Pulling The Rotor Orf Question..
89 replies to this topic
#21 Studley Ramrod
Posted 01 December 2010 - 10:45 am
and it'll have to bloody well wait too !
Now then, if oi were to make me own puller, what would be the optimal thread pitch for the centre bolt ?
I was thinkin' of using an 18mm dia bolt but looks like BrianVG used a bigger wan unsure.gif
#22 leehenty
  • 5,323 posts
Posted 01 December 2010 - 02:12 pm
Use a fine pitch like 1.0 or 1.25. its like using a thin wedge less torque gives more push.
If you are buying a bolt more likely will be 1.5 or 2.0
I used one of these on the 900 but made a set of rotor bolts to fit.
http://cgi.ebay.co.u...15#ht_506wt_934
Edited by leehenty, 01 December 2010 - 03:07 pm.
#23 leehenty
  • 5,323 posts
Posted 01 December 2010 - 03:37 pm
QUOTE(Studley Ramrod @ Wed 1st Dec 2010, 09:00 AM) <{POST_SNAPBACK}>
Teased the bolt out using the 19mm wheel brace and my handlebar extensionerer ! Only thing I could find to slip over the brace was me spare set of handlebars.
Did I mention the snow ?
Ian ,measure the diameter of that bolt that came out of that hole will yer and pm me, I'll get on me lathe and make you a steel protector for it. Also can you tell me the thread in the three open holes looks like 8mm same as the 900 but I need to know, I got the itch for making bits with all this snow....
I bet your shed is nice and warm...
Edited by leehenty, 01 December 2010 - 03:44 pm.
#24 Studley Ramrod
Posted 01 December 2010 - 05:56 pm
QUOTE(leehenty @ Wed 1st Dec 2010, 02:12 PM) <{POST_SNAPBACK}>
Yeah, the measurements.........
They are 8mm holes !
Bolt is 12mm vine peeeeeeach.
#25 dapleb
  • 18,388 posts
Posted 01 December 2010 - 06:06 pm
QUOTE(Studley Ramrod @ Wed 1st Dec 2010, 05:56 PM) <{POST_SNAPBACK}>
Jaws springs to mind again....but lettuce snow whats left when ya done as if it works oil get 12 err I mean 1 2 err no wait oil get wan two....nope thats still not right. Oil git wan too.
#26 leehenty
  • 5,323 posts
Posted 01 December 2010 - 06:25 pm
Thanks for that me lathe will be annoying the chavs next door tomorrow. laugh.gif
The 900 rotor looks almost identical so I'll make the 8mm high tensile 12.9 strength bolts to fit that, plus a little bit for 'adjustment'
12mm fine pitch is er 1.5 so I'll make the protector with that then.
Edited by leehenty, 01 December 2010 - 06:32 pm.
#27 Studley Ramrod
Posted 02 December 2010 - 01:44 pm
Lee, I think the 12mm bolt is 1.25 pitch. Sorry, shudda said so earlier sad.gif
#28 leehenty
  • 5,323 posts
Posted 02 December 2010 - 03:19 pm
QUOTE(Studley Ramrod @ Thu 2nd Dec 2010, 01:44 PM) <{POST_SNAPBACK}>
Ok mate no problem, haven't cut the thread yet. so its extra fine then. make a note of that in the 850 files.
Looking at the pics of the 'official' tools its a plain boss made to fit the root of the thread anyway. I will make two one plain one threaded, you try them out and tell us which works the best. they are only made of 16mm steel bar, cheap as chips.
When we have the info add it to the KB.
#29 leehenty
  • 5,323 posts
#30 Studley Ramrod
Posted 02 December 2010 - 03:26 pm
So, do ya reckon that Am-tech puller is easily up to the job ?
