Any Tips On Removing Pistoons From 22Year Old Calipots?
60 replies to this topic
#21 danceswithmopeds
danceswithmopeds
  • 2,425 posts
Posted 04 November 2012 - 09:32 pm
Dental probes. Don't use a sharp or pointy one, look for one that has a little spoon shaped end.
Do you have a Dental Supply company anywhere near you?
I haven't got a clue what the correct description is, I used to just walk into stores and have a looksee then sign out what I wanted.
#22 dapleb
  • 18,398 posts
Posted 04 November 2012 - 10:48 pm
Ah never though o that ta dances, have lots o dental probes but they moight be a tad too big. :)
Was trying to think of a non metal something.
#23 wicklamulla
Posted 04 November 2012 - 11:05 pm
Peat, cut some hazel whips (of varying sizes) out of a ditch near home and sharpen them, good fer scraping out those recesses. I too have a stock set of MK2 front calipers and rubber hoses and may attempt this rebuild too. I did hear a rumour that Goodrich (out near exeter airport) will build you a set of custom rubber hoses, so might be worth ringing them.
#24 dapleb
  • 18,398 posts
Posted 04 November 2012 - 11:09 pm
Noice wan. I have found a place that will make up the hoses, just need to take em in the oldies to use as a template. Will speak to Goodridge first as it might be these guys will justpost it oft to Goodridge anyroad. :good:
Will a walnut whip do?
#25 stu
stu
  • 2,060 posts
Posted 05 November 2012 - 10:11 am
What about some copper pipe, trimmed to size? Something softer than the caliper metal is what you want.
#26 danceswithmopeds
danceswithmopeds
  • 2,425 posts
Posted 05 November 2012 - 02:42 pm
Just thought of my second most used thingies. Wooden coffee stirrers from McDonalds. Sharp penknife to make the end you want.
Soak in boiling water for a few minutes, and you can form a permanent curve in stirrer.
#27 dapleb
  • 18,398 posts
Posted 13 November 2012 - 09:08 pm
Yes yes I know I'm slow!
Some progress though and a free painting lesson (much needed):
I managed to get the crud out of the grooves thanks to the helpful Carpedian hints. Also found that sticking em in the airing cupboard for a few days made all the crud powderify and was then crumbled oot very easily.
Lightly BLASTED (is that possible)
Attached File  calipot_blasted.JPG   48.11KB   21 downloads
Primered
Attached File  calipot_primer.JPG   60.69KB   36 downloads
Paint and Lacquer
Attached File  calipot_lacquered_drying.JPG   192.06KB   25 downloads
Just refitted the seals and pistoons with lots of red grease and brake fluid.
Any guesses of a torque setting for the calipot half bolts? Noubt in Heinz or Worksop Manuel.
#28 Studley Ramrod
Posted 13 November 2012 - 09:18 pm
Mr Henty could probably calculate the torque if ya let him know the bolt specs ?
Me, I'd say a good tweak and a little nip should be spot on. :)
Lookin' good !
#29 dablik
Posted 13 November 2012 - 09:20 pm
:cool: oooh very nice indeed dappers.. looking good :good:
I split a pair of Nissins like that once and did em up bassad tight,, and they were okay,, errrr but no, dont know sorry..
#30 dapleb
  • 18,398 posts
Posted 13 November 2012 - 09:22 pm
Yeah theres a generic table of bolt size vs torque in one of them there Manuels. The plan is to "use the force"...but not too much. Should be fine, just interested in what others would guess at. If ya get enough people to guess how many sweets are in the jar you can eventually get a very accurate result.
#31 wicklamulla
Posted 13 November 2012 - 09:23 pm
lookin good.
#32 Studley Ramrod
Posted 13 November 2012 - 09:52 pm
Okeedokee then, I'll start the bidding at 28Nm :)
#33 dapleb
  • 18,398 posts
Posted 20 November 2012 - 04:33 pm
They do and it was, thanks for that one. The 2000 brake system on me boike has funky connector blocks but for me orig mkI hoses, they said it shouldnt be a problem, post or drop em in and they will have a look-see. Even offered to deliver to NEC if I were goin. Were keen and helpful.
#34 wicklamulla
Posted 20 November 2012 - 09:11 pm
ahh i loike the sound of that, will keep the boike looking fairly original. any idea on price ??
#35 dapleb
  • 18,398 posts
Posted 20 November 2012 - 09:17 pm
Snot yet but they will have a look, telling-bone with a price if they can do em (which I'm sure they can). Will report back when I know more.
#36 Bikertone7
Bikertone7
  • 78 posts
Posted 21 November 2012 - 08:15 pm
Me calipot halves are soaking in jollop at the moment and I have scrubbed with toothbrush but still some skanky bits in the seal grooves. Any good tips for cleaning in this confined area without scratching bits please and thank you?
I borrowed a dremel hobby drill off a mate with a tiny wire wheel brush cleaned the grooves out a treat.
Other bikes: 1968 Triumph TR6 650cc, 1991 Honda Transalp 600 (everyday runabout), 2013 Triumph Tiger 800 Road, 1979 Kawasaki KL250 green laner (Winter Project)
#37 dapleb
  • 18,398 posts
Posted 21 November 2012 - 08:18 pm
Thats a bloomin good idea.
#38 Bikertone7
Bikertone7
  • 78 posts
Posted 21 November 2012 - 08:29 pm
Picked one up at a jumble later on been a really useful little tool
#39 RolfieB
RolfieB
  • 1,069 posts
Posted 21 November 2012 - 08:30 pm
Nice job Dappers.
Now I just fly everywhere.
Gone to new owner.
Black Mk2a
#40 wicklamulla
Posted 25 November 2012 - 10:45 pm
ear yew Dapleb, is your MK2a hoses cracked and worn out or are ya just tarting her up and sints yer lottery win yer just throwing money at the old gurl ?
