Catsbum's Tinkering Day. Sunday 20th March
143 replies to this topic
#21 3vd
Posted 09 March 2011 - 07:55 pm
Yes they fit, I've got them (minus LEDs and £70!)
#22 sireastwood
sireastwood
  • 207 posts
Posted 09 March 2011 - 08:08 pm
QUOTE(maximuspetrolhead @ Wed 9th Mar 2011, 07:55 PM) <{POST_SNAPBACK}>
OOOOhhh me likey.. so £50ish is an ok price (make offer)...........Only thing is they don't say they will fit a tdm900????????? If they go in the bar ends should they not fit/ be adjusted to fit as £50 is allotta dosh to find out they don't.
Muppet with a spanner
I'm not afraid of death. It's the stake one puts up in order to play the game of life.
Black 07 Niner wiv scott oiler and The House Of Henty Stainless Enjun Kit(Thanks Lee)
Crash Bungs......(Thanks again Lee)
Stainless brake pad pins ...(Thanks again Lee)
Double Bubble Screen, Pipe Werx Oval Black SL Zorsts,Clear LED Rear Light Unit, Clear Indicators, PUIG Bellypan,Black Renthal 755 Medium Road Bars with Brace (Thanks Moose)
#23 3vd
Posted 09 March 2011 - 08:14 pm
They come with a fitting kit and it's pretty straightforward.
#24 TDMick
Posted 09 March 2011 - 08:17 pm
I'll need to burn in a new rear tyre that week end
#25 Studley Ramrod
Posted 09 March 2011 - 08:26 pm
QUOTE(Favs @ Wed 9th Mar 2011, 04:28 PM) <{POST_SNAPBACK}>
Strange request time
If you replace the seals and the coil springs in the seals you remove are intact & not rusty - can I have em please? First one to tell me why I want them (the correct answer that is - it is to do with motorcycles) wins a less fattening cyber Mars Bar.
To stop yer rubber fork protectors from slippin' ? Hmmmm, maybe not unsure.gif
To hold a plaggy bag over yer satnav/leccy farkle thing ? smile.gif
#26 sireastwood
sireastwood
  • 207 posts
Posted 09 March 2011 - 08:31 pm
QUOTE(maximuspetrolhead @ Wed 9th Mar 2011, 08:14 PM) <{POST_SNAPBACK}>
#27 Favs
Posted 09 March 2011 - 09:56 pm
QUOTE(Studley Ramrod @ Wed 9th Mar 2011, 08:26 PM) <{POST_SNAPBACK}>
Much more technical - a repair but not on the TDM.
#28 catsbum
Posted 09 March 2011 - 10:36 pm
Anyone got a torque bar they could bring?
#29 bigboat0
bigboat0
  • 289 posts
Have you tried to take the buggers off?
Fitted mine but for some reason the throttle side guard (with the same spacer as the clutch side) was restricting throttle movement, there was probably about 5mm clearance on the clutch side & very little on the throttle side.
Then I decided to fit heated grips so had to take them off, a bugger of a job to get the expanded inner sleeve back out without unscrewing the little conical expansion screw thingy fully & it ending up rattling around inside the handlebars resulting in a strip down of the brake, clutch levers & switchgear to get the bars hanging loose enough to extract the conical nut with a pair of long nosed pliers!
Contemplating if I'll bother putting them back on again!
06 TDM 900 - gone but not forgotten.
Triumph Sprint ST1050
#30 sireastwood
sireastwood
  • 207 posts
Posted 10 March 2011 - 04:06 am
QUOTE(bigboat0 @ Wed 9th Mar 2011, 10:36 PM) <{POST_SNAPBACK}>
So if i get them it would be wise to fit them after the heated grips.............. laugh.gif
#31 TonyDevil
Posted 10 March 2011 - 07:27 am
QUOTE(CatsBum @ Wed 9th Mar 2011, 10:36 PM) <{POST_SNAPBACK}>
#32 3vd
Posted 10 March 2011 - 08:24 am
QUOTE(CatsBum @ Thu 10th Mar 2011, 12:36 AM) <{POST_SNAPBACK}>
I've got a Norbar 1/2" drive one, probably a bit on the big side....
#33 ChrisG
Posted 10 March 2011 - 09:00 am
I've got 1/2" to 3/8" adaptor as well as 3/8" wrench.
#34 TonyDevil
Posted 10 March 2011 - 09:24 am
i have adapters for going up and down in sizes and 2 torque wrenchs (3/8 8-60Nm and 1/2 40-200Nm)
need me to bring a breaker bar too?
anyone on a 9er need to do a C&S kit? if so i'll bring that 36mm deep socket for the front sprocket too
#35 catsbum
Posted 10 March 2011 - 11:28 am
It's for the oil filter housing bolts. Never bothered but heard the stories of stripped threads!
#36 TonyDevil
Posted 10 March 2011 - 11:46 am
i wouldnt use a spanner/ratchet to do them, i use a screwdriver like bit with suitable attachment and do it handtight
#37 catsbum
Posted 10 March 2011 - 12:22 pm
QUOTE(TonyDevil @ Thu 10th Mar 2011, 11:46 AM) <{POST_SNAPBACK}>
Yep, thats what I use normally, Like a 'Hex' screwdriver.
#38 TonyDevil
Posted 10 March 2011 - 12:33 pm
QUOTE(CatsBum @ Thu 10th Mar 2011, 12:22 PM) <{POST_SNAPBACK}>
#39 Chris B
Chris B
  • 828 posts
Posted 10 March 2011 - 01:11 pm
It is just a stick on LED strips, They where under a fiver for the pair on ebay, I wired them into the headlight, it was dead easy. Probably the best mod I made.
They aren't as blue as that in real life.
02 TDM 900, Silver. 85k miles
#40 ChrisG
Posted 10 March 2011 - 01:36 pm
Those look like the same type as my red one I've got on the back, cost next to nothing