#31 leehenty
  • 5,323 posts
Posted 02 December 2010 - 03:37 pm
QUOTE(Studley Ramrod @ Thu 2nd Dec 2010, 03:26 PM) <{POST_SNAPBACK}>
Well I used mine to get me niner one off, warmed it with a heat gun in the centre and applied pressure and sharp tap with a copper mallet. The puller is americano so all the bolts they supply are UNF, I have some 60mm M8 allen screws and washers that are very strong 12.9's and die cut threads for good engagement I can send you three if you need them.
Regards,
Lee H
#32 leehenty
  • 5,323 posts
Posted 03 December 2010 - 08:09 pm
Yer crank end protector thingy is made mate, and did your big nut as well. The hex blocks are the slices of bar I started with
#33 Studley Ramrod
Posted 03 December 2010 - 09:15 pm
cool.gif Noice wan Lee, thankyou very muchly !
Do you think I'm gonna need them extra strong 60mm M8 allen bolts ?
I'm gonna buy the harmonic puller and get an additional 5mm steel plate with holes made to help strengthen it.
#34 leehenty
  • 5,323 posts
Posted 03 December 2010 - 09:30 pm
QUOTE(Studley Ramrod @ Fri 3rd Dec 2010, 09:15 PM) <{POST_SNAPBACK}>
Yes got three for yer, some high forces will be used on only three M8 bolts you need good threads and lots of tensile strength for safety. If anything broke it would twist and most likely damage the crank or rotor, causing much lamentation, bad language and throwing bits round the workshop.
#35 leehenty
  • 5,323 posts
Posted 05 December 2010 - 01:17 am
Just a pic of the tools I use to hold the rotor and the clutch basket of the 900, the 850 will be much the same, the rotor tool is actually called a sheave holder from the days when factories ran on big belts and lineshafting. Flat alternator belt is nice n grippy for this job. The original bit was a plastic sleeved metal spring steel strip.
The clutch tool can hold sprockets and gears too. You could make one from 6mm x 20mm flat steel bar quite easily and weld a nut on part of it for the lock. Just find someone who has a big vice.
#36 Studley Ramrod
Posted 05 December 2010 - 11:25 am
oooooh yeah, Real tools smile.gif Makes my wooden block and big screwdriver look quite primitive laugh.gif
Although I did notice Haynes also used a wooden block to remove the rotor nut.
Regarding the clutch tool, I know a man wot might have half a cake trolley, with wheels no less !
I doubt he's got a big vice though, being a hard-workin' family man an at !
Seriously though, I've seen the sheave holders and wasn't inspired with the plastic coated metal band but your mod looks to have sorted that out smile.gif Reckon I'll get me one.
#37 dapleb
  • 18,388 posts
Posted 05 December 2010 - 11:36 am
Snow gone now SR?
#38 Studley Ramrod
Posted 05 December 2010 - 11:52 am
QUOTE(dapleb @ Sun 5th Dec 2010, 11:36 AM) <{POST_SNAPBACK}>
Snow gone now SR?
Yeah, it's mostly melted and turned to block ice smile.gif I'm hoping the postal service and the shops etc are all up and running Monday.
Got the chav-ette oot. Fired up first time after being buried for 5 days.
Think I might have been a bit too ambitious when making me own snow shovel tho, aching like fook today jibberjabberjibberjabber..........
#39 Studley Ramrod
Posted 07 December 2010 - 10:38 am
It's official.... I HATE WINTER !
-10 last nite, up to -4 at present. Walking on 6" of ice everywhere........god knows what it's like outside !
No post now for a week, which is a tad annoying as I'm waiting fer the rotor puller parts to arrive, along with ANOTHER bike insurance cheque smile.gif
#40 dapleb
  • 18,388 posts
Posted 07 December 2010 - 10:44 am
QUOTE(Studley Ramrod @ Tue 7th Dec 2010, 10:38 AM) <{POST_SNAPBACK}>
The cold has cracked me grrrt big tick wire encrusted security window....shirley we can harness this power to git yer rotor oft.
