900 2 Into 1 Pic's
25 replies to this topic
#21 jono49
jono49
  • 1,183 posts
Posted 26 June 2016 - 05:30 pm
Frits have a look on Spanish E-bay for the Ixil item as they were supposed to be doing another production run last September :good:
#22 frits44
frits44
  • 170 posts
Posted 29 June 2016 - 01:17 pm
Jono49, Thanks for the answer.
This is what I am going to do with the exhaust,
I will use the stock downpipes cut it in pieces turn it and welt it together in a 2 into 1 system using a Y piece
Why because I can do it myself and its also a sport of mine to use the stock parts and change it or make it
better. I also like the sound off a 2 into 1  system it is deeper and nicer to hear.
If you hit the throttle you can hear more pressure from the 2  into 1 exhaust.
But thats the way I am thinking.
I also will use a shorter and smaller muffler.
I know that 2 into 1 exhaust systems are better for a 2 cylinder engine.
Back pressure, means better filing, more pressure on the cylinders, more torque and much smoother when you ride the bike.
Back pressure is very important on a two cylinder engine.
Almost all  new two cylinder engines have 2 into 1 exhaust systems.
A the moment a have no time for this, so it has the wait for a wile
Again thanks,
Greetings,Frits from holland
#23 Bjørge
  • 1,877 posts
Posted 30 June 2016 - 07:42 am
...and the old 850's.....   :)
EDIT: A 2-1-2 system, actually
Edited by Bjørge, 30 June 2016 - 11:08 am.
#24 fixitsan
  • 4,839 posts
Posted 30 June 2016 - 10:08 am
So does that mean that the Nexus 2 into 2 fitted to my mk1 is a performance downgrade ?  :huh:
#25 frits44
frits44
  • 170 posts
Posted 30 June 2016 - 01:58 pm
It is a pity that the down pipes of the 850 does not fit the TDM 900
It would be nice 2 in 1 exhaust pipes
Greetings, Frits from holland
#26 fixitsan
  • 4,839 posts
Posted 30 June 2016 - 01:59 pm
I need to correct that, it's a Nexus 2 into 1 into 2 again....so it still brings both downpipes together into 1 before splitting again
