and celticbiker for the advice. Given the price of a new stator with wires for the 850 is only £65, I will probably go for that, which will at least cover all bases.
Great stuff
Posted 25 March 2013 - 02:32 pm
Just to add to this superb post.
I've just spoken to Robin Williams (the re-wind man in Devon) and he's still doing business. Still £50 inc. return P&P.
I've got mine to strip down and test but then I'll be giving him a ring to confirm my dead one is on it's way.
Dmm
Posted 25 March 2013 - 02:49 pm
I still have a pre fried one if you are in a hurry and want to send that as a core and then send me your dud.
Posted 25 March 2013 - 03:28 pm
Train ticket has already been bought, so not in a rush...munchos thanks for the offer tho Mr Badger man.
Posted 29 March 2013 - 05:27 pm
Next step.
I have bought a new stator. The 3 white wires which come away from the coil will need to be soldered on to the connectors, which fit in to the plastic housing. Can any one tell me if it matters which white wire goes in which space in the plug and if so how do I differanciate between them.
Many Thanks
Posted 29 March 2013 - 08:32 pm
Posted 28 April 2013 - 07:27 pm
Well I am nearly ready to do some wall demolishing with my forehead.
Having replaced the stator, with a brand new one along with new white wires up to the connectors. I reassembled the bike started it up, however the the battery still does not appear to be charging.
At tick over I am getting around 12.44 volts,
5000rpm about 12.25 volts
Having switched the bike off after about five minutes the voltage returns up to about 12.65 volts.
The resistance between the 3 new white wires still does no fall within the range in the manual and is 0.6 ohms.
If any one has any further suggestions, they would be much appreciated.
Aly
Posted 28 April 2013 - 07:40 pm
regulator, check connector isn't corroded and it has a good earth. Measure any of the white wires resistance to earth there should be no continuity at all.
Posted 29 April 2013 - 07:02 pm
Thanks, I'm a bit of a novice I'm afraid would you be able to tell me how to check the earth of the connector with my multimeter. I have checked the white wires resitance to earth and as you say there is infinite resisitance. I note there are new regilators on ebay for around £20, might be worth a gamble! Cheers
Posted 30 April 2013 - 09:06 am
sound like stator is ok as it should be it's new. between any of the white wires running should be around 25 volts AC at idle, so regulator next.
Incidentally, have you measured the old stator white wires to metal ring in the middle ? Before you chuck it might be a good idea.
Posted 21 June 2013 - 02:58 pm
Aly
0.6 is the magic number. I got that on my old stator and as it is outside all recomendations in links above and in the Haynes manual, I ordered a new one. Arrived today and tests at 0.6 ohms. Unfortunately, having removed the old one for visual inspection based on the advice that it was bad, I now have to decide whether to put it back on (gasket, oil etc) and sell the new one or put the new one on and swallow the loss.
Anyway, for info, a NEW STATOR READS 0.6 OHMS across all combinations of the three wires for a Mk1 3VD.
Posted 21 June 2013 - 06:07 pm
I noticed when checking resistance with my multimeter, it takes a good few seconds before the reading settles. Might be worth trying again and holding the probes in place for 5 seconds or more ?
Posted 21 June 2013 - 08:01 pm
Thanks Studley, held longer and readings dropped to 0.5. Then I had an idea: I put the meter pins together and got a steady 3. 5-3=2 which is close (to 1 decimal point) to Haynes.
The new stator is now mounted in the casing and will be assembled tomorrow with a new reg/rec. Expensive learning curve. ![]()
All back together with a new RR98 reg/rec aswell. Charging! ![]()
Edited by Hombre, 22 June 2013 - 05:11 pm.
Posted 18 September 2013 - 04:15 pm
In discussion with various members a number of these stator failures have happened after a service. (oil change).
I recently stumbled accross a tip:-
- soak the filter in oil as this ensures full flow from the off.
Does anyone with more engineering nous than me think this is a potential explanation - i.e. why the top of the stator burns out - could it be that not enough oil is flowing to cool the stator immediately after a service.
XT1200Z - Big and bouncy
GTR1400 - Chaufer the wife.
XT660Z - Fun and commute.
TDM900 - Yellow.
