A Big Thanks To Dappers
48 replies to this topic
#21 leehenty
  • 5,326 posts
Posted 24 February 2013 - 05:28 pm
Keep them in a locked safe next time.
1. you will always know where they are.
2. no one can 'accidentally' pick them up.
Them shims is vital to the TPLQHCSRSFC  service. The lifeblood of this forum.
Don't ask me what it all stands for though.
#22 Frajt
Frajt
    Lost at Sea
  • 222 posts
Posted 24 February 2013 - 06:02 pm
Lee, is this something we will need for the Fettle day on 24th March?
At risk of doing something exciting!
#23 dapleb
  • 18,399 posts
Posted 24 February 2013 - 06:15 pm
Only send out required shims, so you would need to know which shims required afore hand Frajt.  I also agrozzle with others aboot stone cold injun for shim measuring, so fettle day not ideal unless you have a cake night the night before.
#24 Studley Ramrod
  • 19,373 posts
Posted 24 February 2013 - 07:00 pm
Glad ya found 'em !  :badgerrock:
#25 Frajt
Frajt
    Lost at Sea
  • 222 posts
Posted 24 February 2013 - 07:10 pm
Thanks for the reply Dappers...... ;-))
At the moment the plan is to deliver the bike over to the fettle venue the day before so measuring should work out OK...... Not sure how we'll handle the outcome though.......
#26 wicklamulla
Posted 24 February 2013 - 07:51 pm
get the clearances measured and decide what size shims ya need then swap em out at some udder time like 'fettle day II' the sequel.
#27 leehenty
  • 5,326 posts
Posted 24 February 2013 - 11:10 pm
We will have a measure, see where we are, I do have a set of shims I can bring along with me if it turns out any are needing changing.
#28 maldac
maldac
  • 54 posts
Posted 26 February 2013 - 06:20 pm
so wot does the TPLQHCSRSFC  sta\nd for then ? as im no good at anagrams
got one at last
#29 dapleb
  • 18,399 posts
Posted 26 February 2013 - 06:34 pm
Hey maldac, thanks for askin....ahemm.....The Pa Larkin Quality Hand crafted Shim Retaining System Fan Club.  Which is the Fan Club of the Quality Hand Crafted Shim Retaining System Hand Crafted with Pa Larkin Quality by Pa Larkin for the Retaining of Shims.
We used to do this alot so decided a few acro wotsits would make it less complicated when discussing The Pa Larkin Quality Hand Crafted Shim Retaining System or the associated fan club, namely, The Pa Larkin Quality Hand Crafted Shim Retaining System Fan Club.
As an active member of The Pa Larkin Quality Hand Crafted Shim Retaining System Fan Club I would like to point out that membership of The Pa Larkin Quality Hand Crafted Shim Retaining System Fan Club is free and there is a warm welcome for all who appreciate The Pa Larkin Quality Hand Crafted Shim Retaining System and those who would like to know more about The Pa Larkin Quality Hand Crafted Shim Retaining System and The Pa Larkin Quality Hand Crafted Shim Retaining System Fan Club.
#30 tdm850rider
Posted 26 February 2013 - 06:55 pm
Or TPLFC for short....
#31 dapleb
  • 18,399 posts
Posted 26 February 2013 - 07:01 pm
Ermm noooooooo that misses oot the Quality  and Hand Craftedness ...and also reasonably importantly the fact that its the Fan Club of his Shim retaining System.....what is Quality and Hand Crafted.  So its TPLQHCSRSFC for short.
For TPLFC...see his manager.
