24hrs Of Hell, Fixing Fast Idle Plunger
32 replies to this topic
#21 Geordie Guy
Posted 23 April 2013 - 06:03 am
Thanks for the write up, I'll attempt to repair mine tomorrow.
Bikes been garaged since October, fitted battery & eventually got it fired up to find revs wont drop below 2k.
17 years of GS's and not had any such issues ;-)
I'm Sooooooo tempted to say something !!!!!
Thanks and good luck with it.
#22 leehenty
  • 5,320 posts
Posted 23 April 2013 - 09:45 am
 Use a decent PH2 bit to tackle the screws with not a  pozi bit. I found one of those Wera diamond coated bits give good grip without camming out. If you use a 1/4" small ring spanner to drive the bit you can get in the tight space.
Sometimes the cheese screws just chew out anyway.
Edited by leehenty, 23 April 2013 - 02:10 pm.
#23 Ronnie
Ronnie
  • 30 posts
Posted 23 April 2013 - 12:02 pm
I chewed up the little blighters with a PH2 and thought I was looking at a major strip down!  A nights sleep and fresh eyes in the morning prompted carefully gripping the screw head with a pair of long nose mole grips - that did the jobby!  Much respect and thanks to Mr Henty for his expert guidance along the way....
#24 Borderraider
Borderraider
  • 180 posts
Posted 23 April 2013 - 04:11 pm
Come up to Bellingham weekend of the 10th-11th May- there will be a Campsite full of GSer's to abuse :-)
2007 BMW R1200GS Adventure
2007 Kawasaki Versys 650
2009 Yamaha TDM 900
2013 Kawasaki Versys 650
#25 Geordie Guy
Posted 01 May 2013 - 06:44 pm
Is that the collective noun for a group of GSer's -
a Camp-site ........ :punishment:
#26 Borderraider
Borderraider
  • 180 posts
Posted 01 May 2013 - 07:21 pm
LOL
Soo.. The TDM owning organiser becomes a Ring Leader
2009 Yamaha TDM 900
#27 Borderraider
Borderraider
  • 180 posts
Posted 02 May 2013 - 05:16 pm
Struggled a little to remove the larger bolts, other than that much easier than I expected.
Hopefully the rubber boot will prevent it seizing again.
2009 Yamaha TDM 900
#28 dmmsta
dmmsta
  • 3,627 posts
Posted 03 May 2013 - 01:16 pm
I've had the rubber boot on mine for well over a year, and no issues to date.
I'm off to grab hold of a large lump of wood following that statement...
#29 drumwrecker
drumwrecker
  • 440 posts
Posted 06 May 2013 - 10:50 pm
I have done the above job twice in 23000 miles. replacing the bolts with hexigan head  the second time.
One of the big problems with motorbikes is mild steel in aluminium castings. One reacts with the other causing a seizure.
So I bought some Alumslip, made by Molyslip for this job but knowing it will get many other uses. Try getting a seized engine bolt out, impossible, I had one on my suzuki GS500E, it wouldn't budge.
I believe in using the correct grease for the job now such red rubber grease on brake seals and pistons. It is horrifying how seals react to ordinary grease and copper grease. One of the rubber guids in my old VFR brakes expanded by at least 25%. making them absolutely useless.
I like the idea of the gaitor over the pin, that would do a good job of holding the Alumslip on the pin.
1953 BSA Bantam, 1960 Ariel Arrow, 1948 Vincent Rapide, 1959 Matchless G11, AJS 250CSR, 1986 BMW K75s, Suzuki 1999 GS500E, 2002 Suzuki SV650, 1991 VFR750 FL, 2007 TDM900
#30 leehenty
  • 5,320 posts
Posted 07 May 2013 - 08:56 am
well said, I keep bangin' on to folks about copperslip on brake pistons as well, its for the sliding part of the pads.
The best anti seize in alloy is an alloy based grease, no sense in adding a third metal of copper to the mix to start off electrolytic corrosion. Add salt in there and it will all be fizzing away.
The folks who make ACF50 do a grease version as well which is rated for bearings. To date since I did the cold start with acf50 and the boot, never had to go back there.
I have turned stainless pins for my own and Chrisr's bikes out of 316 stainless rod, the 'final solution' to a problem that should have had a boot in the first place.
http://www.ebay.co.u...1948#vi-content
http://www.ebay.co.u...536787070&ps=54
Edited by leehenty, 07 May 2013 - 09:13 am.
#31 drumwrecker
drumwrecker
  • 440 posts
Posted 07 May 2013 - 12:42 pm
When I found the engine bolt of GS500 was seized it took me on a Google search about elctrolytic effect of one metal on another. There is a table somewhere.
It rather surprised me to find out that mild steel was better than stainless with aluminium.
#32 leehenty
  • 5,320 posts
Posted 07 May 2013 - 01:28 pm
so long as the cathode (stainless steel) is smaller in area relative to the anode (aluminium) there is little risk of corrosion. So you would have problems with alloy screws in stainless steel plates, but rarely with stainless screws holding alloy plates.
I always seek to 'switch off' the galvanic cells by using acf50 on the screws. They use this stuff in aircraft wings.
So far it's been good stuff. Just costs a lot.
#33 drumwrecker
drumwrecker
  • 440 posts
Posted 07 May 2013 - 06:09 pm
Not heard of corrosion block before.
Thanks for the tip.
I always treat my bike with ACF50 each year just before the salt and it does seem to work.
