Downloaded this and used it all day against the Mega £££ one sainsburys have in there vans and had more detail and was spot on.. Nice find thanks
Global Positioning System
#21
Posted 15 February 2012 - 02:24 pm
My Super Modded TDM has gone to a new home ![]()
Posted 16 February 2012 - 07:56 pm
If I go to Google maps on me phone, and type in "Rue de Brehat, Morlaix" it finds the wode and I can see le "Alle de Coat Amour" heading south from the end of it. It heads a bloomin long way South/SSE....cous its an old railway lion.
If I go to mapsource and type in "Rue de Brehat, Morlaix" it does not find it....but since I have already googled it above I can locate it easy enough and it is named (even though it wasn't searchable). The "Alle de Coat Amour" is shown but only within the town of Morlaix after which it shows a dead end.
If it is even possible for those who are using these offlion phone apps that dont need an interweb connection to run the above test it would be greatly appreciated please and thank you.
Of course its entirely possible that this is (one day) user error but since my use is probably quite unusual I can see why this wouldn't be a problem for the majority and might not have a fixification.
#23
Posted 16 February 2012 - 08:07 pm
If you're searching from the unit, you have to select the correct country. Probably the same from mapsource, but I can't remember.
2004 Galaxy Blue. Owned since 486 miles.Renthal 755 bars, Bagster tank cover, Oxford heated grips, DL650 hand guards, Double Bubble screen, Scorpion Rad guard, Gel pad insert, HLD undertray, Angry Badger tailtidy, Roadsmart 4s, Givi E21s, E46 topbox, Ohlins shock and YSS cartridge emulators Currently not fitted - PC3, Remus Revolutions.
#24
Posted 16 February 2012 - 08:17 pm
#25
Posted 16 February 2012 - 08:28 pm
Try searching for Brehat in the road name AFTER entering the town of Morlaix. It finds it if you refine your search a little in that way. Again try searching for Coat Amour, rather than Alle de Coat Amour. It does find it.
The problem is almost certainly the mapset you're using - "City Select" is effectively satnav and doesn't have that level of detail for tracks. You'd need to chack on the Garmin website, but there is probably a mapset that will suit. That said, the unit will still be able to pinpoint your position with grid ref/Lat/Longitude references to use in conjunction with a map.
#26
Posted 16 February 2012 - 08:42 pm
Got it now. Sooo just a map to find. Have emailed the Cycle map dude and asked him to run the "Coat Amour" test.
#27
Posted 16 February 2012 - 08:50 pm
The maps you need (for the 60c) would be the TOPO maps, but they're stupid expensive to get a full set, so much so, it'd probably be cheaper to pay the online costs with Google maps! Not sure about the newser units. The Garmin site doesn't show the maps as screen shots, so I'd be inclined to find a local(ish) shop that sells them and have a gander first.
Another option already mentioned that might be worth a look is Viewranger, who also do euro OS type maps that you buy in sections for the regions you're visiting. I use the 1:50,000 OS maps on my phone and they work fine, but I've never tried them in Euroland.
#28
Posted 16 February 2012 - 09:17 pm
Viewranger would involve a new phone, though that is still an option I spose.
#29
Posted 16 February 2012 - 10:45 pm
#30
Posted 17 February 2012 - 12:23 am
#31
Posted 17 February 2012 - 08:01 am
I'm actually amazed you're considering something other than this. You'll be thrown out of the Luddites you know
#32
Posted 17 February 2012 - 08:40 am
On the TDM I would just go but on the treader going 5miles the wrong way...and then knowing you have to turn around and go another 5 miles back can get a little tedious.
#33
Posted 17 February 2012 - 05:27 pm
Maybe I ought to go back to night school.
#34
Posted 17 February 2012 - 08:19 pm
#35
Posted 19 February 2012 - 08:06 am
#36
Posted 19 February 2012 - 08:32 am
Trying to get to grips with the unit today now most of the reading has been done.
#37
Posted 20 February 2012 - 07:03 pm
Now I have found someone selling a map that is very similar to this one on an SD card. The problem with SD card maps is that apparently it is then not possible to load the maps onto the PC to route plan. But I have also found a downloadable GPX file with a route I want to do......will this GPX file just load onto the GPS device and overlay the map? (blimey I am scaring me'self ear, almost loike when Moose went all Techy on us).
The loaner has been a great help Trev and I ain't bust it yet and it aint been eaten by a hoss.
#38
Posted 20 February 2012 - 07:37 pm
#39
Posted 20 February 2012 - 07:45 pm
GDB, MPS and LOC files 'GPS Babel' also a good conversion program also POI Convertor
#40
Posted 20 February 2012 - 07:57 pm
Downloading...now.
Other Garmin file type .GDP? .MPS for mapsource.
