That small rectangular 14 liter fuel pump on the link you put up is the one I bought early on. I got onto it from a previous TDM owner over on AdvRider who used one and it worked fine for him. I decided not to use it, because it didn't have the fuel shut off valve and I wanted to keep all the ports on the petcock side like the stock one. I also wasn't sure of the original pumps output and though it might be a bit higher than 14.
Affordable Mk1 Fuel Pump Relacement
#21
Posted 15 April 2012 - 06:17 pm
#22
Posted 18 April 2012 - 11:11 pm
Now when it comes to modding the appearance I feel differently, but that is a story for another thread.
Again thanks OP for all your work and help.
#23
Posted 29 April 2012 - 03:41 pm
Yesterday I replaced the pump as an afterthought. My main goal for the day was to take pictures of the swmotech rack so that the somewhere there would be some directions in English,. but I have the pump and while I am farting around in the garage I might as well and so I did... and what an amazing difference! No hard start, no missing at idle when cold, no "on off switch" feeling on the throttle. I took mine apart and the membrane was indeed badly stretched, and the lines were full of white powdery crud. From the pictures in this thread my guess was that it was the original pump.
I was thinking about the why of this as I was drinking a beer and letting the bike idle for half an hour. (I wanted to test the fan on the radiator as this was the first day we have had near 70) and as best I can figure when the diaphram warps the pump has to suck harder to get the same amount of fuel, which robs the carbs of the vacuum they need do their thing. so in situations where a strong "pull" from the carbs is needed (like when cold, going up a long grade or 1/4 throttle the fuel pump steals enough suction that the carbs cannot force gas through the needle- so you got WOT, create enough suction to feed both the carbs and the pump and suddenly you feel like your doing a carrier take off, Now it accelerates smoooooth from 1500 to the redline in any gear with new fuel pump.
#24
Posted 29 April 2012 - 03:56 pm
#25
Posted 07 September 2012 - 08:50 pm
I explained to the parts manager that this was going on a '92 TDM850 for around half the price that Yamaha wanted for basically the same OEM pump. At that point, she asked why I didn't just rebuild the original. I mentioned that Yamaha and Taiyo Giken didn't offer a rebuild kit... and her immediate response was "that's strange, because I have a Polaris parts number showing up in the system that indicates a diaphragm and gasket set for this exact pump... I don't have one in stock, but they show a kit in the system.."
As you can imagine, my bug-eyed response was one of complete surprise... She spun the computer around and showed me the exploded diagram and a Polaris parts # of 3088170 that looked to include the pumper diaphragm and gaskets from the pumper chamber as well as the diaphragm and gasket for the transfer chamber. Although it didn't look to include the check-valve pieces...
She then asked be if I would like to order just the rebuild kit... at a whopping price of approx. $46/us (WOW...) and wait 4-6 days for delivery or take the complete pump in stock for $57/us...
No brainer... I left with the pump... and a parts # for possible rebuild kits for the 2 (yes.. count 'em...TWO...) OEM pumps I now have in the parts bin.
Gotta go pop the tank and get the fuel pump swapped out... If this works, I'll then start a thread on the completely over-engineered DIY carb sync board I fabricated during 4 days of nothing but rain...
But I HAD to pass this one along... Polaris Part #3088170... Here's a link with the exploded diagram...:
http://www.powerspor...32AA/parts.html
I'm sure with some looking, it could probably be found cheaper on-line... Heck, I was actually thinking about sending an email to Winderosa gaskets in Maine about possibly developing a rebuild kit for the OEM pump... they offer inexpensive rebuild kits for the Mikuni pumps. I may still follow through with this idea... but only after I get my ride sorted though.
Edited by use2know, 07 September 2012 - 09:24 pm.
#26
Posted 08 September 2012 - 08:59 am
Excellent detective work there !
I had a look at what other Polaris models the pump fits, there's loads of 'em !
http://www.powerspor...PP-3085275.html
#27
Posted 02 November 2012 - 10:27 am
If anyone is interested oi can enquire aboot a bigger discount for bulk order but I suspect since the pamps last about 20years, there won't be many takers.
#28
Posted 02 November 2012 - 12:16 pm
#29
Posted 12 February 2013 - 11:25 am
Has anyone found a UK supplier for the Polaris model yet?
#30
Posted 12 February 2013 - 12:37 pm
Yup. I found a local Polaris place that do em and there is a linky dink to an onlion place in this ear thread (or the other similar to this) I stink.
If ewe need wan in a hurry, I have one in stock for cost price. ![]()
If worn diagram is suspected on ye olde pamp, it might be worth trying the Snorv budget laminate replacement therapy first as a dignostic method....again, oi can knock ya wan oop if you so desire. http://www.carpe-tdm...&hl=+fuel +pump
#31
Posted 13 February 2013 - 04:46 pm
Dappers me old badger your a gent. I dont think I have a problem at the mo but when I opened the old fuel pump up the diaphram looked old and tired, Much like myself. I wanted a link to a polaris seller just in case the worst happend and it when phut.. If you have the time one of your lamitate prototypes would be well received. I think Im going to replace all the fuel pipes whilst I'm at it as it looks cheap enough to do. ![]()
#32
Posted 13 February 2013 - 05:14 pm
Yes Dappers if you are going to start cutting some ass-i-tate into pretty shapes, can I have one to try please.
#33
Posted 13 February 2013 - 05:59 pm
Ok, done, Lettuce snow addys and oil get um sent.
#34
Posted 13 February 2013 - 06:24 pm
Seeing as I'm nursing wan back to elf, can I have wan too jus tin case?
#35
Posted 13 February 2013 - 06:37 pm
Send us addy Matt.
If anyone blows up or otherwise explodifies don't tell oi tell Eeee (LeHavre legal talk that is). I have wan of these in at the mo though and still ear.
#36
Posted 13 February 2013 - 09:09 pm
I got one from here last year - http://polaris-parts.com - can confirm it definitely fits and is the exact same part as the 20 year old one - except newer ![]()
was about £40 delivered vs £130ish from the stealers
#37
Posted 17 February 2013 - 11:28 am
#38
Posted 18 February 2013 - 05:03 pm
Ditto muchas grassy ass. ![]()
#39
Posted 21 February 2013 - 04:57 pm
Arrived safe and well. Thanking you kindly.
#40
Posted 21 February 2013 - 05:02 pm
Cheap as chips.