#32 maldac
maldac
  • 54 posts
Posted 26 February 2013 - 07:13 pm
Thanks for the answer Dap, i am now enlightened and proudly  aware of  the pa larkin quality hand crafted shim  retaining system fan club, now i have to lie down in a dark room for a while.
got one at last
#33 Rallyist
Posted 26 February 2013 - 07:15 pm
Think 'Shim Stash'
:hide:
#34 Studley Ramrod
  • 19,373 posts
Posted 26 February 2013 - 07:29 pm
I've got a brilliant idea ! :)
As the No.1 fan of The Pa Larkin Quality Hand Crafted Shim Retaining System Fan Club, I've been aware of the recent failed plot by copyright fraudsters, to infiltrate the Postal Service in an attempt to steal the The Pa Larkin Quality Hand Crafted Shim Retaining System in transit.   I'm also aware of the recent nigh on apocolyptic circumstance that happened when The Pa Larkin Quality Hand Crafted Shim Retaining System was thought to have been lost.
My solution is to make a more substantial Pa Larkin Quality Hand Crafted Shim Retaining System using a vintage solid hardwood back door !  Brilliant eh ! :)
No more putting it into a small tread ear pan ear, and wayyyyy to big to fit in the postbox too !  You also get the benefit from vintage of it being Quality Hand Crafted.  Obviously if the door actually belongs to Pa Larkin, we wouldn't even need to change the name. :D
#35 maldac
maldac
  • 54 posts
Posted 26 February 2013 - 07:51 pm
i like the way u fink  :)
having done the spoarkplug challenge on me 9ner do you think i am qualified to attack these shimmy things or am i getti9ng too big for me boots?
got one at last
#36 Studley Ramrod
  • 19,373 posts
Posted 26 February 2013 - 08:09 pm
Well, it's certainly a big step up Mal.  Checking the valve clearances is reasonably straightforward but adjusting them (swapping the shims) is a bit more technical involving setting up the timing after removing/refitting the camshafts.
#37 leehenty
  • 5,326 posts
Posted 26 February 2013 - 09:07 pm
If you are unsure,  get one of the experienced carpedians to help you, once you've done it it's easier the next time.
Just take your time. dablik did his with virtually no previous experience, his came out ok.
My advice is to turn the engine over by hand using the bolt head in the alternator cover hole after you done them and make sure all the marks line up, before trying to start it on the button. If you have got anything wrong and it goes tight, you can't damage the engine gently turning it by hand.
You will have to wind the cam chain tensioner back in, and hold it with the T shaped bit of metal a new one comes with or a small screwdriver. Pop it back in the engine, release it and it will spring out to tension the chain.
You need a decent set of feeler gauges and the manual from JBX's excellent site.
Edited by leehenty, 26 February 2013 - 09:09 pm.
#38 maldac
maldac
  • 54 posts
Posted 27 February 2013 - 08:13 pm
my bikes done 25000 mls so i really should do it i guess as looking at it the tops never been off the motor , I have rebuilt engines before and have a fine selection of hammers and mole grips so i should be fine if i stock up with coffe and cake. If not i will call upon a responsible adult to turn up on his trusty steed to help [ are you reading this cb ].
got one at last
#39 OldGreyWizard
OldGreyWizard
  • 258 posts
Posted 27 February 2013 - 10:05 pm
Dapleb, I've got two shims left over from my recent experience with doing the shims on the 9'er, 190 & 188, do you want these as a donation to the TPLQHCSRSFC?
P.M. an address to me if you do and I'll drop them in the post.
If Yamaha engineers were real geniuses, they would make the Cam lobes wear at the same rate as the valves wear into the seats. If this were done we would never need to do the shims.
As for can anyone do this?, well yes, but you do need the proper tools, lots of patience, time and have read all that you can from the manuals and tutorials.
As well as a good set of feeler guages, a micrometer 0-25mm and one of those extendable magnetic pen shaped things are very very useful.
It also helps if after you carefully arrange all of the shims and buckets your daughter doesn't kick them and scatter them all over the garage!!
Having done the shims once I will do it again. I'm well on the way to becoming a TDM Master, but I've still got a few stages to complete, carb balance and stripping the forks.
#40 dapleb
  • 18,399 posts
Posted 28 February 2013 - 07:04 am
Yes Peas OGW.  :badgerrock:
