Mk2a Carb Stripperoony !
26 replies to this topic
#21 dablik
  • 10,885 posts
Posted 30 November 2019 - 03:26 pm
Yup i'm pretty sure i've seen it on here..
Any help looking at this..
#22 Studley Ramrod
Posted 30 November 2019 - 03:29 pm
All I could find was my previous suggestion of marking the existing fuel levels and then adjusting and seeing if it makes any difference.
#23 dablik
  • 10,885 posts
Posted 30 November 2019 - 03:31 pm
Maybe the Factory pro site has more info, but the measurements for setting mk2 float heights are stated in that thread so should help Murphy crack on..
#24 chrisbee
chrisbee
  • 410 posts
Posted 02 December 2019 - 04:40 pm
QUOTE(robelst @ Sat 19th Feb 2011, 11:45 PM)
I thought he Mk2a had TPS? The 2001 manual explains how to check and reset it.
I will soon find out, my Mk2a seems to have developed a nearly permanent carb-icing-like problem at low/mid revs (not electrical, leads/plus/coils are all new) so I either suspect the TPS is playing up, something is leaking or blocked, or a bird has built its nest in the air-box. MPG is still excellent, so no worn tubes. Compression is fine too, performance is still very impressive. It's done 71k miles now, apart from this and the clutch having run out of adjustment (not slipping though) it seems pretty healthy. I should probably move on to something fresher but it's become like an old pet: You know the end is inevitably near but throwing it out before it's really dead simply isn't an option style_emoticons/#EMO_DIR#/laugh.gif
Rob it does but u need to read the whole topic style_emoticons/#EMO_DIR#/excl.gif
How do you check the TPS??? Never knew i had one, till i read this 😂😂😂😂
#25 leehenty
  • 5,306 posts
Posted 03 December 2019 - 06:24 pm
Isn't a tps supposed to output a variable voltage ? Must be in manual how to set tje end point.
#26 wicklamulla
Posted 05 December 2019 - 09:23 am
Easy procedure once ya have located the Tri shaped (Tri shaped on a 1999-2002 TDM 850) plug connector.  The procedure is in the Haynes manual. I have reset a few over the years and i have never managed to set the rev counter to exactly 4k as described in the  procedure.  If in doubt leave it alone.
#27 chrisbee
chrisbee
  • 410 posts
Posted 05 December 2019 - 12:51 pm
I will have a look thru the manual...
cheers
Chris.
