Clunk on braking
34 replies to this topic
#21 Jez
Jez
  • 722 posts
Posted 19 April 2007 - 11:18 am
I have similar clunking noise on my Mk2.
I tightened the steering until it was too tight and then backed it off - so it is not that dry.gif .
I now have a different front wheel - so it isn't that either dry.gif .
It is not the calipers as it happens when not braking too - so it can't be that too dry.gif .
When changing fork oil I noticed some scuff marks and damage on the fork slider bearings but the marks looked to be only in the teflon coating - woohoo yahoo.gif , it must be that.
Can't be arsed to change them so I am living with it as it doesn't seem to affect the handling good.gif .
#22 Guest_GuyGraham_*
Guest_GuyGraham_*
Posted 19 April 2007 - 11:38 am
QUOTE(Jez @ Thu 19th Apr 2007, 12:03 PM) <{POST_SNAPBACK}>
When I was trying to eliminte my clunking, I put all new fork slider bushes in - it was just as bad, so its not them either
Edited by GuyGraham, 21 April 2007 - 02:52 pm.
#23 dandywarhol
Posted 19 April 2007 - 09:20 pm
I reckon the clunk is the spring moving in the tube - nothing to worry about - my 850 did it - I wonder if that's why the 900 has a short spring and big spacer tube.................. unsure.gif
#24 wicklamulla
Posted 19 April 2007 - 11:25 pm
anyone try winding in the fork preload all the way to see if that quietens it down a little bit ?? to be honest if i hear it i never worry bout it.
#25 Boštjan
Boštjan
  • 7 posts
Posted 20 April 2007 - 08:28 am
QUOTE(wicklamulla @ Fri 20th Apr 2007, 01:10 AM) <{POST_SNAPBACK}>
Fork preload or damping setting doesn't help.
#26 Guest_GuyGraham_*
Guest_GuyGraham_*
Posted 20 April 2007 - 03:45 pm
QUOTE(dandywarhol @ Thu 19th Apr 2007, 10:05 PM) <{POST_SNAPBACK}>
well the Race Tech springs in my forks are much shorter than OEM springs and have a long spacer tube - so it aint that
#27 Jez
Jez
  • 722 posts
Posted 20 April 2007 - 07:46 pm
QUOTE(GuyGraham @ Thu 19th Apr 2007, 12:23 PM) <{POST_SNAPBACK}>
Thanks for that, GG. I don't need an excuse to avoid changing the bushes but extra ammo never hurt good.gif
Edited by Jez, 20 April 2007 - 07:47 pm.
#28 jht
Posted 20 April 2007 - 08:17 pm
Come on Jez, crack out the ol'pinhole and chuck up some shots of the modded steed!! wink.gif
#29 Jez
Jez
  • 722 posts
Posted 21 April 2007 - 10:52 am
QUOTE(jht @ Fri 20th Apr 2007, 09:02 PM) <{POST_SNAPBACK}>
Okily dokily, don't mind if I do 'cos I think it looks ok good.gif . Just won't be today 'though. Now where did I put the Box Brownie and that newfangled posh sepia paper.......?
#30 Jez
Jez
  • 722 posts
Posted 22 April 2007 - 06:57 pm
Ok, check out my 17 incher:
A mate has a 17 incher fitted with a low profile sports tyre which leaves a big orrid gap twixt it and t'mudguard. The Z6 shown here looks much better IMHO.
The whole setup is great. The steering now has no weight and stability is not affected. A very highly recommended mod good.gif .
Edited by Jez, 22 April 2007 - 07:03 pm.
#31 Guest_GuyGraham_*
Guest_GuyGraham_*
Posted 23 April 2007 - 11:40 am
QUOTE(Jez @ Sun 22nd Apr 2007, 07:42 PM) <{POST_SNAPBACK}>
What's the wheel from?
to lower the front mudguard, a few washers, or spacers, between mudguard and fork lugs will lower it
#32 TonyDevil
Posted 23 April 2007 - 12:21 pm
how much does it affect the speedo?
#33 Jez
Jez
  • 722 posts
Posted 23 April 2007 - 02:45 pm
QUOTE(GuyGraham @ Mon 23rd Apr 2007, 12:25 PM) <{POST_SNAPBACK}>
It is from a 1989 FZR1000 EXUP. The spacer on the right will have to be turned down by 2mm to fit int the EXUP dust seal.
Good idea about lowering the mudguard. As I am not short of stainless washers this will get some consideration.
QUOTE(Toneski @ Mon 23rd Apr 2007, 01:06 PM) <{POST_SNAPBACK}>
I measured the two wheel diameters (including tyres) with a tape rule and calculated a 5% difference in the circumferences. This would seem to be true in practice. It is a blessing in disguise actually. Because the speedo reads high I am actually not going as fast as it says.
Edited by Jez, 23 April 2007 - 02:46 pm.
#34 Guest_GuyGraham_*
Guest_GuyGraham_*
Posted 23 April 2007 - 05:30 pm
QUOTE(Jez @ Mon 23rd Apr 2007, 03:30 PM) <{POST_SNAPBACK}>
Is that 2mm on the dia or 2mm length.
Is everthing else OK for a drop in fit ie disc to disc length, wheel spindle dia, speedo drive etc.
Ever thought of doing the back wheel to get a matching pair of 3 spokes
#35 Jez
Jez
  • 722 posts
Posted 24 April 2007 - 03:48 pm
It's 2mm off outside diameter. Everything else goes straight in. Using TDM spindle, speedo drive and discs.
I am not tempted to do the rear as I am happy with the Z6 and function is more important to me than form. So far I am lucky that IMHO the mods I have done fit in with both of these.
Also I do not know of a wheel that will easily fit in the rear. I did ask on this thread some while ago but the lack of response suggests it is not a common mod.
