Wot Have I Got To Take Off
43 replies to this topic
#21 Blackpin
Blackpin
  • 82 posts
  • TDM model: 1994
Posted 05 October 2011 - 01:38 pm
If all is well you can look at my Crack on this link
http://www.facebook....mp;l=ef7f5d7b1e
black pin
Ride the Round Britain Rally this Summer.
#22 Studley Ramrod
Posted 05 October 2011 - 02:46 pm
#23 dapleb
  • 18,388 posts
Posted 05 October 2011 - 04:15 pm
Doozer...wonder what the inside looks loike.
#24 Blackpin
Blackpin
  • 82 posts
  • TDM model: 1994
Posted 10 October 2011 - 07:23 pm
In bits at last
Take of list its long
A 12 pack to start with
Drain the oil out, you can do it with out but it makes last bit harder if you
leave it in.
Get bike off floor fount and back.
Pre - crack as many frame engine nuts as you can.
Don't forget the back bolt under gear box.
Shocker bottom bolt these some time stick.
When de-plunging wires take care we think this is going to be the hardiest
bit to re-build
After 8 hrs.and a 12 pack you should be ready for the welder
THING LEFT ON bars and head stock wiring harness
Yes to say wot we left on was the best way to make the list
of wot to take off.
Off to welder in the morning
jd
#25 Studley Ramrod
Posted 11 October 2011 - 08:40 am
laugh.gif yeah, not much in the 'left on' list.
Did you find any cracking around the inside of the frame ?
#26 Blackpin
Blackpin
  • 82 posts
  • TDM model: 1994
Posted 11 October 2011 - 10:47 am
DO NOT LOOK AT THESE IF YOU ARE OF A NERVOUS DISPOSITION NOT NICE PHOTO'S AT ALL
http://www.facebook....2...7338&type=1
Yes it is cracked very bad but not how you would think at all off to welders
jd
#27 Studley Ramrod
Posted 11 October 2011 - 11:05 am
#28 Rallyist
Posted 11 October 2011 - 12:10 pm
huh.gif Well I have a theory ... On mine I had bad vibration in the left hand footrest when revs were around 4500 and when pushed higher up the rev range felt like a worn out chain, chain & sprockets were replaced tested again vibration not quite as bad but still bad checked all engine mountings all tight but the rear engine mount where the frame crack appears to have originated was squeaking tortuously when tightened so I removed it and checked threads, it showed signs of butting up to the end of thread shoulders so I reinstalled with steel brake size washers, ordinary washers will not fit in hole, and liberal copper-slip and torqued up to the factory figures +5%. Road-test again vibration now only apparent at around 3500 and 4500 rpm and not really intrusive, smooth as a babies bum at the upper rev range.
My theory is that the manufacturing tolerance of this part of frame and engine allow this engine bolt to appear tight but in fact is slightly loose allowing flex and vibration resonance in this frame area hence causing a crack, whilst when new the bolt is full securing when it has been removed the natural stretch of the bolt compromises the tension that is being applied in this area, I may be wrong but in Blackpins case his bolt was broken and as he rarely gets to 3000 rpm Trialsrider rotflmmfao.gif he had not experienced what I had, so I told him to check it that's when he found it. good.gif
#29 Studley Ramrod
Posted 11 October 2011 - 12:48 pm
I wonder if a bad batch of said bolt cudda been fitted when the bike was being made. Or possibly over-tightened. unsure.gif
Whilst your theory works, it assumes the bolt has been undone/removed a few times previously and you'd only undo the bolt if you were takin' the engine out. Still perfectly possible though rolleyes.gif
#30 Studley Ramrod
Posted 11 October 2011 - 01:06 pm
Interesting................ the long allen bolt for the 1991 and 1995 mk1's have a different part number
1991 90110-10175-00
1995 90110-10299-00
It's on the 'Frame' page, item No.8, in the parts fiche.
#31 Rallyist
Posted 11 October 2011 - 01:36 pm
So it would appear that I may be correct cos this cracking only effects 91 -to- 95 models. good.gif
and it is listed as a part "Not Sold" and no price anywhere
Edited by Rallyist, 11 October 2011 - 01:41 pm.
#32 Blackpin
Blackpin
  • 82 posts
  • TDM model: 1994
Posted 11 October 2011 - 05:59 pm
Well back from the welder only to find when we got there the lower bracing under
the gear box was snapped right through all now welded up now to start the long rebuild.
I hope this has helped all on the site .
the Welding was 30 mins work.
these are the photo's of of the cracks and the welding work
Most of all look at your Engine bolts as posted by rallyist
Ride safe
jd
http://www.facebook....mp;l=83014e79a7
Edited by Blackpin, 11 October 2011 - 05:59 pm.
#33 Catteeclan
  • 2,571 posts
Posted 11 October 2011 - 07:50 pm
Just so happens I have a K plate in the garden at the mo. Gonna get checked tomorrow.
#34 Studley Ramrod
Posted 12 October 2011 - 09:35 pm
How's the rebuild going John ?
#35 Studley Ramrod
Posted 13 October 2011 - 04:37 pm
Dappers has 3 shims (he's a star !) and I've just ordered the 4th wan John smile.gif I'll let ya know when they've arrived and then sort out a time fer fittin' 'em.
#36 3vd
Posted 13 October 2011 - 06:00 pm
Not the tidiest welding there?
Hopefully this will look better once painted?
#37 Rallyist
Posted 13 October 2011 - 07:47 pm
Painted??? don't be silly it's a bike that belongs to 'Tatty-Man JD' aka Blackpin. rotflmmfao.gif rotflmmfao.gif rotflmmfao.gif
#38 Blackpin
Blackpin
  • 82 posts
  • TDM model: 1994
Posted 13 October 2011 - 08:37 pm
just got a bucket of ASDA price black T########### laugh.gif laugh.gif laugh.gif laugh.gif
Thanks on the shims
#39 Studley Ramrod
Posted 15 October 2011 - 10:42 am
#40 Blackpin
Blackpin
  • 82 posts
  • TDM model: 1994
Posted 20 October 2011 - 09:04 pm
QUOTE(Studley Ramrod @ Sat 15th Oct 2011, 11:42 AM) <{POST_SNAPBACK}>
Thanks for the fitting but a bit cold job
jd
